Author Topic: Circuit Modules to Augment Installation of Aftermarket Instruments on K-bikes  (Read 123820 times)
The Motogadget wants to see an almost perfect switch for its speed input signal.  That means you'll have to design an opamp based circuit to accept the low voltage, low current sinusoidal output from the Variable Reluctance sensor on the rear drive and convert that to a very high impedance output.  This implies a Vcc for the opamp between 5V - 14V (your choice based on your design) and the opamp needs to drive an open source N-channel MOSFET.  That way, the Motogadget will see an output impedance of infinity with the MOSFET off and 0.5 Ohms or so when conducting.
Offline Totem95d
Perfect !
It was the information I was missing, the motogadget sensor is not only a magnet, and need voltage to works .  thank you.
  • France , Paris
  • K75 light
K75 1996 (140k km)
Modified in something "lighter"
The Motogadget speed sender is a reed switch with magnet.  The magnet passing by the switch engages the switch, makes the contact and causes a pulse count in the instrument.  The OEM sensor outputs a sine wave, the frequency of which is proportional to the road speed.  The two signals are completely incompatible unless one is transformed into the other.
Offline Totem95d
hi all ,
Thanks for the previous answers !
I made the circuit today, but I would like to check something before to test it...
Is there 3 connections on the board OR Is there 4 connections ? :
1: IN +12V
2: IN +BMW Sensor
3: OUT to speedmeter
OR
1: IN +12V
2: IN +BMW Sensor
4: Ground
  • France , Paris
  • K75 light
K75 1996 (140k km)
Four.  There should be a ground reference on the circuit board.
Offline Totem95d
Thanks !
  • France , Paris
  • K75 light
K75 1996 (140k km)
Offline Totem95d
I made the circuits, I don't have any speedometers for the moment but it seems to works well !
First I wanted to buy a Motogadget speedo...but it was finnally too expensive for me...I found something similar but I'm not sure this model could works with the electronic circuit :
http://kosonorthamerica.com/product/tnt-01/
I think it's incompatible because it works with a passive speed sensor, do you agree ?
  • France , Paris
  • K75 light
K75 1996 (140k km)
From the instructions, it appears that the meter is capable of accepting two types of speed sensors -- passive and active.  The passive will be a simple reed switch that senses magnets placed on the wheel.  It can output up to 6 pulses per revolution.  The active sensor will sense the nearness of metal parts and can output up to 20 pulses per revolution.  The circuit you built will emulate the active sensor and can possibly replace it.  The interface on the speedometer will probably have 3 wires - power ground and sense.  The circuit you built will not need power so you connect the output to ground and sense.  I'd advise you to talk to Koso technical support to get answers to any of your questions prior to buying the meter, so that you are sure you're installation will go problem free.
Offline Bill
Interesting project !  New here and new to K bikes.  If one was to integrate all desired features into one system perhaps an Arduino or Raspberry Pi based system with a LCD display would be worth looking into.  Bluetooth, GPS, RFID, accelerometers and other sensors are plentiful and cheap.  Could also be a basis for a HUD.   Just getting into Arduino myself so I can't tell you how .... yet.
  • Sutton, Ontario, Canada
  • K100 LT
Current:  88 K100 LT
86 K100 R-?L?T parts collection in loose formation...
previous:
84 V45 Sabre
74 CB400
72 CB750
Read my blog page on the Brickuino I designed and built to work with my K75.
nice blog page!  lots of good info there!
Offline Bill
Great blog, great work  :clap:   As I am new here I should read all before posting !
  • K100 LT
Current:  88 K100 LT
previous:
84 V45 Sabre
74 CB400
72 CB750
Offline koon
Hi guys.
I am in the progress of installing a KOSO GP style speedo and I would very much like to use the built in speed sensor on my 1991 K75.
The speedo came with a passive speed sensor which can read up to 6 pulsations.
It has an optional active speed sensor which can read up to 20 pulsations.
From reading this subject I understand that it should be possible to use the original bmw speed sensor if I built a board.
Can somebody help me with a diagram of what I should built in order for this to work?
Any help will be much appreciated  :bmwsmile
Thomas
  • Denmark
  • 1991 K75 RT with ABS
Offline timewolf
  • Little Wolf
HI guys,
Ive been following and reading a ton on motobrick and soaking as much info as i can
this is my first post/reply/ question ... I've done my research and read as much as i can.
there has been discussion of what happens when removing the gauge cluster... which I've been riding around with out for a two weeks (waiting for me new after market) gauges to arrive. it didn't dawn on me that the alternator would stop working due to no bulb in the circuit. i haven't died yet but who knows when that will happen.
I love my Brick ( its my first despite owning and building 17 motorcycles from scratch) i really don't love the gauges as they and bulky.
Is there a quick or slow fix to work around this.
