Author Topic: K75S caferacer project - Hedgehog [Finished]  (Read 63484 times)
Re: K75S caferacer project - Hedgehog
« Reply #25 on: August 16, 2016, 09:38:53 PM »
I don't know how much of this I can take.
Offline TrueAce
« Reply #26 on: August 16, 2016, 10:48:38 PM »
There maybe some confusion about velocity air stacks because of some custom early motor K-bikes pics floating around which appear to have them. There are several project bikes which have used a single stack filter.
  • Florida
Online Laitch
« Reply #27 on: August 17, 2016, 12:22:02 AM »
We're all here to help you find out, bill.  :hehehe
Offline NickHeijman
« Reply #28 on: August 17, 2016, 06:43:40 AM »
I am  slightly confused, it sounds like you are replacing the throttle bodies with carburetors, if so what carburetors are you going to use, and I presume you will remove the fuel injectors. If you are just replacing the filter with three K&N filters where are you going to fit the air flow meter? :dunno
Hi Martin,
I looked up the internet and your correct, they called throttle body. My mistake.
I'm learning on the go, looking up thing and in the meantime i'm cleaning and cleaning.
@ Laitch & True Ace.
What about this bike then ?
http://www.pipeburn.com/home/2014/09/29/bmw-k-series-bell-kaff.html
Cannot find a propper discription of what they did to make it work without the air flow meter.
And this guy is just leaving the air flow meter out and testing with the flow.
http://www.k100-forum.com/t8933p50-big-block-k100
Quote"
may have to do similar  with the porting I have done
small bores flow well up high but big bores need a little more  length to stretch the induction stroke lower down in the rev range ...we already have the length and reduced size in the exhaust headers on the 2 valve models ...but have to do something with the intake I recon .
Furthermore I know I need to learn a lot and read a lot. So please correct me if i'm wrong :)
Cheers,
Nick
  • Breda
  • BMW K75S
Offline NickHeijman
« Reply #29 on: August 17, 2016, 06:45:45 AM »
And here we go with the tank.
Using 3,5 bar, the paint is ready hard so I have to be very patient to get all off properly.
See attached:
Cheers,
Nick
  • Breda
  • BMW K75S
Offline Revrdmark
« Reply #30 on: August 17, 2016, 10:44:59 AM »
On my last cafe build I used "orange stripper"  to strip the fuel tank. It works great  you just "glob it on" and let it sit and bubble the paint off. It's made from orange oil but won't take your skin off wreck your clothes or kill brain cells like the old furniture stripper/naipalm stuff I used to use. It smells like orange juice and cleans up with water.
  • Spokane WA
  • 87 K100
Online Laitch
« Reply #31 on: August 17, 2016, 10:55:54 AM »
Neither of those engines is a K75, Nick. What you missed reading in that thread are these two posts
This was a question about the air flow meter.
This was the response.
You should consider that when you don't seem to understand the differences between a carburated fuel system and fuel injection, or between one engine model and another, you probably will get some comments that don't make sense to you, or make statements that don't make sense to others. All the information you need to understand the differences is online already. It just takes patience to read them carefully—you seem to have patience. A simple way to see basic component differences is go to the MAX BMW parts fiche and look at the fuel preparation and other diagrams of the different models.
You seemed determined to make a great project out of this bike so you probably will. Good luck with it.
Offline Revrdmark
« Reply #32 on: August 17, 2016, 11:30:51 AM »
I hesitate to pipe in cause I am new to this bike myself and figuring it out as I go like you.
Two things. 1) this is my 4th cafe build and although pod filters look cool they are a PITA but that has been my experience with normal aspirated carbs. The rejetting and headache of getting a bike to run right made it easier for me to find a creative way to hide or relocate a stock air box. This is my first fuel injected project so I'll defer to those who know whether the "pool" of calm air a stock air box creates makes a difference for FI engines ( my inclination is it doesn't since you are not atomizing fuel with airflow and such like in carbs ???)
