Author Topic: The Rusty Brick - '92 K100RS  (Read 154198 times)
Re: The Rusty Brick - '92 K100RS
« Reply #300 on: February 15, 2017, 09:01:12 AM »
Can I ask you how you know?
Offline Filmcamera
« Reply #301 on: February 15, 2017, 09:03:43 AM »
He could tell you but then he'd have to kill you...
  • San Jose, Costa Rica
Poserbricker
« Reply #302 on: February 15, 2017, 09:11:38 AM »
How do you know?
Offline Filmcamera
« Reply #303 on: February 15, 2017, 09:13:00 AM »
see above... just replace he with I...
Poserbricker
« Reply #304 on: February 15, 2017, 09:23:50 AM »
I could tell you but then he'd have to kill you.
Does he earn dinner out for that?
Offline jakgieger
  • itinerant farmer
« Reply #305 on: February 15, 2017, 10:37:53 AM »
No, HE still has some court ordered public service to fulfill.  Trying to get it all accomplished before our legal system gets any crazier :deal: !
  • Kansas USA
  • 1989 K100rs se
Offline bocutter Ed
« Reply #306 on: February 15, 2017, 01:03:31 PM »
Will everyone just quit beating around the bush! :giggles
Ok ... so I bought my brick with 55667 Km on the clock. The next year I was having problems with the speedo, and had always had trouble with the tach, mostly due to a corroded wiring loom. A working cluster showed up on fleabay california and ...
Of course the Cali cluster was in MPH with KPH not as prominent not a big deal. Swapped it in and recorded the Odometer readings. Shortly after that, that cluster was giving problems so I combined the best of the 2 units. Now I had a good cluster, metric speedo & odometer, good wiring loom, functional clock, etc. All this farting around had left me with a few hundred kilometers missing on the original odometer ...
... so I reset the clock ahead to where it shoud-a-bean.  :hehehe  That's when I noticed the last number was advancing by x.5 ...
  • Toronto, Canada
Offline The Dude
« Reply #307 on: February 15, 2017, 01:32:52 PM »
Haha you clowns,how do I know in deed?
I took a toyato diesel car one apart to "see how it worked".Putting it back together was an effing nightmare.I gave up trying to get all the numerals to sit in the right place,let alone read the true mileage...
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #308 on: February 15, 2017, 01:48:02 PM »
The knowledge base here is getting yuuuge!
Offline MaraudeRS
« Reply #309 on: February 17, 2017, 11:23:40 AM »
Is it normal to have to pull the clutch in to start the bike? I have to do that even when it's in neutral
  • Monterey, CA
  • 1992 K100RS
« Reply #310 on: February 17, 2017, 11:53:17 AM »
Your bike should have a start-in-neutral function if it is stock. When it is in gear, we pull in the clutch to start it. It's a safety feature. Some bikes have a side stand electrical switch that won't allow starting until the stand is raised. Other bikes have mechanical linkage that raises the side stand when the clutch lever is pulled.
Offline MaraudeRS
« Reply #311 on: February 17, 2017, 12:04:06 PM »
Thank you. Do you know what's broken that would cause this?
  • Monterey, CA
  • 1992 K100RS
« Reply #312 on: February 17, 2017, 12:10:30 PM »
Cause what—starting side stand up and with the clutch in but not starting with the side stand up and the bike in neutral?
Offline MaraudeRS
« Reply #313 on: February 17, 2017, 12:30:00 PM »
The bike won't start with side stand up and gear in neutral without pulling in the clutch
  • Monterey, CA
  • 1992 K100RS
« Reply #314 on: February 17, 2017, 12:35:22 PM »
Does your bike have mechanical linkage that raises the stand with a clutch pull?
Offline MaraudeRS
« Reply #315 on: February 17, 2017, 12:39:38 PM »
No
  • Monterey, CA
  • 1992 K100RS
« Reply #316 on: February 17, 2017, 12:44:13 PM »
Does the neutral light work?
Offline MaraudeRS
« Reply #317 on: February 17, 2017, 01:04:45 PM »
No
  • Monterey, CA
  • 1992 K100RS
« Reply #318 on: February 17, 2017, 01:37:35 PM »
No
Read this. It might help you sort things out. It's missing illustrations which is the result of posting photos from a server rather than uploading them to this site from a computer.
Offline MaraudeRS
« Reply #319 on: February 17, 2017, 01:59:17 PM »
Thank you sir! You are a gentleman with a scholarship :giggles I have a feeling it's going to be the gpi on the transmission judging by the bikes history.
  • Monterey, CA
  • 1992 K100RS
« Reply #320 on: February 17, 2017, 04:13:49 PM »
The GPI is extremely susceptible to water and road crap. They can be carefully pulled apart and cleaned. Mine failed about 18 years ago,
so I waterproofed the new one with Plasti Dip and have not had a problem since. I now have the old one cleaned and waterproofed as a spare.
Offline MaraudeRS
« Reply #321 on: February 17, 2017, 05:50:03 PM »
Thank you Martin. That's a great idea. I have some experience with plasti-dip so I may do that.
  • Monterey, CA
  • 1992 K100RS
Offline MaraudeRS
« Reply #322 on: March 13, 2017, 11:36:55 PM »
Has it really been almost a month since my last post?? Well here's an update:
I got the fuel tank patched up and exhaust replaced by a mobile welder who came to my house. I polished the header pipes with some 350 grit sandpaper first, then some 1500 grit sandpaper to shine them up. They're not perfect but a yuuuuge improvement! The exhaust note now sounds deep and throaty...i love it!
New brake lines installed.
I got the headlight wired up and installed but I'm not yet sure how I feel about it. I liked that it had integrated turn indicators. Maybe it's that the lunchbox is still on, but I'm not thrilled with it. Don't spare my feelings, let me know what you think. When I get the Koso TNT installed it's probably gonna look a lot better.
I got the transmission oil replaced.
I topped-off the gear oil in the final drive. It was a bit low.
What's left to do, for now, is install the mirrors and bleed the brakes. Here are some pics for proof:
Those valve stem caps are the icing on the cake, are they not?! Lol
  • Monterey, CA
  • 1992 K100RS
« Reply #323 on: March 14, 2017, 12:24:36 AM »
When they are stolen you can replace them with skulls.
Hard to believe it's the same bike. I think the headlight fits in with it. Have you putted around the neighborhood yet. Don't the Cali po-po want the registration plate lit? Does it have a spotlight on it?
Offline MaraudeRS
« Reply #324 on: March 14, 2017, 03:44:58 PM »
Skulls, why didn't I think of that?! Haha
No rides around the hood yet. I still need to bleed the brakes. Clymer says that if you have ABS you need to take it to an authorized service center to have it done. Does anyone here do it themselves? What's the procedure?
  • Monterey, CA
  • 1992 K100RS
