Author Topic: Electrical ~ Tronics ~ Controls ~ Instruments ~ Lighting  (Read 4377 times)
« on: April 01, 2018, 08:43:38 AM »
JETRONIC ~ MOTRONIC
Motronic Fault Codes
Setting L-Jetronic CO mixture (2V Ks)
Setting L-Jetronic Injectors without an Exhaust Gas Analyzer
LIGHTING
Headlight Bulb Design
Electro Flasher for Flashing Brake Lights
LED Parking Light Retrofit by The Mighty Gryphoon
Headlight Relays by the frankendrunk
Workaround for failed headlight high beam switch
Bulb Monitor Unit (BMU) Wiring Pinout
The Bulb Monitor Unit (BMU) and LEDs
Curing Hyperflashing Turn Signals
How to add 4-way(hazard) flashers to a K bike
RELAY BOX
BMW Relays 101
Relay Box Layouts
STARTER
Starter Simple BackSpin Cleaning
Starter Maintenance (Video)
starter cleaning by healthy...
ALTRNATOR
Replacing the alternator "monkey nutz"
50A Alternator Rebuild
SIDE STAND SWITCH
Bypassing the side stand switch on a K100RS4V, K1 or K1100
K1100 Sidestand Switch Bypass
SPEEDO ~ TACHO ~ DASH
K Bike Dash Switches & Graphic Inserts
GPI Electrical by rbm
K-Bike Instrument Cluster Exploded Drawings
Odometer Fix
K75 K100 K1 K1100 Bulb Monitoring Unit
Instrument Cluster Pinouts & Wire Colors
Instrument Cluster Backlighting Issues
Retrofit a choke light to a 91+ K75 or 2V K100
Speedometer Calibration
Fix a flaky or inoperative K bike speedometer
Mysteries of the speedo pod wiring
Gear Position Indicator (GPI)
MotoScope Speedo Mod
Gear Indicator Mod
K-Bike Tachometer Fix
Transmission Gear Position Switch Troubleshooting
Replacement Odometer Gears
Emulate the "start in neutral" function of a K bike instrument cluster
HANDLEBAR SWITCHES
16 Valve Ignition Switch Overhaul by filmcamera
Frankenduck's Switch Rehabilitation Clinic
K75 K100 K1 K1100 Ignition Switch Cleaning
Combination Switches
BMW Switch Rehab
Sticky headlight switch
Replacing a right or left combination switch
BMW Handlebar Radio Remote Pinout
Curing sloppy clutch and brake levers
HEATED GRIPS
Aftermarket heated grips with an OEM switch
Variable Heated Grips01
Variable Heated Grips02
Variable Heated Grips03
Symtec Heated Grips
AUDIOVOX CRUISE CONTROL
Installing an Audiovox CCS-100 Cruise Control on a K Bike
K75 K100 Electronic Cruise Control Install
EVERYTHING ELSE
Battery Recommendations
Battery Tender Recommendation
Adding A Manual Radiator Fan Switch to a 4 Valve K Bike
Renewing Heat Sink Compound on Ignition Module (Applies only to 93 and earlier 4V K bikes.)
Dumb Dumb x 1 View List
