Great to see an update, sorry to hear about the paint. Maybe you can try airbrushing the paint where it's damaged for a smooth finish?
Do you mind sharing the model of the ignition key unit that you fit into the frame? Having it small and hidden is great!I'm thinking it's a universal 2-position switch?
Looking forward to seeing all the progress
It's just under the throttle bodies, so I'm just going to cover things up, spray it with etching primer, then brush on caliper paint and finish of with 2k clear coat.
This key switch:
http://www.ebay.com/itm/282406644853Not great quality, but it's ok for me since I'm just using it as a backup.
Finally got to take it for a test ride the other day and it was way over my expectations. Engine and gearbox was smooth as silk and handling and brakes were great.
To do before I can call it "finished" (for now):
- Fabricate the seat
- Paint tank and cowl again
- Fabricate a registration plate holder
- Sync the TBs
Also I'm planning to use a solenoid connected to a thermostat switch to pull the choke (or rather 'idle control') lever under a set engine temperature. I'm using a universal trunk release solenoid that pulls 15mm, which should be enough to pull it halfway. I don't see the need to be able to pull it all the way, since I'm not planning to use this bike in cold weather.
