Todd Lampone did this conversion/initial write up a couple of years back.
Interesting, decided I would give it a shot on Heath's 1992 K 75 C project bike.
I just happened to have a spare pair of EBC rotors and a 4 pot R 1200 front caliper gathering dust in my garage. FWIW, the OEM K 75 master cylinder works fine.
Brembo 4 piston calipers on a K75:
First off I have never had any issues with the stock 2 piston calipers that came on my 94 K75, but I always like the look of the 4-piston calipers on later models and wanted to see if I could get them to work on my bike. My main quest was to get them mounted and working with no custom modifications on my part. Short answer is YES they fit with no major issues.
My curiosity began shortly after obtaining my K75 in ~August of 2008. But what really got me going was the R100R that I saw on the floor of Bob's BMW. At that point I knew nothing about their compatibility but it was a 94 R100R, and hey... my K75 is a 94 too so they MUST fit, haha.
I started to do a little online part number research and figured out that the R100R shared the same fork part number as the K75 which led me to believe that the caliper mounting bolts had to be the same spacing on my K75 as there were on the R100R. A rough measurement helped only increase my interest.
I was lucky enough to hit up an eBay auction for the calipers off of a 1999 K1200RS (#34112333111 and #34112333112) for $52 ($20 was for shipping alone!). As soon as they were delivered I ventured down to the garage for a test fit. This is what I saw:
As hoped, a perfect for!!!
Or was it?
As you can see from the last picture there is a terrible offset issue with the rotor. At that point I thought that the only possible fix was to grind down the mounting tab of the caliper to "pull" it away from the rotor. My estimate was ~3mm. I was really hoping to avoid that.
This called for another trip to Bob's.
My next thought was to see if there were any other BMW bikes that had a rotor that would bolt up to the K75 hub. I tried to see if the R100R rotor would work, but it uses a spoked wheel and thus I couldn't confirm that the rotor would work. It was, however, the only BMW bike that I came across that used a 4 bolt mounted rotor. Checking with EBC's online parts list, I saw that there was a different part number for the R100R and K75 front rotors. This meant that there was something different between them. I was hoping that Bob's had an R100R rotor and a K75 rotor in stock so that I could sit them on the counter and measure the differences but that wasn't the case.
So I made a call to EBC and their customer support was very helpful and gave me the break down on their (BMW equivalent) rotors. This is what they told me:
EBC MD605LS (R100R):
Outter Diameter = 285mm
Bore = 62mm
Thickness 4.7mm
Offset = 28mm
4 bolts mounting
EBC MD604LS (K75):
Bore = 62mm
Thickness 4.7mm
Offset = 31.5mm
4 bolts mounting
Highlighted in bold is the only difference between the rotors; a 3.5mm offset, toward the hub!!! This was exactly what I needed.
At this point I was confident that the setup would work. The only thing the EBC CS could not confirm was the actual bolt pattern of the rotor. So back to Bob's for me (luckily i'm only about 3 miles from the dealer).
I did a quick measurement of the mounting bolts and it looked right on. This was enough evidence for me to put in an order for a set of rotors and a set of pads (EBC Rotors MD605LS/MD605RS, EBC Sintered Pads FA407HH).
Finally the rotors, well one of them at least, was delivered. Of course I had to put it on immediately. Here's how it went:
First off the rotor bolts up just fine. Here is a pic of the rotor and caliper on but no pads installed:
As you can see it's not a perfect fit I had hoped for but it was good enough to continue. So off the calipers came and a set of brand new EBC pads went in. I remounted the caliper and this is what I saw:
While still not a perfect fit there is clearance on both sides and the wheel spins freely!!!!
I still have to wait for the other rotor to come in and actually bleed the 4-pots to see how the K75 master cylinder will work.
The left side rotor has already been delivered and I will mount it up, bleed the brakes, and see what happens. The last concern is the master cylinder. The R100R and K75 both share the same 13mm master cylinder, but later MC's used with 4 piston calipers has a 15, 16, and even 20mm MC pistons.
More updates tonight or tomorrow.
The left side rotor was delivered and I installed it. The next step was to install the calipers and bleed them.
When I initially test fit the caliper it was done dry, and therefore none of the lines were disconnected. My 94 K75 has a single flexible line from the MC to the right caliper and a hard line that spans the front fender to the left caliper. I started my install by installing the left side caliper. With the caliper unbolted from the fork tube, I noticed that the mounting bolts were not lining up. Turns out that the threaded hard line hole on the 4-piston caliper was in a slightly different spot than on the 2 piston calipers. Luckily it wasn't very far and only required a little bending of the hard line. I did not what to do this by hand so what I did was screwed only a couple threads of the hard line into the caliper and the bolt down the caliper. From there I tightened the hard line allowing it to bend itself only as much as needed. I needed to do this for the right side as well.
I proceeded to bleed the brakes in the traditional, painful, repetitive manner. For some reason the DOT 4 fluid I was using was brown even though it came from a sealed container. So I'll have to pick some more up tonight are redo it.
As impatient as I am I immediately went for a short ride around the neighborhood, getting up to, at most, 30mph. The lever felt very soft as I expected it too. The brake has a great feel to them but I was a little uneasy about the overall ability. I attribute a lot of that to the fact that both pads and rotors are brand new and need time to bed themselves. Also, the questionable fluid is a concern. I will do a bleed with fresh fluid and give the pads and rotors some time and then decide if a large master cylinder is necessary.
The brake look fantastic
