Author Topic: K75S caferacer project - Hedgehog  (Read 27400 times)
Offline NickHeijman
Re: K75S caferacer project - Hedgehog
« Reply #100 on: August 27, 2018, 08:37:29 AM »
The centerstand is already gone.
Will check this week if I will swap it to the other side.
Thanks for the suggestion  :clap:
  • Breda
  • BMW K75S
Offline NickHeijman
« Reply #101 on: August 31, 2018, 08:18:46 AM »
Hi All,
Here is an update on the bike.
- Frame painted (again hahaha)
- Engine painted
- Cable harnas made ready
- Frame mounted on the engine, cardan and driveshaft checked and re-lubed.
- Gearbox and engine oil flushed and renewed.
- Wheels mounted
- Rear shock mounted
- Made a tray under the tank to fit all the relays in. (picture will follow)
Cheers,
Nick
  • Breda
  • BMW K75S
« Reply #102 on: August 31, 2018, 08:50:46 AM »
kerb fealor
  • :usa#1 i parks my 96 eleven hundert rs motobrick in dodge county cheezconsin :usa#1
Offline Skunky
Re: K75S caferacer project - Hedgehog - * UPDATE *
« Reply #103 on: August 31, 2018, 05:53:13 PM »
Hi,
I don't pretend to be a structural engineer. But that seems a long way without cross frame support. Considering the original frame was hooped with two other welded cross members under the seat. Could be a bit twisty on the bends. Especially with the rear suspension on one side of the frame.
  • Derby GB
  • BMW K100lt
90 K100lt
Triumph Thruxton 900
Honda CB400F
Offline NickHeijman
« Reply #104 on: August 31, 2018, 06:11:44 PM »
Hi,
Have you seen the new design of the bike?
  • Breda
  • BMW K75S
Offline Skunky
« Reply #105 on: August 31, 2018, 11:38:59 PM »
YES!
  • Derby GB
  • BMW K100lt
90 K100lt
Honda CB400F
Offline NickHeijman
« Reply #106 on: September 09, 2018, 06:23:31 AM »
Getting closer to the DGR and nearly finished the bike.
Got the harnass in place and still need to rewire the batt since the new location request longer cables.
Made the mounts on the rearframe for the seat and also started the leather for the seat.
All fluids are refreshed, relays are in a box under the tank, airflowsensor relocated and the exhaust is done.
First kick and run was a huge succes. Just one click, no choke and running as a BMM K !!!
Complete rear is finished now, rear sets work, rearbrake, seat mounting, licenceplate location and rear/brakelight.
Front is nearly done, headlight is in place, fork rebuild and now awaiting the new brakelines to arrive and being installed.
Took some pictures during the process, see below the result.
  • Breda
  • BMW K75S
Offline NickHeijman
« Reply #107 on: September 12, 2018, 05:25:59 AM »
Only a few things left to do.
Licenceplate light
Seat
Install the batt
Ready for DGR 2018
  • Breda
  • BMW K75S
« Reply #108 on: September 12, 2018, 08:52:45 AM »
Huge change on the steering geometry up front . . . looks a little scary . . .
Offline NickHeijman
« Reply #109 on: September 12, 2018, 09:38:01 AM »
I droped the fronkt for 5cms, another build from close to me did the same.
Drove the bike and the handling was still very nice, the corners are a bit wider now, still a nice handling and control on the bike.
If afterwards the handling isnt so nice, just lift the front up and where good to go.
  • Breda
  • BMW K75S
