MOTOBRICK.COM - BMW K75 K100 K1 K1100 Forum
Please login or register.
Advanced search
...i think the owners at beemerboneyard have become billionaires just off jacked up shipping to australia...
Pages: [1]   Go Down
Author Topic: Dr. L. Duck Hubbard explains: Splientology  (Read 3481 times)
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« on: May 26, 2011, 02:11:52 PM »
First off, what the heck are "splines?"  The dictionary definition is: Any of a series of projections on a shaft that fit into slots on a corresponding shaft, enabling both to rotate together.
In laymans terms that means some long gears on one rotating part that are paired with and fit into some corresponding grooves on another rotating part in order to transmit power.
From front to back 2 valve K bikes have three sets of splines:
- Clutch/transmission
- Transmission/drive shaft
- Drive shaft/final drive
4 valve K bikes have four sets of splines:
- Transmission/ front half of drive shaft
- Front half of drive shaft/rear half of drive shaft
- Rear half of drive shaft/final drive
CLUTCH/TRANSMISSION INPUT SPLINES: This set of splines transmits power from the engine via the clutch to the transmission.
Clutch friction plate splines:
Transmission input splines:
TRANSMISSION OUTPUT/DRIVE SHAFT INPUT SPLINES:  This set of splines transmits power from the transmission to the drive shaft which spins inside the swing arm.
Transmission output splines located at the right rear of the transmission:
2 valve K bike drive shaft splines:
4 valve K bike drive shaft splines:
FINAL DRIVE INPUT SPLINES: The drive shaft output splines transmit power to the final drive via these splines.
2 valve K bike monolever final drive input splines:
4 Valve K bike paralever final drive input splines:
SPLINE WEAR: In general spline wear is caused by splines sliding back and forth against each other under load.  If not kept properly lubed then this wear occurs much more quickly due to metal to metal contact while siding under load.
Here's some driveshaft output splines from a 52k bike that have been kept well-lubed and are in pretty good shape:
Here's some drive shaft output splines from a monolever 2 valve K bike that show lots of wear:
(Those aren't cobwebs.  It's fibers from the paper towel I used to clean the grease off of the splines for the picture.)
The wear pattern is often referred to as "the mountain effect" because worn splines look like this:
WHICH SPLINES SHOULD I CARE ABOUT AND KEEP WELL_LUBED? Well, all of them really.  However, the ones that are most susceptible to wear are the ones that slide under load.
For both 2 and 4 valve K bikes the clutch friction plate slides along the transmission input splines as you let the clutch out.  Therefore, these splines are subject to wear and should be kept well-lubed.  A common symptom of them requiring lubrication is difficulty downshifting or "false neutrals" (ending up in between gears) when downshifting, usually on 4->3 or 3->2 shifts.  If you're new to rding K bikes then this symptom may be hard to recognize.
When lubing the transmission input splines be sure to take a close look at the clutch plate splines for the mountain effect.  Usually those splines start to wear faster than the transmission input splines but when they start getting bad they also start to cause wear on the transmission input splines. Given how much effort it takes to get in there, if there's any significant mountain effect on the clutch splines then I'd recommend replacing the clutch friction plate with a new one while you have things apart.
For both 2 and 4 valve K bikes the drive shaft input splines are held in place on the transmission output splines by a circlip inside the splines so those rarely, if ever, wear out.
On 2 valve K bikes the monolever final drive design causes the drive shaft output splines to slide back and forth along the final drive input splines as the suspension travles up and down so these too are subject to wear if not kept properly lubricated.  (Some people claim this is a "design defect" of the monolever rear end.  However, since properly maintained final splines can last 100,000 miles or more I consider it more of a maintenance issue.)  The only good way to detect wear on these is by visual inspection which requires removing the final drive.
On 4 valve K bikes, the drive shaft output splines have a circlip that holds them in place on the final drive so those are not as subject to wear and will usually last the the bike's lifetime.  The intermediate splines are robust and don't seem very prone to wear.
WHAT SHOULD I LUBE MY SPLINES WITH?  Any lubricant containing a fair amount of molybdenum disulfide (a.k.a. "moly") is good for lubricating sliding metals.  Here's a few of the more popular moly lubes favored by K bike owners:
Honda Moly 60 Paste: This is a "grease" containing 60% moly available at Honda car and motorcycle dealers as well as some other auto parts stores and Fleabay vendors.  A 3 oz. tube of it costs <$10 and will last most people a lifetime.  The Honda Part number is 08734-0001.
50/50 mix of Honda Moly 60 and Wurth SIG 3000 Spline Grease:  This is one of the lubes recommended by one of the top BMW "gurus" in the country, Paul Glaves.  The Honda provides the Moly and the Wurth 3000 is uber-sticky stuff which keeps the moly around longer so your splines stay well-lubed and you don't have to lube them as often.  Based upon Glaves' recommendation on the MOA forum that's what I use these days.  The only place I've found it for sale online is here.
GD 525:  This is a product from Texas-based Guard Dog Moly and is another recommendation from Paul Glaves.  I haven't tried this but if Paul Glaves says it works that's good enough for me.  It also doesn't require mixing like the Honda Moly 60/SIG 3000 lube.
