TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: JPaganel on August 23, 2019, 04:19:03 PM
So, I got a blip on the temp light. And when I parked, I saw a drip at the bottom of the water pump. Checked coolant, it's kinda low.
I'm guessing the pump seal is going.
I've been searching threads on that, but a lot of it is dead links. Anyway, doesn't seem like rocket science.
Do I have this right?
Drain coolant and oil
Unscrew pump from motor
Unscrew impeller
Pop out the shaft
Pop put the seals
Pop in new ones
Put it back together and refill.
That's a bit of an oversimplification. But yes, that's it. Plenty of online videos showing the procedure.
That can result from overheating due to a coolant loss from somewhere else. Maybe the radiator cap, then the overflow level is misleading, especially if the level hasn't been rising after a ride and lowered in the morning. Or there are bubbles after a ride but not a second ride shortly after.
