Author Topic: how bad is this?  (Read 8916 times)
Offline zipster68
how bad is this?
« on: August 08, 2016, 01:09:40 PM »
Just bought this 1985 naked K100.  Then I noticed this.  Looks it has suffered a low speed drop due to some plastic wear on the LH turn signals.  So, is this the kiss of death?  Could I have this welded.  Ride as is?
  • Ferndale, Michigan
  • 1986 K100RS, 1977 naked Goldwing, 1975 Yamaha RD350 smoker, 1978 Vespa P200, 1980 Lambretta Jet 200
Offline riots100
Re: how bad is this?
« Reply #1 on: August 08, 2016, 02:25:49 PM »
That part of the broken bolt shaft is unthreaded, so the missing piece was only maintaining compression pressure between the bolt and engine block to hold the cylinder head on.  The missing piece reduces the available area for maintaining compression thus putting more stress on what remains.
I would not do too much riding with it the way it is, as it will overly stress what remains of the bolt shaft compression points and compromise the cylinder head seal.  A good welding job should help redistribute the pressure stress to what it was.
The good news is that it looks like the cylinder head seal is still intact.
  • Los Angeles, CA
BDJ
Offline zipster68
« Reply #2 on: August 08, 2016, 03:09:32 PM »
Thanks.  I thought that was a mounting point for engine to frame.  Didn't realize that was head mount to block.
-Ray
Offline zipster68
« Reply #3 on: August 08, 2016, 03:16:46 PM »
Look at it again.  Pretty sure that mounts engine to frame.  See pic, it's the top left bolt flange.
Offline riots100
« Reply #4 on: August 08, 2016, 03:27:12 PM »
Sorry, you're right.  So the cylinder head thing is not a factor, but the strength of the attachment point still is.  I'd try a weld first.
Nice valve cover.
  • Los Angeles, CA
BDJ
« Reply #5 on: August 08, 2016, 05:34:49 PM »
You also might be able to get a second hand head, price both and see.
Offline zipster68
« Reply #6 on: August 08, 2016, 07:25:36 PM »
that casting is the block
« Reply #7 on: August 08, 2016, 08:27:52 PM »
I do believe we're looking at damage right at the tip of the arrow in the attached diagram.
Offline zipster68
« Reply #8 on: August 08, 2016, 09:40:21 PM »
Ah, thanks.  So that's replaceable.
« Reply #9 on: August 08, 2016, 11:36:16 PM »
Replace it or weld it either way the head will have to come off. A good time to check valve clearances, cam chain and tensioners. This will give you an idea of which way to go.
Offline The Dude
« Reply #10 on: August 09, 2016, 01:04:45 AM »
Er hem,I have inadvertently riden Over 6000km with my other one(op side) simply missing.I was touring.I did not notice any handling issues....Ye haah.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #11 on: August 09, 2016, 11:07:28 AM »
JB weld!
Offline zipster68
« Reply #12 on: August 09, 2016, 12:12:49 PM »
Really not sure what to do.  I'm pretty sure that replacing the head is beyond my capability as a mechanic.  I'm also pretty sure that welding that flange up in place will destroy the head.  I'm also pretty sure that those frame points are load bearing and essential.  Any ideas before I declare this a loss?  Or is the remaining amount of aluminum meat enough to hold it together?
« Reply #13 on: August 09, 2016, 02:46:40 PM »
First, I want to observe that aluminum meat is a product destined for failure.
You've got options.
Do what Chaos suggests and be inspired by the Dude; but don't use the bike as a scrambler. Enjoy riding it in free air. I'm guessing that many here will never feel the need to swap an engine or even remove a cylinder head. You might be one of those; the JB Weld may be good enough, this engine may be good enough and a crack in its repair will show eventually show. Decide then. It's currently not a "track day" bike.
Ride the bike to several welders and show them the problem. Listen closely, compare what they say then decide.
If it appears that this bike is likely to require a lot of bucks to be roadworthy, just say "Feck it", sell it for whatever you can get and mark it off as a lesson learned; however, you be the one to show prospective buyers this defect. I made a couple of bad vehicle purchases early on when I knew nothing about engines, drivelines, brakes and body rot. You eventually learn about what you need to inspect and what you need to ask when buying used; otherwise, you buy from somebody with an enforceable warranty, or you buy new stock.
Someone will buy it and, if the rest of the bike is decent enough, maybe will install a reconditioned head on it then ride it to Tierra del Fuego; maybe even go there regardless of repair if they're desperate enough.
Offline The Dude
« Reply #14 on: August 09, 2016, 03:05:00 PM »
It looks bad.but..how did it get there?
Is there a complimentary bit of damage somewhere else that gave it the shove in the first place?Here may be your answer about safeness.
When I discovered my missing bolt I just thought I forgot to put it back last time....I just put it back and thought phew,I'm a twat but a lucky one.Before I discovered this missing bolt,I rode it like I stole it.
I think it's ridable and faced with the options,I'd just ride it and watch that area regularly.Afterall,there is plenty of meat for normal use,just not luck pushing crash diving stuff.The bolt threads into the frame lug.Pull it out and check the remaining aluminium is sound before riding off with a measure of confidence.
I hear Tierra del Fuego is the place to go for the ultimate test ride.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline zipster68
« Reply #15 on: August 09, 2016, 03:16:21 PM »
Thanks Laitch and Dude for the sage advice.  I thought the JB Weld comment was a joke, but if it's 50% as strong as aluminum, that's better than nothing.
-Ray
« Reply #16 on: August 09, 2016, 03:18:37 PM »
-Ray
It doesn't take the place of aluminum meat, but it spreads better.
Offline The Dude
« Reply #17 on: August 09, 2016, 03:20:11 PM »
JB weld,Good for hiding it but...I'd want full disclosure.Need to watch for "developments".
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline tagaz
« Reply #18 on: June 26, 2017, 12:30:21 PM »
posting in hopes of learning what option was chosen for this K head problem.
Curious as to what u decided to do about it.
Changing the head would be my choice.
All the other items listed to be done while head is being replaced are necessary maintenance anyway.
Vroom,
Troy
  • Kingman, AZ USA
  • 1985 K 100 RT
