Exactly the info I was looking for. Thank you, gentlemen.
I will probably take the advice to add a small fuse around 15--20amps in line w the m-unit, even though it's probably not necessary.
I purchased an LED battery indicator for the B+ to match my oil pressure and water temp indicators, and will add a small resistor(50 Ohm because a 3w bulb on a 12v circuit draws 48 Ohms) in serial w the battery indicator light to get sufficient load to excite the alternator.
I'll also give that referenced post a read through.
Much appreciation!!!
Edit: After reading through the "Quick fix, circuit breaker, save your brick from burning post", I see that the primary concern people have is old wiring, or wiring that has been rubbing against various parts of the bike. Im less worried about a fuse now as ALL of my wiring to the components mentioned in the post are brand new, sheathed in added wire protection, and fixed such that they cannot rub in any significant way that they are likely to suffer any physical damage. My wiring is also fairly simple compared to the oem system and also pretty exposed and easy to inspect for wear. That said, it is the starter relay that seemed to the of highest concern in that post, and a fuse in that line is less ideal than a manual breaker. The problem with starter relays(stuck/welding closed) appear to be caused by low voltage, and thus amperes generated by low voltage wouldnt likely set off any fuse big enough to withstand actually starting the bike. I will probably do the manual cut-off to the starter option since it appears to be the more logical thing to do. THe m.unit itself, per the literature, doesnt require any fusing as it has all fusing built in, so fusing before the m.unit seems pointless...and wouldnt protect the starter system at all in the event of a stuck relay since the m.unit only feeds the electromagnet to trigger the relay, but wont stop the load passing through a stuck switch.
If someone sees something wrong with this logic, please do alert me to my mistake.
Edit 2: Per ChatGPT, the 50Ohm resistor must be wired in parallel in order to work with an led bulb to generate sufficient load on the alternator exciter circuit.
