MOTOBRICK.COM BMW K75 K100 K1 K1100
Please login or register.
Advanced search
Pages: [1]   Go Down
Author Topic: BMW K75 Specifications  (Read 11926 times)
frankenduck
  • Forum Adrninistrator
  • Offline Offline
« on: May 14, 2011, 12:29:43 AM »
BMW K75
BMW K75
Production
Start of Production1986
End of Production1996
Number Sold18.485
Price11.990,- DM
Engine
Motor Typefour-stroke, horizontal three-cylinder in-line engine, liquid-cooled
Bore x Stroke67 x 70 mm
Cubic Capacity740 ccm
Max Power75 hp (55 KW) at 8500 rpm
Max Torque68 Nm at 6750 rpm
Compression Ratio11.0 : 1
Valves per Cylinder2
Valve ControlDOHC, using drive chain and cup tappets
Carburation Systemelectronic injection, Bosch LE-Jetronic
Engine Lubricationwet sump
Power transmission
Clutchdry single plate
Number of Gears5
Gear Selectiondog-type gearbox (ratchet foot lever)
Gear Ratios4.50 / 2.96 / 2.30 / 1.88 / 1.67 :1
Rear Wheel Ratio1 : 3.20 or 1 : 3.36
Bevel / Crownwheel10 / 32 teeth or 11 / 37
Electrical system
Ignitionelectronic ignition, Bosch Le-Jetronic
Alternator12 V 460 W
Starter0.7 kW
Spark PlugsBosch XR 5 DC, Beru 12-5 DU, Champion A 85 YC
Chassis
Type of Frametubular space frame, engine serving as load-bearing component
Front Suspensiontelescopic fork with hydraulic shock absorber
Rear SuspensionBMW Monolever swinging arm
Spring Travel front/rear185 / 114 mm7.28" / 4.49"
Rims front2.50-18 MT H 2
Rims rear2.75-18 MT H 2
Tyres front100/90-18 56 H
Tyres rear120/90-18 56
Brakes frontdual-disc brake 285 mm dia11.22"
Brakes rearsimplex drum brake 200 mm dia or single disc brake 285 mm dia7.78" / 11.22"
Dimensions / Weights
Length x Width x Height2220 x 900 x 1300 mm87.4"(7' 3.4") x 35.4"(2' 11.4") x 51.2"(4' 3.2")
Wheel Base1516 mm59.7"(4' 11.7")
Tank Capacity21 l5.55 Gal - 4.62 Imp Gal
Unladen Weight, full Tank227 kg500 lb
Max permissible Weight450 kg992 lb
Ground Clearance175 mm6.9"
Fuel Consumption4,2 l/100 km (at constant 90 kph)56.0 mpg (@ 60 mph)
Top Speed200 kph124 mph
Acceleration0-100 kph         4,6 sec0-60 mph
Power and torque:
93 K11LT
94 K11RS- "Kato"
86-97 K75F (K75/100/1100 Frankenbrick)
86 K75C w/ paralever, high perf. cams,TURBO!
91 K1
86 custom K100
and 2 more
IBA #17739 (SS1K, BBG, 50CC)
Buy parts HERE
Pages: [1]   Go Up
