Confession time:
The reason for my 3 week hiatus is that I couldn't get the brakes bled myself so I took it to my nearest BMW motorcycle mechanic, which is about 45 minutes away. I asked them to bleed the brakes and do an overall inspection of the bike. Turns out that both of my master cylinders needed to be replaced. They gave me an estimate, and even though I know I could have done it for far less, I let them do it because I didn't want to do it wrong. I also asked them for an estimate to replace then gear position indicator, which I know isn't working. They called me on Tuesday and told me the bike is ready to be picked up. Yay! I drive out there to pick it up and I asked "so what did you find wrong and are the brakes good to go?" They tell me that the brakes are still a little softer than they'd like to see them because the ABS pressure modulator might be going bad. They recommended getting rid of the abs system altogether, which is what I'll do. Hopefully I can recoup so if my money by selling the control module and new brake hoses I just bought. They never gave me an estimate to replace the gpi and didn't do much of an overall inspection aside from telling me my fork seals are leaking and my stanchions need replacing (which I already knew). It was an $1100 lesson in why so many K owners do a lot of their own repairs & maintenance.
The good news is that I finally got to take this baby for a ride. Wow, what an incredible feeling! She's a heavy one but nothing I couldn't handle. I rode around my neighborhood learning how to shift gears and use the controls. I never went over 30mph since the brakes aren't as they should be but the new hose is on its way for the front and I won't need to replace anything for the rear.
As for the fork seals & stanchions, I'm torn between replacing them and doing a front end swap. I really want to do a swap but I have a bunch of money into the brake rebuild, new tire, and powder coating. Decisions, decisions.
