Author Topic: Brake light not working on K100  (Read 3852 times)
Offline jande9
« on: September 01, 2019, 01:02:25 PM »
Hi Everybody,
I have a very early K100, sn4196.  I've owned the bike for 6 years and it is completely stock.
The brake light has stopped working.  It is a separate bulb, single filament.
The bulb is good, tested on a battery.
There is about 6v at the socket constantly, which goes to 12v when the brake lever is squeezed.
The foot brake switch doesn't do anything.
The console isn't original and the bulb monitoring light is not on ever, even when starting.  The neutral light and gear indicator has never worked.  The console has the pinstripes which appeared about 1986.
I have thoroughly cleaned the contacts at the socket with sandpaper.
So, I don't get how there can be voltage but the bulb doesn't light.
Thanks for any insight because I'm stumped.
Jan
Offline bocutter Ed
Re: Brake light not working on K100
« Reply #1 on: September 01, 2019, 01:07:30 PM »
There's a good chance the wire from the foot brake switch is pinched. I'd check that first.
  • Toronto, Canada
Offline jande9
« Reply #2 on: September 03, 2019, 10:07:26 PM »
I traced the wire to the brake light switch by the pedal and it seems clear.
I'm thinking it may be a dirty connector because it does show 12 volts but not enough current will flow to light the lamp.
The contacts in the socket are aluminum which can be an issue but I scraped and cleaned them and that didn't help.
Jan
Offline daveson
« Reply #3 on: September 04, 2019, 07:52:33 AM »
Yep, it maybe a dirty connector.
You got 12V but maybe not enough Amps.  Check the fuses are clean and tight.  Use a test light both sides of connectors and switches.  Or maybe better, just go ahead and clean them all anyway.
You might have better luck using an early model instrument cluster on your early model brick,  for your instrument lights
  • Victoria, Australia
« Reply #4 on: September 04, 2019, 09:18:46 AM »
 :thisplacewhack
Offline jande9
« Reply #5 on: September 04, 2019, 12:50:44 PM »
id getts a 6v bulb...
Hmmm.  My manual says its 12v.
Jan
Offline Scott
« Reply #6 on: September 04, 2019, 01:06:20 PM »
Maybe a poor ground from the socket?  Have you tried a temporary (clip lead) ground to the socket to see it the bulb lights with the extra ground?  Might rule a ground issue, in or out.
  • SoCal
  • bmw R100r, bmw k75, hondapotamus G/W, XT 500 enduro
Offline jande9
« Reply #7 on: September 04, 2019, 08:25:15 PM »
I tried that too.  The brale light shares a ground with the tail light, and the tail light works.   I think I will have to get at the bulb monitoring relay.
Jan
« Reply #8 on: September 04, 2019, 09:11:51 PM »
You might be interested in bypassing that relay for purposes of diagnosis, or permanently.
http://www.motobrick.com/index.php?topic=906.0
Offline beemuker
« Reply #9 on: September 05, 2019, 10:26:04 AM »
Jan
If you are going to take the tank off, and the 100 has the same grounds under there that the 75 has, wouldn't hurt to clean the grounds that bolt to the frame under the tank. That was causing my turn signal whack.I missed it as there are a lot of wires covering it up.
  • Panama City, FL
Offline jande9
« Reply #10 on: September 06, 2019, 06:31:20 PM »
So I popped the tank and had a look at the bulb monitoring unit.  It looks spotless and the diodes all seemed to work the way they are supposed to.  I tried jumpering the connectors in the socket as per that great link (Thanks!) and it didn't help as the brake light shows 12 volts when the handle is pulled but the light doesn't illuminate.
Hmmm.  I really dislike chasing electrical gremlins.
Offline Scott
« Reply #11 on: September 06, 2019, 09:41:08 PM »
Have you tried a new bulb, to rule something else out?  Seems like it has to work.  Keep at it.
  • SoCal
Offline alabrew
« Reply #12 on: September 07, 2019, 01:00:32 PM »
Going to have to have a look at mine too, it is flashing on and off on my bumpy road. Thought it was the bulbs, but changed both of them. Looks like I'll be doing some contact cleaning this weekend.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Offline jande9
« Reply #13 on: September 07, 2019, 01:07:23 PM »
It was the first thing I tried even though the old bulb worked when connected straight to a battery.
I know, it does have to work.  I'm perplexed.
« Reply #14 on: September 07, 2019, 01:33:08 PM »
If there is 12V on the meter but the lamp won't light, something is limiting current under demand. Try changing the fuse dedicated to that circuit and clean the fuse's pins and receiver sockets with emery cloth and contact cleaner. You haven't mentioned you have done that. Fuse defects can be hidden.
« Reply #15 on: September 07, 2019, 04:26:05 PM »
Alabrew a while ago a mate noticed that my brake light was flashing while leaving his property. It ended up being a non OEM brake spring on the rear master cylinder. The one fitted was too light so I just replaced it with a heavier one. The entry to his property is full of lumps and bumps along with exposed tree roots.
Offline jande9
« Reply #16 on: September 07, 2019, 09:59:37 PM »
I was going over the wiring to the foot switch to check yet again that nothing was pinched, and I pulled the connector to see if that helped, and it did.  Without the footswitch in the circuit the lamp lights when squeezing the front brakes so at least I feel OK about riding it now.  The wire is clear and not damaged so I don't understand why that happened.
Thanks for everyone who pitched in their thoughts.
Jan
1983 K100.
Offline Stumpy
« Reply #17 on: September 08, 2019, 05:57:02 AM »
Have you switched the wires, try plugging the brake light socket to the taillight if the bulb works then the holder is working . Same for the taillight to brake light, then you will know if it is the switch wires or the condition of the connectors.
  • Croydon
  • K100RT
Offline alabrew
« Reply #18 on: September 10, 2019, 06:27:51 PM »
Thanks Martin, I’ll look it over. It was flashing on smooth roads before I changed the bulbs.
Also:
2005 K1200LT
1979 R65
