MOTOBRICK.COM => Welcome To Motobrick.Com => Topic started by: zipster68 on August 27, 2019, 02:48:24 PM
gaitors or no gaitors?
Lots of dust and crap on the roads where I live so gaitors every time for me.
my vote is neither...
i have had to replace many seals before i started replacing the bushings when i did the seals... now the motos with new bushings never gotts seals again... i do run traxxion dynamics (http://traxxion.com/product/fork-guard-kit/) and do use a homemade sealmate (http://sealmate.net/) and flush and change my suspension fluid often...
traxxion 100% positive...
I pack heavy silicone grease between the seal and dust cover and change the grease every 1-2 years depending on how much dust is encountered.
When changing the grease I also do a run around with a home made seal mate. I last changed the seals probably twenty years ago. However if I rode a lot of dusty or gravel roads I'd definitely be running gaiters as well.
I'll have to try the Traxxion fork guard; always used some 35mm film negatives to clean the seals.
Gaitors can add a retro look to the bike, which is nice in some cases.
Gaitors for me, both bikes. Lots of bugs..
I installed gaiters on mine, too. I ride at least a hundred miles on gravel roads per week.
Gaiters. The less shiny stuff the better.
My sentiments exactly.
And they keep the crap out of the seals. Only thing is that I need to remove the dust seals to put them on because of the tight clearance between the brace and the lower fork tube.
That is one handsome motorcycle.
