Wow, the tank is off, the seat is off. What did they do to your bike? Did they do something to your gas tank?
They did a lot of work. Won't find out the price until later this morning when I pick it up. I was going to have them do the clutch spline as well but the tech called me and said considering the condition of the rear drive splines, the grease and the fact that there are no issues shifting up or down on the bike that he would wait until the next tire change to pull the transmission and do them. Time will tell if that was the good choice.
Here's what they did:
Engine oil and filter change.
Brake fluid flush.
New Spiegler brake lines
Clutch cable replacement
Coolant flush.
Tire change.
Pennsylvania State Motorcycle Inspection.
Final drive oil change.
Transmission oil change.
Rear spline lubrication.
Swing arm boot replacement.
Check and replace if necessary any hoses or rubber parts he notices
And whatever else emerges during the maintenance.
Figure this will all cost thirty or forty dollars. Right??