2) as I work on my K100 it seems there are two boxes. One with the air scoop and filter on the right side, and a big collection box (or whatever BMW calls it) on the left with the mass airflow sensor between the two. I have seen ... Somewhere (on this forum???) ... that someone turned the "collection box" 180 degrees so the MAS is on the out side of the bike with a 90 degree tube. ( kinda looked like the V-twin filters on early Buells) You could fabricate a smaller box with the pod filters and an opening for the MAS. But some how you would have to get the MAS behind the filters to get clean air  to it. Or maybe one big pod connected to the MAS like this
https://upload.wikimedia.org/wikipedia/commons/1/1b/Buell_M2_Cyclone_white_2000_front.jpg
Your milage may vary :-) just thinking out loud
  • Spokane WA
  • 87 K100
Offline NickHeijman
« Reply #33 on: August 17, 2016, 04:18:34 PM »
Hee Revrdmark,
Thanks for you kind reply, in the first time I wasn't aware of the FI system because i saw the other bikes first before I took all apart.
For now I will leave the stock air box and so for what it is and focus on the rest. But the idea which you send of the air filter 90 degrees would be a option for later on.
PS: This bike has also a different air filter.
Tomorrow I will finish sanding the tank and go to the paint shop to get a nice mat black hard paint of the tank and the wheels.
And also again do a lot of cleaning the frame and parts. Hopefully my parts will arrive soon to finish the front fork. After that the rear and exhaust are up the agenda.
Again thanks !
Cheers Nick
  • Breda
  • BMW K75S
« Reply #34 on: August 17, 2016, 04:38:49 PM »
The Pipeburn link to the Bell Kaff shows a highly highly modified K1100 frame strapped to a K1200 motor with a K1200 transmission and customised rear.  The early K1200s use Bosch Motronic  fuel injection.  Thus, the Bell Kaff can use velocity stacks since there is no air flow meter as in a Jetronic.  If you want to read more about Larry's bikes, especially this one, then go to his site - www.specialks.net - and click on the Media link.
Offline TrueAce
« Reply #35 on: August 17, 2016, 05:06:20 PM »
I recall a project bike from Alaska that placed a single cone filter off the back under the seat using a custom housing to hold the AFM, and using a lithium battery to replace stock so the space would be freed. Many folks strive for that open look by going to a lithium. What are you doing with the battery? I left the air box alone just for simplicity, but did ditch the snorkel.
  • Florida
Offline NickHeijman
« Reply #36 on: August 18, 2016, 01:44:01 AM »
Hi Ace,
Looks good !! Also you took off the "eyes" from the tank. (I dont know how to call them) most people leave them on even when they do a paint job.
The snorkel is off for now, I'm placing a mesh gasket where the snorkel schould be.
For the battery I want a really small one but not sure where to place it. I'm making a bike with a double seat to get the GF with me so I dont have space to get it in the seat. But I will figure something out.
Regarding the footpegs you just cut them off to a single one?
Cheers,
Nick
  • Breda
  • BMW K75S
Offline TrueAce
« Reply #37 on: August 18, 2016, 09:33:58 AM »
Correct, and cut down the seat pan, but you could configure for a passenger, just don't cut too much off the rear subframe. My battery is lithium hidden in the modified relay box, after removing superfluous relays......tight squeeze. And yes all good builds should eliminate the useless tank eyes! Keep the pics coming.
  • Florida
Offline NickHeijman
« Reply #38 on: August 18, 2016, 09:40:49 AM »
Oh yeah I think I will cut off some off the foot pegs. Regardingt removing the relays. Could you advise me, because it sounds like the best option so far _o_
Here are some pic's of the tank, sand blasted. I kept the original paint on the bottom because this paint is really hard and good. Therefor no one would see it because the tank will be painted completely.
Taking of the eyes and so of the tank will be done later on.
