MOTOBRICK.COM - BMW K75 K100 K1 K1100 Forum
Please login or register.
Advanced search
...i think the owners at beemerboneyard have become billionaires just off jacked up shipping to australia...
Pages: [1]   Go Down
Author Topic: BMW K1 Specifications  (Read 1032 times)
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« on: May 14, 2011, 01:16:54 AM »
BMW K1
BMW K1
Production
Start of Production1988
End of Production1993
Number Sold6.921
Price20.200,- DM
Engine
Motor Typefour-stroke, horizontal four-cylinder in-line engine, liquid-cooled
Bore x Stroke67 x 70 mm
Cubic Capacity987 ccm
Max Power100 hp (74 KW) at 8000 rpm
Max Torque100 Nm at 6750 rpm
Compression Ratio11.0 : 1
Valves per Cylinder4
Valve ControlDOHC, using drive chain and cup tappets
Carburation Systemelectronic injection, Bosch Motronic
Engine Lubricationwet sump
Power transmission
Clutchdry single plate
Number of Gears5
Gear Selectiondog-type gearbox (ratchet foot lever)
Gear Ratios   4.50 / 2.96 / 2.30 / 1.88 / 1.61 :1
Rear Wheel Ratio1 : 2.75
Bevel / Crownwheel12 / 33 teeth
Electrical system
Ignition   electronic ignition, Bosch Motronic
Alternator12 V 460 W
Starter0.7 kW
Spark PlugsBosch XR 5 DC, Beru 12 R-5 DU
Chassis
Type of Frametubular space frame, engine serving as load-bearing component
Front Suspensiontelescopic fork with hydraulic shock absorber
Rear SuspensionBMW Paralever swinging arm
Spring Travel front/rear135 / 140 mm5.32" / 5.51"
Rims front3.50-17 MT H 2
Rims rear4.50-18 MT H 2
Tyres front120/70-ZR 17
Tyres rear160/60-ZR 18
Brakes frontdual-disc brake 305 mm dia11.22"
Brakes rearsingle disc brake 285 mm dia12.01"
Dimensions / Weights
Length x Width x Height2230 x 875 x 1210 mm87.8"(7' 3.8") x 34.4"(2' 10.4") x 47.6"(3' 11.6")
Wheel Base1565 mm61.6"(5' 1.6")
Tank Capacity22 l5.81 Gal - 4.84 Imp Gal
Unladen Weight, full Tank234 kg516 lb
Max permissible Weight480 kg1,058 lb
Ground Clearance140 mm5.5"
Fuel Consumption4,2 l/100 km (at constant 90 kph)56.0 mpg (@ 60 mph)
Top Speed240 kph149 mph
Acceleration0-100 kph         3,9 sec0-60 mph
Power and torque:
Pages: [1]   Go Up
