Author Topic: Headlight bulb conversion  (Read 1099 times)
Offline Soggz
« on: September 20, 2019, 04:04:59 PM »
To LED.
Is there a led bulb available for the k75?
Thanks in advance.
  • Down in Selwood Forest
Online The Mighty Gryphon
Re: Headlight bulb conversion
« Reply #1 on: September 20, 2019, 04:58:10 PM »
Do you want an LED replacement that works properly and is legal?
If the answer is no, there are a lot of LED H4 replacements out there, some of them are pretty cheap, too.
If the answer is yes, then you need to wait.  There are no LED H4 replacements that meet D.O.T. requirements for pattern and scatter.
'91 K100RS "Moby Brick Too
'89 K100RS SE
Offline Soggz
« Reply #2 on: September 20, 2019, 07:10:11 PM »
just something that works,really.
Online stokester
« Reply #3 on: September 20, 2019, 07:22:56 PM »
As a former licensed Virginia State Inspector I've had this discussion with many riders.
You are correct, and in the Commonwealth of Virginia the installed bulb must match the embossed label on the headlight assembly.  Most inspectors will not go to that extent to fail you on an inspection but by the law it is still not allowed.  It is the same with cars.  If the headlamp says H4 and you have an HID or LED bulb in there it does not pass inspection.
There is a reason for this.  The light pattern of the original bulb was matched to the headlamp assembly and frequently an improper replacement will not illuminate the road according to the law.
  • Yorktown, Virginia
  • '94 K75S Dakar Yellow - '93 K75S Seiden Blau - '91 R100RT Dark Blue- '78 R100S Smoke Red
Online Filmcamera
« Reply #4 on: September 20, 2019, 09:05:50 PM »
I had a dodgy LED for a while but though bright it was rubbish.
In the end I went this route
http://www.easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html
with this bulb
https://www.amazon.com/BREAKER-Halogen-Headlight-64193NBL-Folding/dp/B01LLKFX8Q/ref=dp_ob_title_auto
It is not quite a bright as an LED but saves your switches and has the proper pattern.  For out and out brightness I have some cheap and cheerful spots added.
  • San Jose, Costa Rica
Poserbricker
« Reply #5 on: September 20, 2019, 09:37:29 PM »
Use a legal high wattage H4 bulb, add a relay and if that's not bright enough add a couple of auxiliary LED spots or a LED light bar.
Offline Chri5
  • Buy it - Break it - Rebuild it!
« Reply #6 on: September 20, 2019, 10:32:04 PM »
You wont pass an MOT with an led bulb in the stock housing the new mot rules (2018) have been tightened. aftermarket led bulbs in normal housing are strictly prohibited unless your on good terms with the inspector and hes willing to fudge it for you
But you can always swap the bulbs for the mot but watch out for vosa vehicles they will pull you for it as its easily spotted
  • United Kingdom
  • K100RS
Yamaha FZ6n-s2 electric conversion(Electric motor 240nm of instant torque)
Kawasaki Z750R
85 BMW K100RS
Buy - Break - Rebuild - Repeat!
Offline Soggz
« Reply #7 on: September 21, 2019, 02:28:45 AM »
Ok.
Thanks all. Basically, the reason Iím asking, is that
my low beam went out last night, so I was thinking that while I had all the cowl off to change the bulb, would it be worth me putting an led in.
Where would I get the twin spotlights from, And is it easy to wire them in? ( Iím not good at electrickery).
« Reply #8 on: September 21, 2019, 03:06:55 AM »
Ebay or Aliexpress I picked up 2 x 6" light bars for $16.00 Au. The bricks should really be fitted with a relay to stop the switch from overloading., see Eastern Beaver. With a relay fitted it is easy to wire in the auxiliary lights to the high beam circuit with a separate switch to switch off when not required. There are also heaps of wiring diagrams on the net.
Offline Soggz
« Reply #9 on: September 21, 2019, 03:09:01 AM »
Thanks Martin.
