Author Topic: K75 will not start  (Read 4013 times)
Offline keith g
K75 will not start
« on: January 16, 2014, 11:28:56 AM »
ok........i replaced the fuel pipes from the regulator to the tank and the return,did not disconnect the MAF,just left it hanging,got good pressure from the pump......got sparks.......still won't start.......any ideas welcome......
  • UK
  • 1985 K75c
Offline K75RT Keith
Re: K75 will not start
« Reply #1 on: January 16, 2014, 02:23:31 PM »
Try reseating the connector on the computer, then check for voltage at the injectors
1990 K75RT
« Reply #2 on: January 17, 2014, 12:06:04 AM »
I would like to add that voltage is only present at the injectors when you press the starter button..........
or the engine is running.
But as your fuel pump is running you probably also got voltage at the injectors....powered from the same relay.
The signal to the injectors is on the ground side.
Offline keith g
« Reply #3 on: January 17, 2014, 01:07:40 AM »
ok.....thanks guys i'll look at that today ...cheers :2thumbup:
  • UK
  • 1985 K75c
Offline keith g
« Reply #4 on: January 17, 2014, 05:16:07 AM »
OK.......between you guys and Frankenduck's repair PDF......i have to confess...i'm an idiot...!!!
i cross connected the fuel pipes........DUHHHHHH!!!!!!!!!!!
  • UK
  • 1985 K75c