Thanks in advance for the time and help
-Wolf
1987 BMW K100RS
  • brooklyn
  • 1987 bmw k100rs
Holding it down since 79
Welcome, timewolf.
If it's any comfort, you aren't alone. None of us really know when that will happen.
https://tinyurl.com/RillRider
HI guys,
-Wolf
1987 BMW K100RS
is that a trick question?  ;-)
put the stock gauges back in until you figure out the alternate replacement......
Offline DJC
If you can put the stock gauge in while you wait. Do that.
But, if you can't....
From what i understand, the charging circuit runs through the light on the original dash. Which is a 3W globe.
So to emulate that circuit, you'll need something like a 120 Ohm / 3 Watt resistor. This gets wired between the BLUE cable from the alternator and any switched POSITIVE.
I'm in the process of doing this to my bike so i'll keep it updated with results.
  • Sydney, Australia
  • 83 K100, 81 GSX250
Its my first day.
Offline XxRamboSpainxX
i'm in the process of doing this too
  • Spain
  • k100
Offline duckytran
Hi guys.
Thomas
I saw this suggestion from another thread. Check it out and see if can help you.
http://maru-labs.com/en/
  • Austin, Texas
  • 1993 K75, 1981 R65
Offline jc55
RBM, I'm thinking about using one of the various Trail Tech units. Are there any issues using one of these relays for the "start in neutral emulation" circuit? They're plentiful and would be a compact option with or without the base.
Also, do you have any opinions on the...
MSD Tach Signal GMR Pickup
Converts a low-voltage, high-current pulse to a clean 12-volt square wave with no wire splicing required.
PART# 8918
Suggested Retail: $65.68
Your Price:$59.11
  • Carrollton, Ohio
  • '90 K100LT '77 Gl1000
This is a power switching relay and is oversized for the application.  The contacts are rated at 120V/5A which is 600 Watts or about 0.8 HP.  The Start in Neutral relays only have to have contacts rated at 12V/1A max.  In any case, it is also a 4PDT.  You'd have to have four of them to get the functionality meaning they collectively would take a huge amount of space in the relay box (if that's where you'd locate them).  I think these are a poor choice for the application, even if they are plentiful.
PART# 8918
Your Price:$59.11
This looks like a good solution to getting a conditioned signal to the tachometer input on your gauge and it appears to work with a number of different ignition systems.  I think the price is fair for what they are providing.  It probably has some quantity of electronic components inside it to perform the signal conditioning.  Others have managed to condition the signal coming off the coil primary, and I have helped a guy with his K75 to get the tach working by wrapping 6 turns of 18AWG wire around Cylinder #1 spark wire.  The MSD pickup tooks to be a very universal solution.
Offline jc55
RBM, thank you for taking the time to reply.  Comparing my relay to the neutral function schematic, I can see that you are right. I need the three separate 'gear position switch' grounds to energize three relays minimum, to complete the circuit. (Not knowing the inner workings of the 'gear position switch', if I could use only one of the grounds, I could use just one relay).
I'm assuming there is a triple ground redundancy to ensure that there isn't an accidental starting while in gear.
Thank you for weighing in on the MSD GMR pickup. It appears to require an rpm pulse per revolution setting of "1".  The Trail Techs seem to provide a .5, 1 and 2 PPR.
RBM, do you have any of your 'start in neutral' circuits available to buy?
  • Carrollton, Ohio
Yes, I have three available at the moment.  And more printed circuit cards are in the mail to me ready to be completed once they arrive.
The TGPI switch is a three pole rotary switch that has contacts arranged in a circular pattern.  The wiper arm inside the switch rotates via an axle protruding out of the transmission.  As each gear is selected, the axle rotates a few degrees, and positions the wiper over a patterned set of three contacts.  The pattern reproduced by the contact arrangement mimics a Binary Coded Decimal (BCD) truth table.  BCD is a very common method in computers to digitally represent a number between 0 - 7.  For the K-bike transmission, there are 6 gear positions - Neutral and 1 - 5.  The circuit inside the OEM cluster translates that pattern into gear numbers and neutral.  Neutral is equal to Gear 0.  The circuit detects this state and does special things when it is detected., exactly the same way the relays do, my circuit does and Maru's Brotbox does.
Offline jc55
Ahhh, that makes sense. So the TGPI works for each gear as well as neutral and the three wires are required...thank you.
  • Carrollton, Ohio
Offline sermardau
Hello all!
I am trying to replace the OEM speedo of my K75 with a Daytona Velona speedometer using original speed sensor, and also I have some led lights in order to replace the functions of the original velocimeter. Do you know how I can make it work? I'm rather new with electronics, so any help with the scheme of the circuit will be highly appreciated!
Thank you in advance!
 :riding:
  • Valencia, Spain
  • Bmw k75, Bmw k1200lt