« Reply #10 on: September 21, 2019, 10:01:55 AM »
I just bought an Eastern Beaver harness for the "new" brick.  They now have an option for a pigtail to power driving lights from either the hi or lo beam.
These relay harnesses are the best upgrade you can make to your brick.
'89 K100RS SE
« Reply #11 on: September 21, 2019, 10:18:14 AM »
eastern beaver user here... osram was my go to bulb... then catz hyperwhite which is no longer imported from japan... then back to osram... they discoed the ralley which was one of the best... now my go to bulb guy says the vosla is now his go to bulb...
i have 1 more spare catz hyperwhite on the shelf... the catz hyperwhite is what is in the herseyb rs eleven hundert... those things are amazing... bonsai tora tora tora...
yeeeeeerhaaaaaaa...
« Reply #12 on: September 21, 2019, 12:41:57 PM »
JO, how's the life of your Osram bulb on the Eastern Beaver harness.  I found that bulb life went down a lot, probably because the bulb was seeing more voltage and current which put lots more light downrange.  Right now I'm averaging about 15,000 miles per bulb on Ilsa, the horizon chaser.
That Vosla bulb looks interesting.  I might have to put some in the fleet this winter.
'89 K100RS SE
« Reply #13 on: September 21, 2019, 02:22:13 PM »
caints say cause i dont know... butts the sylvanias didnt seem to last that long... the catzs certainly didnt last that long... butts the osrams did seem to last longer than the rest...
Offline Soggz
« Reply #14 on: September 21, 2019, 04:48:17 PM »
Problem solved. Took the cowl off to reveal the top connected in the bulb block had come out. Bulbs ok.
« Reply #15 on: September 21, 2019, 05:45:46 PM »
You still need to fit a relay if you want to avoid future switch problems.
Offline Soggz
« Reply #16 on: September 21, 2019, 07:11:33 PM »
Thanks Martin. How do I go about doing that please?
« Reply #17 on: September 21, 2019, 07:23:08 PM »
Eastern Beaver kit is recommended by a lot of Brick riders. And as per Gryph you might want to get the one with the facilities to add driving lights or fog lights. Buying the kit will make it a lot easier for an electrical novice to fit it.
Offline Soggz
« Reply #18 on: September 21, 2019, 07:29:21 PM »
ok. Thanks. Is it available in the uk?
« Reply #19 on: September 21, 2019, 07:38:46 PM »
Seek and ye may or ye may not find. It can be ordered from the US.
Online Laitch
  • Redline 7000
  • Forum Moderator
« Reply #20 on: September 21, 2019, 08:16:20 PM »
It'll be shipped from Japan regardless of where it's ordered. The UK isn't on EB's no ship list. Google Easter Beaver relays and go directly to the site.
  • 1995 K75 72,000 miles
https://tinyurl.com/RillRider
Offline Soggz
« Reply #21 on: September 22, 2019, 04:19:27 AM »
Hey, thanks.
Offline Soggz
« Reply #22 on: September 22, 2019, 04:25:05 AM »
Erm... looked on the site. Which one do I need, please?
Online Laitch
  • Redline 7000
  • Forum Moderator
« Reply #23 on: September 22, 2019, 05:39:10 AM »
It might be that one or the other of the H4 Single 'In Shell' Relay Kits will work for you based on your confidence about installing using Posilocks and shrinktubing. Plenty of YouTube videos are available on both products. The LO Cut option is unnecessary. It also depends on how the wiring is configured into that headlight fairing. As Martin and The Mighty G have indicated, get the kit with the two extra leads if you can see driving lights in your future.
Offline Soggz
« Reply #24 on: September 22, 2019, 06:04:26 AM »
Ok, yes, Iím no good at electrics, as I said. The loom comes from under the tank to the headlight plug. Thatís about it really. There is no indication that anything goes into the shell.
There is plenty of room in the cowl, as there is a redundant alarm system in there that can come out as it dosnt work.
