Author Topic: 1987 K100LT Resto - from bits to brick  (Read 66439 times)
Offline FlatSix
Re: 1987 K100LT Resto - from bits to brick
« Reply #25 on: July 10, 2019, 12:04:27 PM »
Not much done this week as I was out of town on vacation.
But I do have a question for the experts.  How does one go about installing these footpeg springs without losing an eye or messing up my freshly painted brackets?  Is there a trick to it?
Should be able to pick up my freshly powdercoated wheels this week.
Dave
  • TX
  • K100LT
Dave in TX
1987 K100LT project
1971 Triumph Bonneville -sold to a couple young female tattoo artists
« Reply #26 on: July 10, 2019, 07:45:06 PM »
How does one go about installing these footpeg springs without losing an eye . . .
Wear safety glasses.
Offline FlatSix
« Reply #27 on: July 11, 2019, 09:14:53 AM »
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #28 on: July 11, 2019, 10:24:31 AM »
¡Salud! :_+:
Offline FlatSix
« Reply #29 on: July 17, 2019, 12:40:12 PM »
Update:
I finally got the footpeg springs installed correctly.  Sure its a simple task and should only take a few minutes but one of the drawbacks of not disassembling the parts is that I don’t intuitively know how they go back together.  So let’s just say it took me a few extra minutes to figure out that there is a hole in the bottom of the footpeg for the spring to go in.  :yikes:
Got some parts in including the signal minder which I thought would be a good addition.  Still waiting on some parts and I don’t want to remove the engine covers and redo them until some new bolts come in from overseas.  That has taken nearly a month but should be here soon.
I also modded the BMU to hopefully work with LED lights.  My plan if I can figure it out is to use as many LED’s as possible on the bike.  I got all LED’s on my Triumph and it works for the most part except the headlight flickers a little.  But it still works.  Hopefully I can get a better quality one and figure out how to prevent it for the K.
That’s all for now.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #30 on: July 17, 2019, 01:20:20 PM »
I finally got the footpeg springs installed correctly.  . . . So let’s just say it took me a few extra minutes to figure out that there is a hole in the bottom of the footpeg for the spring to go in.
Perhaps you could go into more detail about how you installed the foot pegs to help the next person who is assembling them from a box of parts. Thanks for the update.
« Reply #31 on: July 17, 2019, 01:38:35 PM »
I wanna see a picture of the M&M's Max sent you.
Actually, right now I want the M&M's.
Offline alabrew
« Reply #32 on: July 17, 2019, 02:01:22 PM »
"Got some parts in including the signal minder which I thought would be a good addition."
Why do you need this? It should already have factory self canceling turn signals, or am I missing something...
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Online The Mighty Gryphon
« Reply #33 on: July 17, 2019, 02:32:20 PM »
My last couple orders didn't include M&M's.  Got a bunch of MaxBMW stickers instead. :dunno
« Reply #34 on: July 17, 2019, 03:05:06 PM »
You also got free shipping, right? The M&Ms were nice but I like the free shipping better.
Offline FlatSix
« Reply #35 on: July 17, 2019, 04:43:59 PM »
Good idea.  I will take a picture and follow up when I get home.
The M&M’s don’t last long around my house!
I’m not familiar enough with the BMW flashers yet to answer that however, it does also flash the signal indicators along with the brakes when you hit them.
Also, I forgot to mention still no wheels from the powdercoater.  I think I was right on not leaving the frame with him as well.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
Offline alabrew
« Reply #36 on: July 17, 2019, 07:15:19 PM »
They are set up to cancel based on time and distance, which ever is longer. About 10 seconds on the interstate, about 500 ft at slower speeds.
Also:
2005 K1200LT
1979 R65
Offline DJEwen
« Reply #37 on: July 18, 2019, 03:27:24 AM »
Update:
That’s all for now.
I feel your pain Dave, driving the old pins out initially then rebuilding everything after powder coat were two of the hardest tasks on my build. Well done.
  • Scotland
Offline FlatSix
« Reply #38 on: July 20, 2019, 07:21:23 PM »
Looks like I might have an issue.
