Author Topic: 1989 K75 reanimation  (Read 6610 times)
Offline koshak
Re: 1989 K75 reanimation
« Reply #100 on: November 10, 2020, 02:00:21 AM »
not sure if understood your question properly.
On photos:
1. proper installation (yellow dots matching)
2,3. Shaft turned 180 degrees.
  • Cyprus
  • 1989 K75, 1989 K1, 2008 K1200GT
« Reply #101 on: November 10, 2020, 02:18:33 AM »
Yes, that's what I meant. Thanks heaps for going out of your way to help me understand this funny little unit.
Offline koshak
« Reply #102 on: November 17, 2020, 08:59:43 AM »
to install valves seals, suitable socket was used.
  • Cyprus
Offline koshak
« Reply #103 on: November 17, 2020, 09:28:04 AM »
By the way, to remove that valve stem seals was quite a pain without proper tool, due to quite deep wells. I did not need such tool in my other projects, but now, sitting in Malaysia, purchased such puller. Since there is another brick in the queue, will see how it works.
  • Cyprus
Offline koshak
« Reply #104 on: November 17, 2020, 09:34:51 AM »
Shopping in Malaysia was not bad.
Got the tool for the springs.
However, if center stand assembly removed completely to work on bench, this tool is not needed. :laughing4-giggles:
  • Cyprus
Offline koshak
« Reply #105 on: November 17, 2020, 09:35:49 AM »
Springs compressor
  • Cyprus
Offline koshak
« Reply #106 on: November 17, 2020, 09:37:32 AM »
Holder. Good thingy, already used to remove rear brake disk.
  • Cyprus
Offline koshak
« Reply #107 on: November 17, 2020, 09:40:23 AM »
Original rear master cylinder was terrible, as was shown before. Found original used part, but it was not pumping either. 177381
So took an overhaul kit, now all ok.
  • Cyprus
Offline koshak
« Reply #108 on: November 17, 2020, 09:43:03 AM »
Installing valves
  • Cyprus
Offline koshak
« Reply #109 on: November 17, 2020, 09:47:22 AM »
Brembo forks.
What is correct oil volume????
I drained 200 ml.
In Haynes says 420 when dry
In Maintenance manual says 0.330 for K75.
  • Cyprus
  • Redline 7000
  • Forum Moderator
« Reply #110 on: November 17, 2020, 11:04:38 AM »
The 420ml figure is for Showa forks from 1991 on when the oil is drained completely.
The attached chart from IBMWR is widely accepted and shows the figures for Showas, sport forks and Brembos. Brembos are identified by an imprint on the slider.
  • 1995 K75 80,000 miles
https://tinyurl.com/RillRider
Offline koshak
« Reply #111 on: November 17, 2020, 01:13:49 PM »
thank you. that appears i have K75 Sport and will need 280 ml.
  • Cyprus
Offline koshak
« Reply #112 on: November 18, 2020, 03:40:35 AM »
front brakes overhaul.
  • Cyprus
Offline koshak
« Reply #113 on: November 18, 2020, 03:41:54 AM »
such amount of "substance" remained in caliper after draining
  • Cyprus
Offline koshak
« Reply #114 on: November 18, 2020, 03:43:15 AM »
inspection of rear drive - before cleaning and after
  • Cyprus
Offline koshak
« Reply #115 on: November 18, 2020, 03:44:58 AM »
internal inspection
  • Cyprus
Offline koshak
« Reply #116 on: November 18, 2020, 03:45:35 AM »
seal replaced
  • Cyprus
Offline koshak
« Reply #117 on: November 18, 2020, 04:31:50 AM »
i am changing low seat to high seat.
that also requires change of the seat lock.
This is lock for high seat.
  • Cyprus
Offline koshak
« Reply #118 on: November 18, 2020, 04:32:57 AM »
to avoid having many keys (individual per lock), decided to replace lock insert from original lock to the new one.
this is original lock for low seat.
  • Cyprus
Offline koshak
« Reply #119 on: November 18, 2020, 04:34:44 AM »
Unfortunately, these inserts are not interchangeable, they are of different construction of the actuator (not very seen on this photo)
Left is high seat lock, right is low seat lock.
  • Cyprus
Offline koshak
« Reply #120 on: November 18, 2020, 04:36:51 AM »
therefore, the pins were removed from each lock and interchanged. 112350
  • Cyprus
Offline koshak
« Reply #121 on: November 18, 2020, 04:38:46 AM »
Ignition coils cosmetic maintenance
  • Cyprus
Offline koshak
« Reply #122 on: November 23, 2020, 04:45:42 AM »
today is one month since parts for engine were sent by supplier in Germany. And delivery date is still not know, as per tracking they are in the middle of nowhere.... When this worldwide craziness already finish?
However, sometimes long waiting time is good. Thus, i was looking yesterday through the pictures of disassembly, and suddenly realized that i installed output shaft wrongly.  boohoo Original mark almost lost its paint mark.
Since engine is open, the situation was immediately rectified.
  • Cyprus
Offline koshak
« Reply #123 on: November 23, 2020, 04:46:50 AM »
after that engine was wrapped in plastic again, to wait for parts to arrive.
  • Cyprus
Offline koshak
« Reply #124 on: November 23, 2020, 04:49:56 AM »
time to do forks
  • Cyprus
