TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: fivespeedsquirrel on July 18, 2018, 01:35:57 PM
I have a chance to buy one of the increasingly rare Schneider Flip-A-Lever throttle locks, but I am trying to figure out whether this will fit my naked 1995 K75. I found a comment at the bottom of this thread, which seems to indicate the BMW friction screw will not fit my bike:
http://www.motobrick.com/index.php?topic=3054.0
I know that the BMW friction screw and Flip-A-Lever are not exactly the same in design, but I am still trying to figure out if there is clearance for the Flip-A-Lever to fit on my bike. So I have looked at my throttle housing, and also many other throttle housings online, and they all look like they have the mirror stem nut in the same place, so I can't see how the Flip-A-Lever would fit any of the K75 models. It's possible the skinny stem of the Flip-A-Lever just squeezes past the mirror nut...? I am not sure how the throttle assembly between different versions of the K75 would be different. Can anyone enlighten me?
It does seem to indicate that but I have a naked '95 K75 with OEM mirrors and it has an OEM throttle screw that works appropriately; nothing is in its way.
This is your second thread concerning these blasted throttle controls. Martin has a thread here with photos explaining how to make a Flip-a-Lever style throttle control all your own. Here's a link to a link about them (http://www.motobrick.com/index.php/topic,11403.msg99773.html#msg99773).
Thank you for the input. Don't worry, this is my last thread on the subject :) I am trying to search as much as I can before asking questions. I am not opposed to Martin's method, but I am treating that as Opn #2 for now.
used to use a flipalever... it will fit if you have the threaded hole... i still have one in a box in the basement... you want it...
Returning to the handlebar throttle response screw and mirror stem/nut relationship, in this photo of my K75's assemblies the mirror stem and nut are indicated by the green arrow, the screw by the red arrow. The threaded stem is above the screw with a few millimeters of clearance.
(http://www.motobrick.com/gallery/1/1601-180718180412.jpeg)
i gotts the threaded hole on top... and on bottom like laitch... bottom hole works with flipalever butts is better on top me thinks...
not sure if this other source still is making them but,
https://advrider.com/index.php?threads/anyone-know-where-to-get-a-schneiders-flip-a-lever.415580/
not the same... schneiders screws into the hole and puts pressure on the mechanizium from the inside... not on some chunk of chromium on the outside...
schneider was sued cause some lazy a-hole wadded it up cause he said he could not articulate the lever... f-ing lazy a-hole poachers and false report filers are gonna f-it up for everybody...
, so I can't see how the Flip-A-Lever would fit any of the K75 models. It's possible the skinny stem of the Flip-A-Lever just squeezes past the mirror nut...? Can anyone enlighten me?
If you aren't enlightened enough yet attached is a photo of the FAL from the link mlytle provided in Reply #6. Using the OEM screw, the screw is turned until its nylon tip provides the desired friction. In the FAL, a moving nylon rod within the screw provides the friction based on the position of the lever. With lower handlebars on a K75, the FAL mounted beneath the handlebar could hit the tank.
(http://www.motobrick.com/gallery/1/1601-190718090623.jpeg)
With lower handlebars on a K75, the FAL mounted beneath the handlebar WILL hit the tank and feck up the paint.
Fixed it for you. Been there, done that.
That must have been when you were a callow and fevered youth dismissing the need to analyze new installations before using them. :giggles
If you say so...
