Author Topic: What Did You Did To Your Motobrick Today ?  (Read 1115558 times)
« Reply #3600 on: April 06, 2019, 04:26:20 PM »
greetings..
3800 stumble = throttle sync... be sure to do it with fresh no corn ethy... and 4 or 5 bottles of techron afterwards of course...
  • :usa#1 i parks my 96 eleven hundert rs motobrick in dodge county cheezconsin :usa#1
Offline MIbrick
« Reply #3601 on: April 06, 2019, 06:46:07 PM »
greetings..
Throttle sync is on my list of things to do, guess it gets moved to the top. Now to remember where I stored that SyncPro thing. I'm sure it was someplace I'd never forget. :\
  • Michigan
  • 1986 K100RS (ohne Tragkorb)
Offline duckhawk
  • duckhawk
« Reply #3602 on: April 07, 2019, 12:58:11 PM »
Lubed the spline with my own grease and molybdenum powder mixture yesterday. They still had grease on them from 6k miles ago.
How do they look after the clean up?
  • Cowconsin
  • 95 K75
"Go soothingly on the grease mud as there lurk the skid devil."
 In Clancy's Boots: The Greatest Ever Round-The-World Motorbike Adventure.
 - Geoff Hill
« Reply #3603 on: April 07, 2019, 01:04:33 PM »
not good... you better find some new ones... i will come down to fetch those so they dont end up in a landfill...
j io
« Reply #3604 on: April 07, 2019, 08:39:08 PM »
They look okay, but there is some visible wear.  How many miles?
  • '94 K75RT Mystic Red, '91K100RS White/Blue
'91 K100RS "Moby Brick Too
Offline Supershooter
« Reply #3605 on: April 07, 2019, 10:20:29 PM »
Yesterday, I was reading about testing the temp relay that controls the fan and idiot light. I understood it to say that I could turn the key on, then use a jumper wire to bypass the relay by connecting two wires in the plug to make the light turn on or fan run. I used a test light to find power in the plug and then used the jumper to get power to A2 and A3
In my effort to light the light and run the fan neither happened.
Either I've got wiring issues or I didn't understand the directions. I'm leaning towards I did it wrong, because I have had the light come on when it did overheat.
Thoughts
Supershooter
  • Liberty Township, O'brien County, Iowa
  • 85 K100 RT
Offline duckhawk
  • duckhawk
« Reply #3606 on: April 08, 2019, 09:42:03 AM »
27K . The last 7 have been solo country road rides. Now my son his learning on the bike. I am sure that will accelerate the wear. I don't see a problem re-lubing at more frequent intervals. The bike only gets 1500 miles a year max.
  • Cowconsin
  • 95 K75
 - Geoff Hill
Offline Idonthaveaclue
  • Veni, vidi, vici
« Reply #3607 on: April 09, 2019, 07:55:20 PM »
Brand new Odyssey PC680. And WOW, she fires up much better.
However there is an oily mess behind the throttle bodies. I'm assuming a breather is leaking. Guess I should look up how to pull the tank!
  • 87' K75S | 16' H-D Road Glide Special
1987 K75S
« Reply #3608 on: April 10, 2019, 08:48:54 AM »
Before you do that, have a look at the Z-pipe.
  • Veni, vidi, vici
« Reply #3609 on: April 10, 2019, 05:05:13 PM »
Thanks for the heads up! Seems to be a good place to start as they are so common!
1987 K75S
Offline natalena
« Reply #3610 on: April 13, 2019, 07:51:24 AM »
In a word, "spectacular."
  • East of Joshua Tree
  • 1987 K75s #0919
On Holy Quest seeking Techron equivalent for splines.
Offline MIbrick
« Reply #3611 on: April 13, 2019, 09:33:16 PM »
Today I gazed longingly at my flying brick, pained by the knowledge that tomorrow it will be in the mid 30s with snow and rain. Maybe I should pull out that water gauge that keeps shorting the fuse and see if the replacement gauge solves the problem.
  • Michigan
Offline BlitzenGruv
  • My first BMW. Been riding old British forever..
« Reply #3612 on: April 14, 2019, 10:21:41 PM »
I hadn't planned to do anything to the Brick today, but doodoo happens.
High winds here today, and guess which bike blew over. Of course, the heavy one which I cannot pick up!
Guess I should have taken the cover off. Those things act like a parachute once the wind gets under them.
Since I retired all my neighbors are old women, no help there. I've watched all those videos of women picking up Harleys, but that method just doesn't work for me on this machine.
I need to build a cage for this bike and strap it to the walls.
  • Music City
  • '92 K100rs, 16v, '71 BSA Lightning, '72 Triumph Bonneville, '72 Triumph Trident
You say I'm schizophrenic, but I don't believe we are.
