Author Topic: ALTERNATE PARTS LIST Master Index  (Read 29915 times)
Offline wmax351
« on: January 06, 2012, 02:47:48 AM »
edit 04-01-2018 by TimTyler...
added the fuel pump thread by f14crazy...
The following master index should make it easier to find alternate parts in the Lieberry.
Also, if you have something that you'd like to add to the APL thread, then feel free to post a thread here and we will take care of adding it the Alternate Parts List.
MicroFiche
OEM BMW Part Number Cross Reference at RealOEM.COM
Windscreen
K1100LT Alternative Windscreen Motor and Hardware
Alternate Handlebar Micro Switch For Front Brake Lever
Brake System
Alternative Brake Pads
Bearings
K100 2V Bearing Cross Reference
Steering Head Bearings
Cooling System
Thermostat
Engine Electrical
Fan
Spark Plugs
Ignition Module and Heat Sink Compound
Alternate 50A Alternator Voltage Regulator
Starter Relay
Fuel Pump Relay
Engine Internals
Valve Shims
Fuel System
Injectors
Injector O-Rings
Complete Fuel Pump/Pump Holder/Fuel Filter/Electrical Connector Package
Fuel Pumps
Fuel Filters
Air Filters
Oil System
Oil Filters
Oil Pressure Switch
Clutch System
Clutch Plate
From the list at IBMWR.org, with a few annotations from me (wmax351).
29 Bosch items for K75 bikes
Date: Wed, 4 Mar 1998 16:57:06 -0500 (EST)
Sure... There are 29 items for K75 Bikes (including alternatives for several items that vary by country & the side of the road bikes are ridden on). The items include (pls. excuse the translation from Spanish) the following:
ITEM ~ PART NO.
(1) Ignition switch ~ 0 232 101 003
(2) Ignition Control Unit (with an alternative for Switzerland) ~ 0 227 401 003 ~ 0 227 401 005
(3) Ignition Coil ~ 0 221 125 010
(4) Spark Plug, Super (X 5 DC) 0,60 mm ~ 0 241 145 500
(5) Spark Plug, Silver (XR 4 CS) 0,70 mm ~ 0 242 150 501
(6) Alternator (G1 L 14V 28A 22) until 9/91 ~ 0 120 339 546
(7) Alternator (G1 (R) 14V 8/32A) from 10/91 ~ 9 120 333 230
(8) Battery (12V 30Ah 180A) ~ 0 180 053 030
(9) Starter Relay ~ 0 332 002 161
(10) Fuel Injection Control Unit (LE2) until 7/90 ~ 0 280 000 332
(11) Fuel Injection Control Unit (LE2.1) from 8/90 ~ 0 280 000 376
(12) Fuel Injection Control Unit (LE2) from 7/89 (police) ~ 0 280 000 376
(13) Air Volume Sensor ~ 0 280 200 040
(14) Pressure Regulator ~ 0 280 160 200
(15) Water Temp. Sensor ~ 0 280 130 032
(16) Injection Valve ~ 0 280 150 210
(17) Butterfly Position Sensor [TPS?] ~ 0 280 120 302
(18) Fuel Pump 52mm 16 12 14 61 576, 16121461576 ~ 0 580 453 999  0 580 463 999  0580453999
(19) Fuel Pump (Treated against parasites [!]) ~ 0 580 463 998
(20) Fan Motor ~ 0 130 007 304
(21) Fan Motor (Treated against parasites [!]) ~ 0 130 007 319
(22) Rectangular Rt Hand Ride Headlamp ~ 0 303 750 100
(23) Round Rt Hand Ride Headlamp Until 5/94 ~ 0 303 850 109
(24) Round Rt Hand Ride Headlamp ~ 0 303 851 100
(25) Rectangular Left Hand Ride Headlamp ~ 0 303 750 600
(26) Round Left Hand Ride Headlamp ~ 0 303 851 600
(27) Fog Lamp Until 9/91 ~ 0 305 402 106
(28) Wiring Harness Parts ~ 1 987 352 018
  • Ann Arbor, MI on the way to ABQ, NM
  • 1991 BMW K75 Standard, Refreshed '94 engine
Bikes:
Re: ALTERNATE PARTS LIST (Index)
« Reply #1 on: October 21, 2015, 09:53:53 AM »
greetings airheaddreamin...
welcome to motobrick.com...
thank you for your positive contribution...
mystic red will add these two items to the altetnate list straightaway...