Checking valve clearances and I have what appears to be a tight valve on #3 exhaust.  I rotated the engine to double check and same result.  Should I attempt to fix this or should I wait until I run the bike and then recheck?
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #39 on: July 20, 2019, 10:32:43 PM »
Your moto's engine has a tight valve. The purpose of checking valve clearances is to determine if they meet specifications and set them to meet specifications if they don't. You must understand procedure thoroughly, work carefully and have confidence. Set the valve's clearance so it meets the spec: it's tight. Running the engine more won't set it correctly for you.
Others have run their clearance and shim calculations by us here and you could do that, too.
« Reply #40 on: July 20, 2019, 10:51:56 PM »
Pull the shim and check for the number printed on it, then get the next thinner one.  That will get you back in spec.
« Reply #41 on: July 20, 2019, 11:22:39 PM »
I don't think so. This is an exhaust valve. Shims are manufactured in 0.05 increments and the valve's current clearance is 0.10 out of spec.
Offline SpecialK
« Reply #42 on: July 21, 2019, 04:24:52 PM »
If it is 0.10mm out of spec, can't he just get the next two sizes down? So if his current shim is say 2.20mm he can get the 2.10mm shim? Never done it myself but I see the shims come 2.00mm - 3.00mm in 0.05 increments as Laitch says so it would seem to be the solution. Correct me if I'm missing something.
  • Wappingers Falls, New York
  • 1987 K100RS
"The first to present his case seems right, till another comes forward and questions him". Proverbs 18:17
« Reply #43 on: July 21, 2019, 04:34:03 PM »
If it is 0.10mm out of spec, can't he just get the next two sizes down? Correct me if I'm missing something.
You're missing what I wrote, that is, 0.05 + 0.05 = 0.10 the amount needed to return the clearance to specification. If you've reasoned that a shim 0.10 less in thickness should be substituted, you are correct.
If the size isn't on the current shim, it will need measurement. A micrometer will provide the most accuracy.
Offline FlatSix
« Reply #44 on: July 21, 2019, 06:31:39 PM »
Thank you all for the advice.  I ordered the tools from Ken Lively and looks like I will be adjusting the clearance once the tools come in and I can remove the current shim.  And I was so close, it was the very last valve I checked and I thought I was going to be good.  But alas that's how it goes.
Did give me a little time to work on repainting the engine covers and my guess is I won't be able to button up the engine for a few weeks now. In the meantime I will start working on something else.  Perhaps the brake calipers which need a complete rebuild on all of them.
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #45 on: July 21, 2019, 06:51:06 PM »
Rejoice that it goes with replacing just shims instead of buckets like on the 16V models. Shims less costly than OEM are available here.
Offline FlatSix
« Reply #46 on: July 21, 2019, 08:26:38 PM »
Thanks for the link!
  • TX
  • K100LT
Dave in TX
1987 K100LT project
« Reply #47 on: July 21, 2019, 08:35:01 PM »
When you figure out what you need, ask here. Someone might have one in their old parts bucket.
Also, note that many old Yamahas use the same size shim, which opens up more possible sources.
« Reply #48 on: July 21, 2019, 11:24:07 PM »
When you get it out, post the size.  I have a bunch of them laying in my tool chest.  One of them might work for you.
Offline FlatSix
« Reply #49 on: July 22, 2019, 09:35:02 AM »
Thank you very much!
The tools are on order so I took advantage of the break to work on refinishing the timing chain, camshaft and crankshaft covers.  I guess it is true that the obstacle is the way, the impediment to action enhances action.
In case anyone needs to order the same or a few other tools Ken was quick to respond.  His info is below:
Polepenhollow Valve Tools and Clutch Pilots
pelopenhollow@yahoo.com
The covers required some sanding, careful masking the paint and clear high temp semi-gloss.  I think they came out OK but not perfect.  A little dust flew into the garage and shows in the picture but they were dry and cured at that point.
More parts arrived at the end of last week including the two new tires.  Powdercoater says the wheels are ready so I will be picking them up soon.  We shall see!
  • TX
  • K100LT
Dave in TX
1987 K100LT project
