This week I installed my new brake discs and pads. When I bled the brakes they felt fine but when I went for a brief test ride a problem appeared and I am not sure exactly what is causing it.
When the bike is still the front brake lever works pretty much as normal, depressing with a little bite until about half way through the travel when the bite gets progressively stringer and when I start off it does as well. However as soon as I get over about 3 mph the lever will not move at all but the brakes are not on. If I bring the bike to a stop using the rear brake the lever suddenly starts moving again. When it is moving very slowly the brakes seem to work, obviously not much braking force but since they are brand new discs and brand new pads I assume that is fairly normal.
The only issue I had of any sort installing the pads was that I got the cheap chinese pads and the top of the shoulders were too tight a fit to able to get them installed properly so I had to grind back maybe 1/2 mm to they are snug against the bolts but I can still get the main pin in.
Here is a picture of the old pads with an arrow showing where I had to grind back a little
I also noticed a line around the very outer edge of one of the new discs
Something seems to be stopping the ads from moving when the wheel is moving but I am not sure what I should do to fix the issue.
BTW my test ride was no more than 300 meters, I live at the top of a very steep hill and did not want to go all the way down with just the rear brake so I turned around pretty much as soon as the issue showed up.
Any suggestions would be very welcome.