Offline dglcinc
« Reply #2 on: March 06, 2016, 11:52:52 PM »
FAG 6005-2RSR-C3 are available on Amazon for $2.40(!) each and are exact replacement for K75 front wheel bearings (you need two.) Also, all EBC front and rear brake rotors and pads for K75 are available on Amazon for good prices. Finally, FAG 320/28X available on Amazon for $44/ea, exact replacement for OEM k75 steering bearings. I've heard others say you can get this bearing even cheaper at auto parts stores with this same spec (320/28x), but I cannot vouch.
  • New Jersey
  • 1987 K75S candy red 45K
« Reply #3 on: March 07, 2016, 12:05:13 AM »
greetings dglcinc...
mystic red will add these items to the alternate list as soon as getts off his latest bender...
« Reply #4 on: March 07, 2016, 12:32:22 AM »
Those wheel bearings are limited to "10000rpm Maximum Rotational Speed" which works out to about 800mph on a 27" diameter K tire.  Might not be enough for some riders like Johnny.
Offline dglcinc
« Reply #5 on: March 07, 2016, 07:39:36 PM »
Sorry new to the crew, it may take me some time to pick up on the humor. I assume you're joking? How do you tell the rotational rating of a bearing? As far I could tell looking at the old bearing and the new one they were pretty near identical (based on the markings on the bearing.) Did I miss something?
  • New Jersey
  • Redline 7000
  • Forum Moderator
« Reply #6 on: March 07, 2016, 08:07:52 PM »
You video it in action, speeding it up until it explodes then you replay the video at a very slow rate counting the revs during the minute just before the explosion.
  • 1995 K75 72,000 miles
https://tinyurl.com/RillRider
« Reply #7 on: March 07, 2016, 08:19:28 PM »
thats why i put a line on my bearings in reflective ink... makes it easier to count the revolutions... dont have to slow the tape down as much...
anyhow... i switched to ceramic bearings... when i switched to 27" tiors...
Online Martin
Online Martin
Re: ALTERNATE PARTS LIST Master Index
« Reply #9 on: July 12, 2017, 05:39:35 AM »
Source of  starter brushes which can be replaced instead of buying the whole plate. http://www.motobrick.com/index.php/topic,10032.0.html
Offline bluto359
  • what day is it
« Reply #10 on: July 23, 2017, 11:41:47 AM »
Looking for a switch that'll drop into the switch pad on the handle bar. I have a K75s, looking to add some low amp LEDs. I have an extra slot for a switch. Doesn't have to be an oem number.
  • Southern Illinois Land of Lincoln
  • 1987 K75s 2009 1125CR
tomorrow
Offline propav8r
« Reply #11 on: November 13, 2017, 02:37:05 PM »
If you trim 4.5" off the short end of a Volvo 240 lower radiator hose, it fits the lower hose on a K perfectly. It's ever so slightly smaller in diameter than the factory hose, so it's MUCH easier to get through the crankshaft cover.
Also, it's $6 instead of almost $60.  https://www.eeuroparts.com/Parts/4336/Engine-Coolant-Hose-Lower-270616/?gclid=CjwKCAiAoqXQBRA8EiwAIIOWsimr9SDC-0d7ixL8CyOrFS9t7V69_JmZaSR-ldxUaqpnce6MmTiUnRoC5hUQAvD_BwE
  • Franklin, NC
  • 1985 K100RS, 1978 GL1000, 1972 Kawasaki H2 750
« Reply #12 on: November 13, 2017, 03:18:46 PM »
The problem with BMW hoses and other rubber stuff is that they were never able to rebuild the rubber factories bombed by the allies in WWII, and most of the meager German rubber output is dedicated to making B&D costumes for the German dungeon sex market.
