Author Topic: Headlight Relays  (Read 30132 times)
Headlight Relays
« on: May 02, 2011, 02:08:54 PM »
Lots of people add headlight relays to their K bikes. Why?
1) The stock wiring for BMW headlights is rather wimpy.  It suffices but given the small gauge of the wire, voltage is lost in the circuit.  By upgrading to thicker wire (like 14 gauge or even 12) the amount of voltage lost is much less.  More voltage to your headlight means more light.
2) Since, from the factory, the headlight does not use relays this means that all of the current travels through the contacts in the high beam/low beam switch on your left handlebar.  Every time you switch between beams a little spark is created.  Over time and many uses, these little sparks degrade the switch contacts and eventually cause the switch to fail.  When you use relays, the current flowing through the switch is reduced to next to nothing and this increases the longevity of your headlight switch.
3) Once you've upgraded the wiring and added relays you can switch to a higher power bulb.  If you tried that with the stock wiring chances are you'd melt the insulation off of the wires and have some potentially serious problems.  (I run a 90/100W Xenon H4 headlight bulb which is a massive improvment over the stock halogen H4 bulb.)
You have two options when adding headlight relays:
1) Buy a kit from Jim Davis at Eastern Beaver.  If you're not into chasing electrons or just don't feel like making your own, Jim's kits are handy, fairly priced and used by lots of K bike owners.
Jim's page of H4 headlight relays:
http://www.easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html
2) "Roll your own"
You can find a couple of write-ups on this over at the IBMWR K Bike Tech Pages:
http://www.ibmwr.org/ktech.shtml
You can  either use your existing headlight plug and cut the wires very close to the headlight socket or you can get a new H4 headlight socket and connect your higher gauge wiring to the socket. This is really the "right" way to do things. (I get mine from Jim Davis.)
I'd also recommend using Posi-Taps to tap into the headlight wires from your switch.  Jim Davis has those too.  You'll need two of the PT1800 type.  (I do not recommend using ScotchLocks or T-taps - both have a tendency to fail or cut through the wire you're tapping into.)
Here's a how to wire headlight relays. Note that the wires indicated by thicker lines are the ones where you should use 12 or 14 gauge wiring:
Re: Headlight Relays
« Reply #1 on: January 08, 2012, 06:39:31 AM »
By the way, on many K bikes you'll also notice a white nylon single wire connector in your relay box.  If this is connected then both your high and low beams will be powered when the high beam is on.  Once you've added relays it's probably a good idea to disconnect this as having both beams illuminated on high isn't really necessary.
« Reply #2 on: January 08, 2012, 08:48:20 AM »
By the way, on many K bikes you'll also notice a white nylon single wire connector in your relay box.  If this is connected then both your high and low beams will be powered when the high beam is on......
When did they start doing this? :hmm:
1997 R1100RT ZC62149
« Reply #3 on: January 08, 2012, 01:32:57 PM »
By the way, on many K bikes you'll also notice a white nylon single wire connector in your relay box.  If this is connected then both your high and lows beams will be powered when the high beam is on......
I think it's only found on the earlier wiring harnesses on the 2V bikes.
« Reply #4 on: January 08, 2012, 04:18:02 PM »
That explains why I haven't seen in on either of my bikes.....
Thanks.
Offline wmax351
« Reply #5 on: May 05, 2012, 03:53:58 AM »
Interesting... I just bought a 130/100 H/L bulb, so I probably don't want to have both on at the same time. Currently, my bike only does one on at a time.
http://www.amazon.com/gp/product/B000H0OSMY/ref=oh_details_o01_s01_i00
  • Albuquerque, NM
Bikes:
« Reply #6 on: May 05, 2012, 10:45:35 AM »
You'll light up the world with that baby. You'll love it.
Offline wmax351
« Reply #7 on: May 05, 2012, 04:14:41 PM »
Quote
Should work nicely. I like the selective yellow too: makes you stand out.
Got a pair of some cheapo, harbor freight fog lights I modified for inverted use. Stick those on with a couple of 55 watt h1 bulbs, and I am in business.
  • Albuquerque, NM
Bikes:
« Reply #8 on: May 05, 2012, 04:23:01 PM »
I've been running the
CATZ H4 Gold iridium Ion Yellow All Weather bulb for a while. Like it. Low watt with high output. Seems to be as advertised but light output can be very subjective. :deal: :yes
Offline wmax351
« Reply #9 on: May 05, 2012, 06:39:03 PM »
I usually prefer to just go with the high watt=high output bulbs. I have a 50 amp alternator for a reason :)
  • Albuquerque, NM
Bikes:
« Reply #10 on: May 05, 2012, 06:59:00 PM »
I had one of the 130's before this one and this is comparable. Only yellow. Now he needs to come out with a 130/100 with the output of a 160/130. I'd have to be all over that. :biggrin:
Offline wmax351
« Reply #11 on: May 05, 2012, 08:24:05 PM »
At a certain point, it makes more sense to just add additional lights. Redundancy, in addition to more light output, that can be better aimed.