« Reply #3613 on: April 14, 2019, 10:24:16 PM »
Was it on the side stand or center stand?
  • 1995 K75T 68,000 miles
Offline BlitzenGruv
« Reply #3614 on: April 14, 2019, 10:30:54 PM »
It was on the side stand. The first, and last, time I used the center stand it fell over when I took it off the stand. I will not use the center stand without a spotter.
  • Music City
  • Forum Moderator
« Reply #3615 on: April 14, 2019, 10:37:26 PM »
Today I replaced batteries.... The one I had in the '97 was from late 2012(early 2013) and it failed on me last week, the one I had in the '95 was from early 2014. It was still starting the bike but I could tell it was getting weak, even with using a tender. So I replaced both.
Ride safe.
1997 K1100LT 0302488
Garmin StreetPilot 2820
Garmin Zumo 550
« Reply #3616 on: April 14, 2019, 10:45:53 PM »
Were you astride it or beside it when you rolled it off the stand? Was the moto parked on pavement when the wind tackled it this time?
Offline BlitzenGruv
« Reply #3617 on: April 14, 2019, 11:03:33 PM »
I took it off the stand following the directions in the BMW shop manual, standing next to it handle in right hand, handlebar grip in left. It immediately fell away from me. I do take my British bikes off the center stand while seated, but even the Trident weighs only 450 lbs..
Yes, the bike was parked on pavement in the carport.
I have a fiberglass repair kit. I guess there's a reason I haven't used it yet. That side of the fairing is doomed to be ugly.
  • Music City
Online Martin
« Reply #3618 on: April 15, 2019, 02:18:27 AM »
BG beware of the rubber grip on the lift handle. A person who shall remain nameless was lifting his newly acquired Brick on to the centre stand and ended up with a rubber handle in his hand without the requisite bike attached. He learnt a valuable lesson and subsequently glued it on. I He has had no problem since.
Offline RobP
« Reply #3619 on: April 15, 2019, 12:16:03 PM »
FWIW - When I roll the bike off the center stand I grab both handlebar grips, then as it moves forward I pull slightly towards myself to ensure it doesn't go over away from me - it's too hard to recover balance if'n it would go away from me, vs toward me.
I use both handlebar grips when rolling backward to put it on the stand, and then only move my right land to the lift lever after I feel both 'feet' on the centerstand are engaged with the ground.   I brace my right knee under the lift handle / right hand and use my ankle/ lower leg muscles for most of the lift effort.
I don't like the side stand, the bike leans too far over and seems sketchy if the ground is soft or slightly uneven.   I need to get around to welding a 1/2" steel riser plate to the bottom pad of the side stand.
  • Driftwood, TX
  • 1985 K100RS
Offline BlitzenGruv
« Reply #3620 on: April 15, 2019, 12:52:29 PM »
Pretty much all side stands make the bike lean too far. All mine have their own short 2x4 on which to plant the stand. And I carry a small stand pad when I go camping.
Perhaps if the Brick had not been on the 2x4 it would have leaned over far enough to resist the wind gust?
  • Music City
Offline mw074
« Reply #3621 on: April 15, 2019, 01:01:12 PM »
 I straighten the side stands in a press to get the bike to sit correctly when it is deployed. Always helps to use a thin plate carried in the top box or under the seat.
  • Michigan
« Reply #3622 on: April 15, 2019, 01:46:38 PM »
On soft ground I always use the side stand. I carry a plastic puck in my tank bag that I put under the stand when I deploy it. One time, the moto tipped over when I used the center stand on soft terrain. Once was enough.
Offline BlitzenGruv
« Reply #3623 on: April 16, 2019, 12:58:28 AM »
I use an old BSA points cover as a pad on soft ground. It's maybe 3" diameter alloy.
FWIW: British side stands have a bit larger contact area with the ground.
  • Music City
Offline daveson
« Reply #3624 on: April 16, 2019, 06:46:53 AM »
Took it out on a spin today, first time in a year. I sometimes wonder if I should get this one registered instead of my main bike, but even more so after today. Because I'm old (56) quite a few people have told me my arms would ache after a while of riding it (I'm thinking riding a bike is a way to get rid of aches) The previous owner, who lived in a coastal town, and owned it for eight years, had not started it in five, since he got a bike eligible for club rego. Surprisingly inside the tank was perfect except the two lower points were leaky. He said he had never put ethanol blend in it.
Feels like way more power than my RT, I spose its because of less weight. Way more fun. Not as far forward leaning as i remembered.
  • Victoria, Australia
  • Current; 1985 bmw k100rt VIN 0090567 ('84 k100RT, 87 k100RT, '89 k100rt, '91k75s, '96 Kawasaki Vulcan 1500) Past; V Star 650, Kawasaki klx250, Yamaha tt250