HOW OFTEN SHOULD I LUBE MY SPLINES?  There isn't a hard and fast answer to this one other than "enough to minimize the wear."  You probably can't do it too often though.
2 valve K bike monolever final drive splines:  Many owners recommend lubing these splines every time you replace the rear tire.  Another approach would be to do them every 10,000 miles.  That's what I do.  When you remove the final drive without draining it it gets rather messy unless you keep it upright.  I use Mobil 1 synthetic gear oil on 20,000 mile intervals so that way I'm sure the splines stay well-lubed but only have to do it once without draining the gear oil from the final drive.
Clutch/transmission splines:  BMW hardened the transmission input splines in 1990 and the recommended service interval was changed to every 40,000 miles.  Before that it was annually I think but that's overkill if you're not logging a lot of miles.  I don't have right answer but every 20-25,000 miles on a pre-90 bike and every 40,000 miles on later bikes sounds reasonable to me.  However, if you ever start experiencing sticky downshifting then I'd get it done soon because that sticky downshifting is caused by metal to metal contact.  (On the first K bike I logged any miles on I didn't know about the downshifting thing and wrote it off to just being a klunky transmission.  About 8,000 miles later I was left stranded when my splines stripped.  It was an expensive learning experience.)
4 valve K bike paralever final drive and drive shaft splines:  I do it every 20,000 miles when I change the final drive gear oil.  That might be overkill though.
HOW MUCH SPLINE LUBE SHOULD I USE? On the drive shaft and final drive splines you can't use too much.  Any excess will spin off harmlessly onto the interior of the swing arm.
There is the VERY mistaken notion about that you need to be sparing with the clutch plate/transmission spline lube because if you use too much it will spin off onto the clutch friction surface.  This is only partially true.  If the lube comes out of the front of the splines then it can indeed spin off onto the clutch friction surface.  However, if it comes out the back of the splines then, due to the raised collar on the rear of the clutch friction plate then it will just spin off harmlessly onto the inside of the bellhousing.  So the best approach is to clean all of the old grease out of both sets of splines and lube the hell out of only the transmission input splines before putting the transmission back on.
It this picture below I used Mobil 1 synthetic bearing grease for demonstration purposes only because it's red and more visible in the picture. It's a clutch plate assembly pushed onto transmission input splines.  The very fact that you can see that excess lube from the side demonstrates that it is well behind the rear clutch plate friction surface and will just spin off onto the bellhousing.
And here's how much of the Honda/Wurth 50/50 lube that I used when assembling my K75F:
Finally, if you pull your bike apart and the splines appear to be rusty then don't be alarmed. It's probably just the old red spline grease that BMW used to use.
Thanks for reading,
Dr. L. Duck Hubbard
By the way, if you enjoyed this post then please go to Amazon.com and buy my book, Splyanetics.  It will teach you how to be a happy successful person and provide you with enough disposable income to own and ride a BMW K1600GTL.
frodef
  • Novice Motobricker
  • Offline Offline
  • 1986 K75C
Re: Dr. L. Duck Hubbard explains: Splientology
« Reply #1 on: May 26, 2011, 03:58:52 PM »
What can one say? Now I feel like grasping two metal handles with some meters in between them that measure my internal state of happiness   ::)
Excellent information, thank you!
johnny
  • Uber Motobricker
  • Offline Offline
  • Name: Johnny Owrstrich
  • Ride It Till It Wont Move
« Reply #2 on: May 26, 2011, 05:47:09 PM »
i never splyanlubbed the bug... and when the driveshaft broke at 100k+... the splyans looked marvelous...
the top spleintologists suggest it was exceptional throttle control n supernatural motocontrol...
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« Reply #3 on: May 26, 2011, 06:55:35 PM »
Got a link to back that up?
Sonu
  • Offline Offline
« Reply #4 on: May 27, 2011, 01:35:30 AM »
Dr. Duck is granted tenure and shall hereby be addressed as PROFESSOR Duck.
This is the best write-up on spline lube I've ever seen.   When you have a chance please do write up how to take the bike apart to GET TO the splines. For someone who has never done this it is a daunting task.  If you are ever doing this within a day's ride of where I'm located I'll come down and be the photographer & even write it up.  I tried to do that with your visit to Roy S. but missed the action by a few hours.
Thanks,
Sanjiv
1997 K1100LT "Ziggy"  Now in 12th year with me.
leecow
  • Motobricker
  • Offline Offline
« Reply #5 on: June 02, 2011, 04:01:40 AM »
Paul Glaves has a 2 1/2 column blurb in his May BMW ON "Fact or Fiction" article about spline failure and maintenance. Not enough space (or really the point of the article) to cover the details Dr. D includes above but where they touch on similar points Dr. D and Dr. G seem to be in agreement.
Good work as usual FD!
Lee
'93 K1100RS
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« Reply #6 on: June 18, 2011, 08:47:16 PM »
Should've titled it "Fact or Friction"  ;D
johnny
  • Uber Motobricker
  • Offline Offline
« Reply #7 on: January 23, 2012, 12:23:10 AM »
wmax351
  • SuperNatural Motobricker
  • Offline Offline
« Reply #8 on: January 23, 2012, 12:43:01 AM »
Here is a picture of my Bruno's rebuilt driveshaft/final drive. Opened it up for a spline lube while I was doing some other tasks. 8000 miles on it or so, and no apparent wear.