Cheers,
Nick
  • Breda
  • BMW K75S
Offline TrueAce
« Reply #39 on: August 18, 2016, 09:55:47 AM »
Good job on your tank. I used a chemical remover that got 80% and then lots of wet sanding. Be sure to insulate the bottom of the tank from the engine heat. On the relays, because my bike is a scrambler, I did not keep turn signals, horn, flasher, load shed,etc that were not essential, thereby freeing up space for the lithium. Very tight squeeze. Instead, you might mount a small box for a lithium where the stock.big battery sits, most folks won't notice it laying on its side, way easier than the relay box. Be very careful with cutting off your tank eyes, used a dremel.on mine
  • Florida
Offline NickHeijman
« Reply #40 on: August 18, 2016, 10:03:21 AM »
Thanks !
Well when I didn't got the option to sand blast the paint of I would do it the same.
Ah a scambler, in my case I need to keep the signal lights, horn, flash etc.. so thats not a option. I think I will go for a very small flat battery to fit under the new seat max hight 5-7cm. I will search the i-net and post some battery's up here.
Cheers,
Nick
  • Breda
  • BMW K75S
Offline NickHeijman
« Reply #41 on: August 18, 2016, 12:26:07 PM »
Hi guys,
Today I tried to put back the fuel "bar/rail" but cant get it done :(
I put grease on the injector top o-rings and inside the cups but cant get them on. I mean I dont want to force anything or brake the injectors.
Any tips or tricks
Cheers,
Nick
  • Breda
  • BMW K75S
« Reply #42 on: August 18, 2016, 12:38:34 PM »
You did it backwards. Install the injectors onto the rail, then install the rail + injectors into the engine.
« Reply #43 on: August 18, 2016, 01:35:18 PM »
Don't forget to blow out the injector recesses with compressed air and clean up any debris before removing the injectors from the block.  You don't want road grit and rocks in your intake system.
Offline Revrdmark
« Reply #44 on: August 18, 2016, 05:05:05 PM »
I had same issue. Much easier with them attached to the rail and putting all 4 in. I also sprayed the rubber o rings with WD-40 made them slick and "pop" into the sockets much easier. The WD-40 will evaporate but even if you get it in combustion chamber it won't hurt anything just smoke a bit for a while.
  • Spokane WA
  • 87 K100
Offline NickHeijman
« Reply #45 on: August 18, 2016, 05:09:33 PM »
Great thanks guys I will try that.
How to get the injectors out properly, I tried to pull them out but I think a need a quite force to do it?
Maybe there is some under pressure in the chamber during the compression or so
Thanks a lot
cheers,
Nick
  • Breda
  • BMW K75S
« Reply #46 on: August 18, 2016, 06:02:25 PM »
It can sometimes take force to extract them.  They are only held in place with O-rings, similar to the ones you can see on the tops of the injectors.  Try a little more force inline with the injector; it's possible its age and the O-ring is just very stuck.
Online Laitch
« Reply #47 on: August 18, 2016, 07:29:39 PM »
Call on some friends to hold down the bike, Nick, and have a party doing it!
Offline NickHeijman
« Reply #48 on: August 19, 2016, 03:41:03 AM »
Hahahahahahaha Laitch, you'v made my day for so far.
Will try it this weekend to get them out properly. (Wish me luck)
Got some MAT BLACK paint for the tank, fuel rail, wheels, swing arm and so on. YEAHHHH
Pictures of all will follow soon.
Cheers, Nick
  • Breda
  • BMW K75S
Offline NickHeijman
« Reply #49 on: August 19, 2016, 04:16:38 AM »
Hi Guys,
Regarding the battery, I found this one on the internet and i'm curious if some has some expirience with it. I used the search button but nothing came up on ultrabatt.
http://www.ultrabatt.com/batteries
They are powerfull and tiny, great to fit betweet the frame under the seat :)
What is the minimum power the K75 needs to start up, I found: 12 VOLT, 30 AH ?
Cheers,
Nick
  • Breda
  • BMW K75S
