Author Topic: Missing Rubber handle bar end, P/N help? Source?  (Read 188 times)
Offline KCinSB
« on: January 12, 2021, 09:06:59 AM »
The RH handle bar end on this Ď93 K1100RS fell off somewhere, and itís eluded my parts book search. The thing is a simple thin rubber cap that was glued to the end. Can anyone here help me find a part number to try ordering with? I figure there has to be a few laying around, but the variety of bar ends available makes description a bit foggy. I suppose a photo would be a smart move here.....   :wink:
K1100RS, some old BSAs and Triumphs,... some even run!! Recent Dark Side foray... '65 XLCH tractor.
  • Redline 7000
  • Forum Moderator
Re: Missing Rubber handle bar end, P/N help? Source?
« Reply #1 on: January 12, 2021, 09:31:20 AM »
Correct! From your description it seems homemade or aftermarket.
  • 1995 K75 80,000 miles
https://tinyurl.com/RillRider
« Reply #2 on: January 12, 2021, 02:03:00 PM »
Some of the grips I've used came with a plug/cap. You could do better by upgrading to either alloy or steel bar end caps. A lot of motorcycle accessory shops stock them or try Fleabay.
Offline mw074
« Reply #3 on: January 12, 2021, 05:38:07 PM »
 Part number 32 71 2 307 452. Part in the middle of the picture.
 Not glued. It snaps on.
  • Michigan
Offline mw074
« Reply #4 on: January 12, 2021, 05:40:42 PM »
BMW part fiche.
16    32 71 2 307 452    COVERING CAP   0.01    2     $3.68
  • Michigan
Offline KCinSB
« Reply #5 on: January 13, 2021, 01:59:48 AM »
Thank you!  Tharís the thing all right. I guess mine must have given up the snap fit at some point since the base is covered with old glue, looks like more than once too. Hopefully they are still available. Itís a small thing, but just ugly and obvious!
............... MINUTES LATER,  itís on the way!  Part and shipping, $11.53.
Offline Areshuan
  • Ecuador
  • 96 K1100RS
Killing time until time kills me
96 K1100RS
07 R1200GS
04 R1150GS
