MOTOBRICK.COM - BMW K75 K100 K1 K1100 Forum
Please login or register.
Advanced search
...i think the owners at beemerboneyard have become billionaires just off jacked up shipping to australia...
Pages: [1]   Go Down
Author Topic: BMW K100LT Specifications  (Read 1347 times)
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« on: May 14, 2011, 01:31:28 AM »
BMW K100LT
BMW K100LT
Production
Start of Production1986
End of Production1991
Number Sold14.899
Price18.530,- DM
Engine
Motor Typefour-stroke, horizontal four-cylinder in-line engine, liquid-cooled
Bore x Stroke67 x 70 mm
Cubic Capacity987 ccm
Max Power90 hp (66 KW) at 8000 rpm
Max Torque86 Nm at 6000 rpm
Compression Ratio10.2 : 1
Valves per Cylinder2
Valve ControlDOHC, using drive chain and cup tappets
Carburation Systemelectronic injection, Bosch LE-Jetronic
Engine Lubricationwet sump
Power transmission
Clutchdry single plate
Number of Gears5
Gear Selectiondog-type gearbox (ratchet foot lever)
Gear Ratios4.50 / 2.96 / 2.30 / 1.88 / 1.61:1
Rear Wheel Ratio1 : 2.91
Bevel / Crownwheel11 / 32 teeth]
Electrical system
Ignitionelectronic ignition, Bosch Le-Jetronic
Alternator12 V 460 W
Starter0.7 kW
Spark PlugsBosch XR 5 DC, Beru 12-5 DU, Champion A 85 YC
Chassis
Type of Frametubular space frame, engine serving as load-bearing component
Front Suspensiontelescopic fork with hydraulic shock absorber
Rear SuspensionBMW Monolever swinging arm
Spring Travel front/rear185 / 110 mm7.3" / 4.3"
Rims front2.50-18 MT H 2
Rims rear2.75-17 MT H 2
Tyres front100/90-V 18 or 100/90-VR 18
Tyres rear130/90-V 17 or 130/90-VR 17
Brakes frontdual-disc brake 285 mm dia11.2"
Brakes rearsingle disc brake 285 mm dia11.2"
Dimensions / Weights
Length x Width x Height2220 x 920 x 1155 mm87.4"(7' 3.4") x 36.2"(3' 9.2") x 45.5"(3' 9.5")
Wheel Base1516 mm59.7"(4' 11.7")
Tank Capacity22l5.81 Gal - 4.84 Imp Gal
Unladen Weight, full Tank283 kg623 lb
Max permissible Weight480 kg1,056 lb
Ground Clearance175 mm6.9"
Fuel Consumption4,4 l/100 km (at constant 90 kph)54.7 mpg
Top Speed215 kph134 mph
Acceleration0-100 kph         4,1 sec0-60 mph
Power and torque:
Pages: [1]   Go Up
