Author Topic: K75 Auxiliary Power Outlet  (Read 7544 times)
Offline mrkay
« on: September 10, 2012, 11:53:37 AM »
So I just found this auxiliary power outlet on my 1992 K75s the other day.  What accessories are out there that plug into this?  Can I hook up a phone charger by chance lol I tried looking all this up on Google but I just keep getting results for the actual part its self.
Offline jsb
Re: K75 Auxiliary Power Outlet
« Reply #1 on: September 10, 2012, 03:24:35 PM »
Short answer: yes.
You will need to get a Powerlet to cigarette lighter adapter for your phone charger. Something like this:
http://www.powerlet.com/product/10-powerlet-to-cigarette-socket-cable/10
  • McKinney, TX, USA
  • 1993 K75, 2000 MotoGuzzi V11 Sport
'94 K75S (on its way to New York with its new owner)
'93 K75
'00 Guzzi V11 Sport
Offline argent brick
« Reply #2 on: September 10, 2012, 03:27:35 PM »
Are you talking about the one down by the coils?
BMW makes a battery charger that fits it. I have also seen an aftermarket set of jumper cables that will plug in as well. Do not use the jumper cables or the charger on the outlet by your key switch.
In the past, BMW has made a heated vest that would work on that plug. It was like the one made by Eclipse but sported a different plug. I think Eclipse made it. Do not know if it is still made. If you want one, buy the Eclipse version and save yourself some cash. If you still use the old System series helmets from BMW, the heated visor will plug in too. If you use that helmet we need have a little talk about a new skid lid.
An adapter is made so that you can run a normal phone charger like you would use in your car. Any BMW motorcycle dealer should be able to get it.
Try A&S, I think it runs about $15.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Offline 2000rsv
  • Ride Far - Ride Fast
AMA 1097757, IBA 33089, TS 700
2000 Yamaha RSV, 2008 KLR650, '86 BMW K75C, and always a couple of projects
93 K11LT
94 K11RS- "Kato"
86-97 K75F (K75/100/1100 Frankenbrick)
86 K75C w/ paralever, high perf. cams,TURBO!
91 K1
86 custom K100
and 2 more
IBA #17739 (SS1K, BBG, 50CC)
Buy parts HERE
Offline mrkay
« Reply #5 on: September 12, 2012, 05:57:38 PM »
Nice! Those will work perfectly these K bikes have a lot of cool hidden fetters.  I only posed the question because the other day I was riding back home in the morning after waking up hungover from a party at my friends place to find that my phone was dead and no charger available.  Now I can just get an extra car charger for the bike just in case.   :2thumbup:
« Reply #6 on: September 12, 2012, 07:21:03 PM »
I'd advise against riding hung over.  Your situational awareness suffers or you might even fall asleep and total your first K bike. DAMHIK.
93 K11LT
94 K11RS- "Kato"
91 K1
86 custom K100
and 2 more
Buy parts HERE
Offline Lastunder
« Reply #7 on: October 30, 2016, 12:56:54 PM »
I know this is an old thread, but do all K75 have an aux outlet?  I have an 86 75C and can't find one.  :(  Want to add a usb powerlet
  • Alberta
  • '86 K75C
« Reply #8 on: October 30, 2016, 02:23:21 PM »
All K75s should have the hole in the plastic coil cover that makes it "power outlet ready".   The BMW power outlet was an option that a buyer could add to the bike at the time of ordering or later. Normally, there is a plug that covers the hole if the option hasn't been added to the bike. There are connectors in the relay box of all K75s, as part of the wiring harness and into which the power outlet was plugged.
You can see the optional power outlet installed on this K-bike, at the bottom of this photo:
2011 Moto Guzzi V7 Racer
« Reply #9 on: October 30, 2016, 02:27:21 PM »
They are also known as Merit plugs you can buy universal plugs that have a removable end ( normally red ) and convert from a standard cigarette plug to a Merit by removing it. You can also buy Merit sockets and a Merit to cigarette lighter cable. You should be able to get them from Tandy or any good automotive outlet. I have converted a lot of items to the Merit connector. See site   http://www.powerlet.com/learningCenter/welcome-bmw-owners.
Offline Lastunder
« Reply #10 on: October 30, 2016, 02:52:18 PM »
Thanks Robert, that explains it. Have the hole, with a plastic plug(not flip up outlet cover) and a gaping hole of "PO didn't buy that option" behind it. Thanks for clearing that up.
Dave
  • Alberta
  • '86 K75C
Offline Michael Sydney
« Reply #11 on: April 20, 2017, 07:54:06 AM »
Hi, I know this is quite an old thread, but my questions are relevant.
I have a K100 (naked) with no auxiliary power outlet. I will probably fit a BMW/merit socket but wondered if the original wiring harness actually included a provision for this or do I need to go back to the fuse box? What connectors?
There is a fuse dedicated to fitting an outlet but perhaps it would be better to simply wire it back to the battery (via a fuse) so that the socket can double as a connection point for a battery maintenance charger?
Is the standard BMW socket "always live" or only on with the ignition?
  • Sydney Australia
  • K100 R65
« Reply #12 on: April 20, 2017, 09:50:15 AM »
I could be wrong, but I believe there is a connector in the harness that is for the auxiliary outlet.  It should be around the relay box just above the ignition coils.
On my bikes the auxiliary outlet is always live.  I use it as the connector for my battery maintainer which is equipped with a Hella connector.
  • '94 K75RT Mystic Red, '92K100RS White, '94 K75S Dakar Yellow
'94 K75S "Cheetos"
'91 K100RS "Moby Brick Too
« Reply #13 on: April 20, 2017, 02:16:02 PM »
Jaycar is a good source in OZ for Merit sockets.
Offline mlytle
« Reply #14 on: April 20, 2017, 02:58:28 PM »
what gryph said.
plus, i added a direct to battery two prong din connect with fuse that i use for charging (that is the standard charger plug) and i have a USB converter with same style plug for charging phones and SENA system.
primarily use BMW plug for heated vest.
  • alexandria, va
  • 92 K75s, 94 K75s, 09 K1300s
Marshall
"K75s Midlife Refresh V 2.0"
http://www.motobrick.com/index.php?topic=10043.new#new
Offline technostructural
« Reply #15 on: May 30, 2017, 06:26:29 AM »
I've been trying to wire up a USB outlet to the hella plug under the seat / near the coils. I haven't been having any luck. Looks like the hella plug is wired in correctly but I'm not getting any juice. Any thoughts for troubleshooting this?
  • Halifax, NS
  • 1989 K75 ("Schatz"), '81 Suzuki GS450T, 1974 Yamaha TX500
« Reply #16 on: May 30, 2017, 06:30:06 AM »
Can you get in there for a photo of your wiring job clear enough to analyze?
  • 1995 K75T 68,000 miles
« Reply #17 on: May 30, 2017, 06:32:51 AM »
Thanks for the quick reply Laitch. I can, but it is going to take me 24 hours or so at this rate.
Curious if there is a fuse or relay that might be the culprit? I will attach a photo asap.
  • Halifax, NS
