Author Topic: Cam chain problem  (Read 407 times)
Offline Boxermann
Cam chain problem
« on: September 12, 2019, 08:31:13 AM »
Hi,
So... I've had the header off, and now when I've assembled it I can't turn the engine. I can turn the cams and crankshaft, but as soon as I mount the chain it's stuck after half a turn. What obvious thing have I've missed?
1987 K100
  • Norway
  • K100 / '87, K75 / '87
  • Redline 7000
  • Forum Moderator
Re: Cam chain problem
« Reply #1 on: September 12, 2019, 09:15:28 AM »
Exactly what type of work was done that needed removal of the header? Are you referring to the exhaust manifold, or the cylinder head?
  • 1995 K75 72,000 miles
https://tinyurl.com/RillRider
Offline Boxermann
« Reply #2 on: September 12, 2019, 12:47:59 PM »
Cylinder head. I replaced the head gasket.
  • Norway
  • Forum Moderator
« Reply #3 on: September 12, 2019, 01:08:38 PM »
From where I sit here in my chair, it sounds like your physical crankshaft/camshaft timing is not correct.
Ride safe.
1997 K1100LT 0302488
Garmin StreetPilot 2820
Garmin Zumo 550
  • Redline 7000
  • Forum Moderator
« Reply #4 on: September 12, 2019, 01:40:46 PM »
As Scott_ indicates, installation of the camshafts without a loads on their cams, camshaft sprocket alignment and agreement of camshaft sprocket alignment with crankshaft alignment are critical. At which fitting are you rotating the crankshaft? With which tool are you rotating it? In which direction are you rotating it? Are the spark plugs installed?
Offline Boxermann
« Reply #5 on: September 12, 2019, 07:07:46 PM »
Thanks guys. Yeah, I think I just have to start over.
At the ignition rotor flange retaining bolt with an allen key, anticlockwise. Plugs out.
  • Norway
Online Chaos
« Reply #6 on: September 12, 2019, 09:59:48 PM »
hmmm, are K's interference engines?  I don't recall it ever coming up before.
2012 Ural 2WD sidecar (BMW's bastard step child)
