Inge K
Does that wiring sound right, and that should eliminate the Gear sensor and clutch switch as I have not hooked up the 12V feed wire.
Thanks for the reply. Sorry for the delay, time difference gets me everytime.
I did clean the contacts on the starter and block.
I have been chasing my tail everywhere.
I have tried shorting the starter relay terminal across the terminals and still nothing.
I have tried disconnecting the battery and hooking directly to the starter motor...nothing.
Just now I have taken the starter motor off the bike and hooked the battery up.
I am now getting a constant 12Volts to the starter motor wire with the ignition on even WITHOUT pushing the start button.
Of coarse the relay is reading the same at both points..
So something is terribly wrong..relay?? It is not constantly clicking but may be stuck or corroded??? That has me puzzled for the moment
I would be excited but the test hooking the starter motor up to direct power should have given me cranking.
I have pulled the sprag clutch out for repairs...so maybe I have missed something mechanically as well.
I have put the bike in gear and the motor is not seized...I will continue searching.
Hopefully we are getting closer.
Please continue with your ideas...I am open to suggestions and will try anything suggested.
Cheers people