I saw an alternator mod on ADVrider that had some aussie set up an R100gs with a belt driven car alternator to run aircraft landing lights. I think they are something like 200 watts each. 800 watts total.
http://www.advrider.com/forums/showthread.php?t=225223&highlight=alternator
  • Albuquerque, NM
Bikes:
Offline Snowy
« Reply #12 on: May 06, 2012, 05:25:06 AM »
On my K1100RS I use an Eastern Beaver relay with Philips Xtreme bulbs at the standard rating 55/60w. I have also fitted a pair of Hella FF50 spot lights mounted under the mirrors using a pair of mounts I got a couple of years ago from a member here. I made up a loom with relay, fuse etc and thats powered from the relay box. I find this set up really good and has built in redundancy. Its not as good as the set up I have on the GSA which uses the same spots but with 50w HID conversions fitted. As the standard lamp also has a 50w HID fitted, when I turn these on its like switching the sun on. Truly awesome lighting and since I ride a lot at night and have quite a few deer and other critters where I live its absolutely necessary to have good lights.
  • Marlborough, UK
« Reply #13 on: December 30, 2012, 10:37:02 AM »
http://easternbeaver.com/Main/Products/H4_Kits/h4_kits.html
That URL has changed, here's a good one: http://www.easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html
(Busy poring over his pages, trying to figure out what's best for me to buy with my Xmas $$$...)
« Reply #14 on: December 30, 2012, 01:52:33 PM »
Thanks for the heads up. I updated the original post.
Offline Shiny
« Reply #15 on: August 11, 2016, 06:23:27 AM »
I'm electrically hopeless, which kit would be best for my K75?
  • Northern Virginia
  • BMW K75T
« Reply #16 on: August 11, 2016, 07:28:25 AM »
It sounds right now like no kit would be best for your bike until you feel more hopeful. :giggles
Even the basic H4 Single In Shell plug into old connector, fuse holder-battery connect model requires attention to detail regarding wrapping to prevent problems.
Offline xpc316e
« Reply #17 on: August 25, 2016, 09:50:57 AM »
If you are going to fit relays and a high-wattage headlamp bulb, do not forget to fit a ceramic bulb holder. They cost very little, but high-wattage bulbs give out enough heat to melt a normal plastic holder.
Offline lefthander
« Reply #18 on: May 28, 2020, 09:13:45 PM »
 Hello,
 I have a 1992 k75 low seat model. I installed an Eastern Beaver relay kit to boost headlight brightness. I purchased the kit with the auxilary light capability. This is a 2 part inquiry.
1st, the question if anyone has been able to install aux. lights on a bike of my type. There is one red wire for the lights that comes out of the kit. It has a spade? fitting on it. My auxilary lights both have two wires coming out of them each. Not sure how to make the magic happen electrically with this setup. I don't know how to wire it up to work. Basically I'm an electrically challenged person.
 Part two: After I installed the relay kit I then tested it with success! However, when I disconnect the negative terminal from the battery the digital clock is still on and I can turn the key and headlight comes on. I'm kind of lost at this point and don't want to do damage to the electrical system for the bike. Any help with this is greatly appreciated.
 Side note: on my k75 I purchased a ceramic H4 female plug to fit in the light bucket or globe as advised. The type of H4 female plug needed is one that the wires come out at a 90 degree angle from the side like the oem plug. I tried one where the wires come directly out of the back and it would not fit. Maybe someone else has had success with this type but I did not. Thank you
  • Savannah GA
  • 1992 k75, 2002 1150gs
« Reply #19 on: May 29, 2020, 12:01:27 AM »
...when I disconnect the negative terminal from the battery the digital clock is still on and I can turn the key and headlight comes on.
You need to have an A:B:C or a B:C dry chemical fire extinguisher within reach when you involve yourself in wiring at your level of understanding. You've got problems and shouldn't want to join the ranks of members who slowed the modification process by introduction of electrical fires.
Yes. Many K75 owners have installed driving lights.
I'd be disassembling what I did until I restored the correct relationship of the battery ground connection to the headlight and clock operation so I could understand where I went wrong.
The wire with the spade fitting attaches to a switch to operate the driving lights. The page for that relay setup at Eastern Beaver tells us so.
Each auxiliary light has a wire for 12V and a wire for ground connection. That is why there are two wires on each light.
You should clearly explain exactly where every connection has been made and its source.
« Reply #20 on: April 01, 2022, 03:18:42 PM »
If you're adding headlight relays then I recommend using a CERAMIC H4 socket.  They won't melt like plastic ones can.
Offline alexg
« Reply #21 on: April 16, 2022, 04:18:01 PM »
I've added the Eastern Beaver relay to decrease the load through the switch, but then bought a LED lamp, which does the same thing and has twice the brilliance. If I had to do it over again, I would go LED only and use standard wiring.
  • Michigan
Alex G.
« Reply #22 on: April 16, 2022, 06:23:01 PM »
I kind of agree. I always do headlight relays but on a K75 I rehabbed last year I skipped the headlight relays since I knew I'd be going with an LED bulb that is 40W on high vs 60W of a halogen bulb. It certainly can't hurt to have HL relays though.
