Author Topic: 22Lt top box mounting plate.  (Read 290 times)
« on: August 03, 2020, 07:56:32 PM »
Due to the 22Lt top box mounting plates seeming to disappear I thought I'd look into whether it would be possible to make them. The guys in the foundry decided to fit it with reinforcing. This has now deemed to be unnecessary as pushing the pattern a little deeper into the mold is all that is needed. The steel cam lock was initially made in two pieces and silver soldered together. This was found to be time consuming and future ones will be cast in brass using a pattern.
* 22Lt mounting plate 1.png (43.6 kB . 768x576 - viewed 99 times)
* 22Lt mounting plate 2.png (32.72 kB . 768x576 - viewed 98 times)
Offline natalena
Re: 22Lt top box mounting plate.
« Reply #1 on: September 13, 2020, 12:09:48 PM »
Really cool project. Are you mechanically pressing, or using a hydroform mold? Staying with the original steel construction? Cheers
  • MST
  • 1987 K75s #0919, '05 Sportster 1200C
We don't need no stinkin' moly.
« Reply #2 on: September 13, 2020, 04:11:03 PM »
Natalena the Trades Guild are sand casting out of aluminium slightly thicker than the OEM steel. The extra thickness is achieved by pushing the pattern into the sand on one half of the mold before casting. A couple of methods were tried to make the cam locks that attach to the plate, a two parts steel silver soldered together. Also tried casting off the original cam lock. Eventually decided to make a camlock pattern and cast it in brass and then finish it off which hasn't been tried yet.
Offline natalena
« Reply #3 on: September 13, 2020, 08:29:55 PM »
+1 with the usage of Aluminum. The OEM plate has a lot of slop, and I always thought an aluminum plate would be less rattle prone and could be made thicker.
  • MST
Offline alexg
« Reply #4 on: September 14, 2020, 11:44:36 AM »
Martin, not a small feat to make an alu casting that thin. As a metallurgist, I am interested in the method: heated sand mold? high Si (piston stock) alloy? what else? I am impressed!
Alex
  • Michigan
  • '93 K75S, 1975 BMW R75/6 & 1984 Yamaha RZ350
Alex G.
« Reply #5 on: September 14, 2020, 03:25:01 PM »
Alex all done by our resident foundry Gurus. They are sandcast out of a pattern as in an OEM 22 Lt plate, and I believe they used high silicon aluminium. The head of the foundry Doc is pretty clued up when it comes to what metal to use for the best results for a particular job. The Guild has a pretty varied range of retired tradesmen which cover a lot of subjects from furniture restoration, toy making, CNC machining, and fitting and turning. Current project for the machine shop is building a CNC machine. We've already built a CNC/ computer plasma cutter for the neighboring Blacksmith. We run three days a week Tuesday Friday and Sunday but we've slowed down a bit due to Corona. See here for more information.  http://northpinetradesguild.org.au/
Offline alexg
« Reply #6 on: September 14, 2020, 04:56:03 PM »
Martin:
I looked at the web site. Seems to be a fun place to meet interesting people! Enjoy.
  • Michigan
Alex G.
« Reply #7 on: September 14, 2020, 11:47:10 PM »
It keeps me out of trouble, mostly. I seem to be busier now than when I was working.
