Author Topic: What Did You Did To Your Motobrick Today ?  (Read 1903551 times)
« Reply #3375 on: October 20, 2018, 02:43:41 PM »
You're not allowed to park by dumpsters or graffiti with an unlooped brick.
Besides, I don't reside in an urban combat zone and don't have the ambition to travel into the city to be in one.  I suppose I could find a local brick wall or railroad track.
Hey, outta my way, Douchebags, I got a cafe racer I need to photograph.
http://www.rockandrollconfidential.com/hall/hall_detail.php?dd_keyid=369
Offline John Lang
  • John Lang
« Reply #3376 on: October 20, 2018, 07:01:05 PM »
When I discovered I needed a new valve spacer my local friend and fellow Brick owner volunteered to make the appropriate tool. He has a garage full of strange, to me, metalworking machines.
I also discovered that the PO had over-torqued a valve cover bolt, cracking the soft yet brittle camshaft bearing cap into which it fastens. It would no longer hold the bolt.
My attempt to 'fix' it by inserting a Heli-coil resulted in the female thread body disintegrating into several pieces. The camshaft bearing cap is not a separate part but integral to the cylinder head; the bearings are line-bored. My machinist friend sprang into action. First, he Krazy-glued the pieces together and took careful measurements. He then transformed the end of a steel rod into a ring that fits snugly over the broken threads. Finally, we re-tapped for another Heli-coil and it held. The valve cover is back on and all bolts are correctly torqued.
Moral: get yourself a helpful buddy with a garage full of strange lathes, presses and metal saws. And always use a torque wrench!
  • Ottawa, ON Canada
  • 1987 K75C
Offline jakgieger
  • itinerant farmer
« Reply #3377 on: October 20, 2018, 07:35:39 PM »
That is a nice looking SE :bmwsmile ;)
  • Kansas USA
  • 1989 K100rs se
« Reply #3378 on: October 20, 2018, 07:37:51 PM »
@ John Lang, Very nicely done!!! :clap:
Offline Supershooter
« Reply #3379 on: October 22, 2018, 10:19:57 PM »
I took off work and rode it! All my clients were busy with grain harvest, so I ran the Brick to test previous work I had done. The bike ran without issue for a couple hours this afternoon, slowly building confidence it may run well going forward.
Supershooter
  • Liberty Township, O'brien County, Iowa
  • 85 K100 RT
« Reply #3380 on: October 23, 2018, 03:47:49 PM »
Supershooter
 :clap:  It's been a long road getting to this point, here's hoping the road ahead is much, much longer.
« Reply #3381 on: October 23, 2018, 04:23:50 PM »
:yippee:
Offline Filmcamera
« Reply #3382 on: November 02, 2018, 06:41:39 PM »
Today I finally got round to replacing the fuel pump.  It had not failed but as the photos show was a McGiver that had been worrying me for a while.  I got a new filter and vibration damper from Euro Moto Electrics and a new pump from Ebay and feel better now. I still have the old one as a back up...  I think it also explains why I kept running out of gas so early, the bottom of the old pump was about an inch and a half higher than the new one so it got starved much earlier, when there was still gas in the tank.
  • San Jose, Costa Rica
Poserbricker
« Reply #3383 on: November 02, 2018, 10:27:53 PM »
Supershooter
i did that yesterday too!  sunny and 75...on 01NOV in Virginia.  actually spent about an hour running all the traps on an MSF school lot with noone around.  great fun.....and practice.
Offline natalena
« Reply #3384 on: November 05, 2018, 06:06:43 PM »
Head gasket on the Xterra blew over the weekend, so with a dental apt this AM, I figured "great, I'll ride the brick." It was pouring rain, but a warm rain :) Fun riding, except for the many soccer-mom's and "I'm too sexy for my car" jerks running up super close and swerving back into the right lane too quickly after the pass throwing rooster tails. :( I finally teamed up with a slower car at 55mph that I could follow and keep in the line of sight of drivers coming up from behind.
  • MST
Texas catheters ROCK!
Offline rdivy725
« Reply #3385 on: November 06, 2018, 03:19:10 AM »
I decided to change the coolant and oil(and filter) on my recently purchased K75.The front radiator shroud came off way easier than I thought. Got the sick green coolant out and added proper BMW blue. The fuel lines looked good until I moved the fuel tank back to access the radiator cap. The outer shell of the pressure line was split! All new hoses and clamps are on the way from EME, along with spark plugs. I also found the tank vent hose to the crankcase was disconnected-it looks like when the tank was off previously, it was misrouted and had too much tension on it. A simple reroute should keep it in place. With the tank off it was a good time to inspect all the wiring/connections and everything else looks in good shape.