Notice the longer spline section, for both the FD and the shaft. Also has a grease reservoir in the spline cup.
Bikes:
BMW 1991 K75 Standard
1971 BMW R75/5 in Toaster outfit (Shared with Dad)
'83 BMW R65LS (An R65 with a prototype K Bike Front End)
'75 Honda CB550F
'69 CB175
1999 Royal Enfield Bullet 500 (Last month of the original '55 model)
1973 Triumph Tiger TR7V (5 speed, Right Shift, Disc Brake)
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« Reply #9 on: January 23, 2012, 01:11:43 AM »
Interesting.  Bruno actually redoes the drive shaft splines too?  I was emailing with somebody at Hansen's in OR last month and what they do is only beef up the the final drive splines and then recommend a new drive shaft from BMW.
Different ways to skin a cat I suppose but I think that the key is keeping them well-lubed with moly is the way to go in order to minimize wear.
wmax351
  • Offline Offline
Bikes:
'75 Honda CB550F
'69 CB175
DRxBMW
  • Offline Offline
  • Name: Gary Weaver
« Reply #11 on: January 23, 2012, 08:27:10 AM »
I think, ____ Curry has a Hansen rebuild. He may be lurking here good or bad. LOL
From my understanding they use a differential metal (more durable) for the actual spline section. Seem to remember that Hansen spline R&R was born out of a Caterpillar bulldozer service shop in the early days.
Bruno does good work, over 98K on my K 75 rebuild,  DS splines look almost brand new. However, the mantra for lubrication is every rear tire change, NO exceptions.
IMHO,capping the DS to keep the grease in place instead of flinging down the hollow tube is the answer.
BMW K75 K100 Final Drive Shaft Spline Failure Causes 1of1
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
wmax351
  • Offline Offline
« Reply #12 on: January 23, 2012, 02:46:11 PM »
You are correct. Hansen's uses Catterpillar welding rods that are for repairing track wheel teeth.
I had them do my Airhead spline. They do quick, good work as well. I favored Bruno's for the K bike, as he upgrades the whole thing, without having to buy a new DS, which is arguably under-engineered from BMW. It simply shouldn't fail. If it does, it needs a bigger spline, a better metal, or a tighter tolerance. He does all three.
Bikes:
'75 Honda CB550F
'69 CB175
TaosBrick
  • Proficient Motobricker
  • Offline Offline
« Reply #13 on: April 13, 2012, 10:33:25 PM »
So Dr. D - My wife just ordered the Haynes 2valve manual. (I would have preferred the Clymer actually, but so it goes). Are there other write-ups online somewhere that have step-by-step instructions on removing driveshaft, transmission and clutch?
Just askin'.
'92 K75
'73 R75/5 Café
'96 F650 Funduro
'89 Yam XT350
'96 Yam Virago 750 (Wife Brenda's)
- Samurai Maxim
Photog
  • Motobricker
  • Offline Offline
« Reply #14 on: April 13, 2012, 11:37:00 PM »
There are two good write-ups in the Internet BMW riders tech section;
http://www.ibmwr.org/ktech.shtml
I used a combination of the two articles in there, the Haynes manual and Duck's writings on my recent clutch spline lube project.
I bought a clutch alignment tool ($18.50 shipped) from Kenneth Lively aka polepenhollow@yahoo.com which I found helpful.
If you don't take the clutch apart, however, you won't need the alignment tool.
On mine, I had a leaky o-ring and/or rear main seal, so that required disassembly of the clutch too.
'87 K75s
'90 Klein Quantum
"A safety device is only safe if you don't rely on it"; Arthur Klein
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« Reply #15 on: April 13, 2012, 11:39:00 PM »
Just askin'.
Your wife is gonna lube your splines?  (Lucky bastard - even without the double entendre. :laugh)
Take a look a my ABS II spline lube post in The Lieberry.  It's pretty much the same thing but without having to F with the ABS and paralever.
TaosBrick
  • Offline Offline
« Reply #16 on: April 13, 2012, 11:47:15 PM »
Oh yeah, baby! :2thumbup:
'92 K75
'73 R75/5 Café
'96 F650 Funduro
'89 Yam XT350
- Samurai Maxim
TaosBrick
  • Offline Offline
« Reply #17 on: April 16, 2012, 12:46:44 AM »
So Dr. D - How long does it take you to perform a splienectomy on a K75? Figger I'll prolly need to double that for my 1st time at it.
'92 K75
'73 R75/5 Café
'96 F650 Funduro
'89 Yam XT350
- Samurai Maxim
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« Reply #18 on: April 17, 2012, 01:20:01 AM »
Non-ABS K75:  About four hours if I had to do one quickly.  I usually take more time though and clean/degrunge everything while I have it off and relube the clutch arm pivot too.
Have lots of beer handy.  Running out can really slow things down.....
Pages: [1]   Go Up
