MOTOBRICK.COM - BMW K75 K100 K1 K1100 Forum
Please login or register.
Advanced search
...i think the owners at beemerboneyard have become billionaires just off jacked up shipping to australia...
Pages: [1]   Go Down
Author Topic: BMW K75C Specifications (includes the US only K75T model)  (Read 1579 times)
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
« on: May 14, 2011, 01:24:38 AM »
BMW K75C
BMW K75C
Production
Start of Production1985
End of Production1990
Number Sold9.566
Price12.890,- DM
Engine
Motor Typefour-stroke, horizontal three-cylinder in-line engine, liquid-cooled
Bore x Stroke67 x 70 mm
Cubic Capacity740 ccm
Max Power75 hp (55 KW) at 8500 rpm
Max Torque68 Nm at 6750 rpm
Compression Ratio11.0 : 1
Valves per Cylinder2
Valve ControlDOHC, using drive chain and cup tappets
Carburation Systemelectronic injection, Bosch LE-Jetronic
Engine Lubricationwet sump
Power transmission
Clutchdry single plate
Number of Gears5
Gear Selectiondog-type gearbox (ratchet foot lever)
Gear Ratios4.50 / 2.96 / 2.30 / 1.88 / 1.67 :1
Rear Wheel Ratio1 : 3.20 or 1 : 3.36
Bevel / Crownwheel10 / 32 teeth or 11 / 37
Electrical system
Ignitionelectronic ignition, Bosch Le-Jetronic
Alternator12 V 460 W
Starter0.7 kW
Spark PlugsBosch X 5 DC, Beru 12-5 DU
Chassis
Type of Frametubular space frame, engine serving as load-bearing component
Front Suspensiontelescopic fork with hydraulic shock absorber
Rear SuspensionBMW Monolever swinging arm
Spring Travel front/rear185 / 114 mm7.28" / 4.49"
Rims front2.50-18 MT H 2
Rims rear2.75-18 MT H 2
Tyres front100/90-18 56 H
Tyres rear120/90-18 56
Brakes frontdual-disc brake 285 mm dia11.22"
Brakes rearsimplex drum brake 200 mm dia or single disc brake 285 mm dia7.78" / 11.22"
Dimensions / Weights
Length x Width x Height2220 x 900 x 1300 mm87.4"(7' 3.4") x 35.4"(2' 11.4") x 51.2"(4' 3.2")
Wheel Base1516 mm59.7"(4' 11.7")
Tank Capacity21 l5.55 Gal - 4.62 Imp Gal
Unladen Weight, full Tank227 kg500 lb
Max permissible Weight450 kg992 lb
Ground Clearance175 mm6.9"
Fuel Consumption4,2 l/100 km (at constant 90 kph)58.8 mpg (@ 60 mph)
Top Speed200 kph127 mph
Acceleration0-100 kph         4,6 sec0-60 mph
Power and torque:
frankenduck
  • Uber Motobricker
  • Offline Offline
  • Name: frankenduck
Re: BMW K75C Specifications (includes the US only K75T model)
« Reply #1 on: May 14, 2011, 01:27:33 AM »
Footnote: The K75T was a US only version of the K75C.  It had a "naked" K100 fairing and a handlebar mounted large windscreen:
Pages: [1]   Go Up
