Author Topic: FS: Multivario Tank Bag K75, K100, K1100, K1  (Read 1691 times)
Offline ffbikersa
  • Sarajevo K 1100 RS biker
« on: November 02, 2019, 01:07:52 PM »
Selling BMW tank bag Multivario, fits with the corresponding base plate on many BMW motorcycles:
R65, R 65 RT, R 65 GS, R 80, R 80 RT, R 80 G / S, R 80 ST, R 100, R 100 RS, R 100 RT, K75, K75 C, K75 S, K75 RT, K100, K100 RS , K100 RT, K100 LT, K1100 RS, K1100 LT, K1 - one picture shows it on my K1100 RS
including volume enlargement parts, all zips OK
https://www.ebay.com/itm/264519621938
* _MG_6412.JPG (36.75 kB . 702x576 - viewed 214 times)
1997-1999 R 100 RT, 1999-2000 R 100, 2000-2003 R 80, 2003-2017 K 100 LT; now K 1100 RS
Offline bocutter Ed
Re: FS: Multivario Tank Bag K75, K100, K1100, K1
« Reply #1 on: November 02, 2019, 02:31:26 PM »
Which base is with it?
  • Toronto, Canada
« Reply #2 on: November 02, 2019, 03:12:00 PM »
bocutter ed has legit question..
the base is not proper k1100 oe fittment...
* not proper.png (46.75 kB . 768x430 - viewed 201 times)
Offline volador
  • NEEDS MORE CHROME
« Reply #3 on: November 02, 2019, 03:41:35 PM »
True to its OE Multivariable fits 22 motos
Fine looking piece of equipment
GLWS
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
  • Forum Moderator
« Reply #4 on: November 03, 2019, 07:15:49 AM »
I used to have one of those older bags, they were not intended to fit the 1100's or K1's as they use the wire loop type attachment along the gas tank seam. The side straps also have more of a straight downward angle to them, unlike the newer series that is more swept back towards the rear 1/3 of the fuel tank.
They will fit if you can manage enough free space between the side cover and the fuel tank.
The base should be stamped with what series they fit. My old one was stamped K75/K100. The stamping should be visible if the bag us unzipped from the base.
Ride safe.
1997 K1100LT 0302488
Garmin StreetPilot 2820
Garmin Zumo 550
Offline ffbikersa
« Reply #5 on: November 05, 2019, 04:21:07 AM »
This base did not have anything stamped (that could be seen on the ebay add pics).
From what I could figure out in BMW OEM catalogue, it would be 71602340658
Anyway, it got sold to Germany.
Now I ordered another bag made specifically for use with K1100 and hooks one has to install
  • Forum Moderator
« Reply #6 on: November 05, 2019, 06:57:27 AM »
That is the correct bag for the 1100's..... in fact, that 2nd picture is one I took of the clips on my '97.
Ride safe.
Garmin Zumo 550
Offline alabrew
« Reply #7 on: November 05, 2019, 05:39:44 PM »
The elastic on my k100 bag (like the yellow trimmed one) is showing age. Anyone replace it? Difficult?
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Offline stokester
« Reply #8 on: November 05, 2019, 06:59:24 PM »
I had the same issue with my airhead Multivario bag and had the elastic replaced at a leather repair shop.  I see no reason a decent shoe repair shop could not do it as they would also have the heavy-duty sewing machines.
  • Yorktown, Virginia
Offline mdk_mdk
« Reply #9 on: November 05, 2019, 08:08:49 PM »
I repaired mine using 2" Underwear & Pajama elastic from Michael's Craft Store. I opened up some stitches with a stitch cutter, cut out the old elastic, glued in the new elastic and then restitched by hand through the existing holes in the leather. Came out great, holds well. I would recommend safety pinning the elastic to the strap and checking the fit first, I had to shorten up the straps more than I thought to get a fit where the elastic was slightly stretched instead of slack.
  • Ringoes NJ
  • 1990 K75
Offline mdk_mdk
« Reply #10 on: November 05, 2019, 08:09:50 PM »
If you can't find the elastic, let me know, I have 1.9 yds left over!
  • Ringoes NJ
  • 1990 K75
Offline ffbikersa
« Reply #11 on: November 06, 2019, 12:17:59 AM »
I have the same issue with elastic on my new bag. Planned to have it fixed now during the winter.
  • Forum Moderator
« Reply #12 on: November 06, 2019, 06:58:59 AM »
I've replaced the elastic on mine as well a couple of years ago. Like others, I just cut the stitching and put new elastic in then sewed it back together.
I wasn't able to find any 2" wide elastic, best I could find was 1-1/2" wide. It fits, though it's not as snug as the original.
Ride safe.
Garmin Zumo 550
Offline alabrew
« Reply #13 on: November 06, 2019, 02:36:59 PM »
Thanks for the replies. I was sorry for highjacking a thread, butI think it worked out well.
Thanks for the offer mdk_mdk, buttts yous gotts to use black, like zip ties. =-}
Also:
2005 K1200LT
1979 R65
Offline BrickDad
« Reply #14 on: November 06, 2019, 07:00:13 PM »
.... yous gotts to use black, like zip ties. =-}
That's what black permanent markers with a wide chisel tip are for  ;-)
  • Arlington County, Virginia
  • K75T, 1995
Disagree Disagree x 1 View List
Offline ffbikersa
« Reply #15 on: November 07, 2019, 01:48:12 AM »
I've just ordered black 4.5cm wide (1.77"), 3 meters length, from eBay - that fits exactly for my base plate:
https://www.ebay.co.uk/itm/White-Black-Flat-Elastic-Band-Lingerie-Ribbon-Trim-DIY-Sewing-Dress-Making/273986223671
Just search for the "elastic band" in ebay.co.uk's "Crafts" section, or for "gummiband" in ebay.de's, and choose "Item location: worldwide" option
  • Redline 7000
  • Forum Moderator
« Reply #16 on: November 07, 2019, 07:47:44 AM »
This stuff is perfect for suspenders, too.     Some of this is sublimated creativity which can be your personal secret once installed. 2" available.
  • 1995 K75 72,000 miles
https://tinyurl.com/RillRider
Offline mdk_mdk
« Reply #17 on: November 07, 2019, 09:06:02 AM »
They make black zip ties....????
I've always used these:
  • Ringoes NJ
  • 1990 K75
Offline ffbikersa
« Reply #18 on: November 07, 2019, 02:52:30 PM »
Zip ties? What these have to do with elastic bands on tank bag base plates???
Offline volador
  • NEEDS MORE CHROME
« Reply #19 on: November 07, 2019, 05:04:44 PM »
A man after my own heart
  • NYC NY