  • '94 K75RT Mystic Red, '91K100RS White/Blue, '89 K100RS Special edition White/Blue
'91 K100RS "Moby Brick Too
'89 K100RS SE
Online Martin
« Reply #13 on: November 13, 2017, 03:40:11 PM »
 :clap: Good find, now all we need is a substitute for the top hose.  :popcorm
  • Redline 7000
  • Forum Moderator
« Reply #14 on: March 20, 2019, 10:05:18 PM »
Tyco Starter Relay Tyco V23232-A0001-X003
Shop around using this maker and part number. It can be found for less than half the OEM price.
Offline wenbo_wang
« Reply #15 on: March 30, 2019, 01:46:20 AM »
Great find! Looks like they charge 12 dollar shipping fee. Here is what I found on Amazon. 9.55 plus free shipping if you are prime!
https://www.amazon.com/URO-Parts-270616-Lower-Radiator/dp/B0066SOBR8/ref=sr_1_fkmrnull_1?keywords=URO+Parts+270616&qid=1553924591&s=automotive&sr=1-1-fkmrnull
Cheers!
  • US
  • 1986 BMW K100 RS
« Reply #17 on: March 31, 2019, 11:43:16 AM »
BMW Kbikes used switches that are standard sizes for marine use.  So, you should be able to locate compatible switches at a local marine shop.  The dimensions of the BMW / marine rocker switches are 1 3/8 by 13/16 (35 mm by 20 mm)
Examples of suitable switches are:
Carling Contura rocker switches (available from Eastern Beaver
I found a cheap set of switches on Banggood, a Chinese online retailer, that seem to be suitable but I can't say for sure.
Offline szabgab
« Reply #18 on: August 08, 2019, 03:16:30 PM »
In my fruitless search for better fuel economy I have decided to replace the coolant temp sensor. Bosch part is hardish to come by and it is expensive and we know from Martin's experience, the ali version is a no go. However many brands produce the same type coolant sensor, and I can attest, it works as it should (e.g. resistance readings are perfect, it fits perfectly, the connector is the right type and the bike runs with it just fine and switches on the fan, as it should)
The one, I have bought is the FAE 33090 so that is the one, I am sure, works.
Apparently all these are a direct replacement:
NOTE... these below have NOT been verified as alternative to oe... Reader Beware... if you have verified these are 100% or otherwise... poast up here...
FACET 7.3192
METZGER 0905174
ERA 330133
LUCAS ELECTRICAL SNB810
SIDAT 82.594
MAGNETI MARELLI 171916011290
HELLA 6PT 009 107-501
VEMO V40-72-0328
  • Budapest, Hungary
  • K75S 1985 model
Offline volador
  • NEEDS MORE CHROME
« Reply #19 on: December 15, 2019, 01:11:11 PM »
COOLANT TEMPERATURE SENSOR
K75 K100 2V  BMW # 61311459197   BOSCH 0280130032 or 0280130069  PORSCHE 92860612600  SAAB 8788200  STANT 74052
K1 K1004V K1100 # 13622242184   BOSCH 0280130055
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline volador
  • NEEDS MORE CHROME
  • NYC NY
Offline volador
  • NEEDS MORE CHROME
« Reply #21 on: December 18, 2019, 02:35:34 AM »
Genuine Honda 08798-9013 Silicone Grease
rejuvenate rubber seals, lubricating door seals, window channels, sunroof seals
Genuine Honda 08798-9002 Hi Temp Urea Grease
metal-to-metal contact
  • NYC NY