  • Greater Pittsburgh Area
  • 1994 K75, 2002 R1150R, 2013 Triumph Thunderbird
1994 K75
2002 R1150R
Past: 71 R75/5
« Reply #3386 on: November 06, 2018, 06:46:35 PM »
Just finished up on Ilsa's annual pampering which included all the maintenance stuff along with some minor repairs like the right side heated grip.
Spline lube was the last thing I did.
* DSCN3341.JPG (22.8 kB . 609x576 - viewed 488 times)
* DSCN3343.JPG (24.83 kB . 765x576 - viewed 447 times)
* DSCN3349.JPG (38.13 kB . 618x576 - viewed 452 times)
Not too bad for 93,000 miles.
A little cosmetics on the fairing and she'll be ready for another year and the 100,000 mile mark.
Offline holmesy
« Reply #3387 on: November 07, 2018, 07:59:22 AM »
IMG20181103131023" border="0 IMG20181103131017" border="0 IMG20181103131014" border="0
  • Melbourne, Australia
  • 1995 K1100LT, 2005 SV650S
Offline holmesy
« Reply #3388 on: November 07, 2018, 08:00:39 AM »
^^^ I have angered the K bike Gods
« Reply #3389 on: November 07, 2018, 09:29:19 AM »
You'll no doubt enjoy their wrath. :giggles
« Reply #3390 on: November 07, 2018, 02:36:55 PM »
you are doomed, I see vast electrical problems in your future, caused by incurring the wrath of the gods. You need to appease them with a appropriate sacrifice. :beehive:
Offline twowheeledgator
« Reply #3391 on: November 09, 2018, 02:08:33 PM »
* 5FBE0126-2E89-4ED6-990B-F7801E255023.jpeg (78.22 kB . 768x576 - viewed 460 times)
Right front rotor.  One pad was as thick as a new one and the other was down to the metal.
Cracked it open. Pistons looked good.  Cleaned, replaced the rubber and the bolts.  New pads.  Bled. Back in business.  It was very easy.  Started with a air to blow the piston and slowly cranked it up so I didn’t shoot it across the room.
Everything  looked pretty good.  Not sure why the outer piston was not working.  Will see in a few months how it wears.  The other caliper was wearing evenly.  I feel wrong not taking them apart and cleaning and replacing the seals so they are both done at the same time.  For now I will just leave well enough alone.
  • Floridy
  • '86 K75C, '95 R1100GS, '13 Bonnie Scrambler
« Reply #3392 on: November 09, 2018, 02:53:49 PM »
Did you buy a rebuild kit? Whose?   Thanks, Bill
« Reply #3393 on: November 09, 2018, 03:05:35 PM »
Just finished the annual maintenance festivities on Cheetos the Big Banana Slug.  Except for a few things like a spline lube and compression check on Moby Brick Too all that's left is a little Bondo and paint work on Ilsa's fairing to have everybody ready for next year's riding season.  YeeHah!!!
Offline holmesy
« Reply #3394 on: November 11, 2018, 04:32:54 AM »
I also see vast electrical problems. One of the main reasons the lunch box is staying until I’ve ironed out all the other bugs and get it riding right.
I’ve seen all the threads on the wiring and it will be an effort. I’ve got 12 months to get it done proper, but might pay the premium and get one of those magic boxes and a new motogadget
« Reply #3395 on: November 12, 2018, 09:55:22 PM »
changed the engine oil...and installed new grips.
ProGrip 714's.  had to trim off the "rings" on the inside of the left one to accomodate the SENA comms remote.
« Reply #3396 on: November 12, 2018, 10:11:01 PM »
Pro Grip 714 grips are my favorite.  I have them on my K100 and they feel great.  Soft, and give a great feel, make turning the throttle very easy.
« Reply #3397 on: November 13, 2018, 07:55:56 AM »
agree!  we already have them on the K1100RS and i have another set going on the K13S this week.   they are slightly larger diameter than the stock ones, but not as big as stock with grip puppies on top.
« Reply #3398 on: November 13, 2018, 08:05:22 AM »
Those grips were on my used K75 when I bought it. Now I know what they are. Thanks for the photo. They've been durable.
Offline mw074
« Reply #3399 on: November 13, 2018, 08:44:21 AM »
 I liked the fit, finish, and feel of the ProGrip gel grips. However, the older ones that I ran would crack when riding in below freezing temperatures. Not sure if the newer ones do.
  • Michigan
