Author Topic: Change wheel Bearings???  (Read 1927 times)
Offline beemrdon
« on: September 10, 2019, 11:08:12 PM »
Well Hello there ya'll,
A question for the K brain trust.
My K1100 has almost 124,000 miles on the odo now and I am wondering if I should change the front wheel bearings as a preventive measure. I thought I heard that BMW recommends swapping the out at every 30k, which most likely nobody does.
Thanks
  • The South West... best motorcycling in the US! Longest riding season = 12 months per year
  • 1996 K1100 LT SE, Aspen Silver - Now with 159,xxx miles.
Re: Change wheel Bearings???
« Reply #1 on: September 11, 2019, 12:03:42 AM »
You're correct. The BMW service schedule I have calls out wheel bearing and swing arm bearing replacement at 25,000 mile intervals. I replaced my moto's front wheel bearings at 60,000 miles because there was slight play in them. I used a bearing puller from AutoZone by leaving a credit card deposit of approximately $120. There was no charge for its use and I was allotted 10 days to use it. Once the wheel was off, extraction took ten minutes, including bird-watching. The spacer can be reused but I installed a new one.
https://tinyurl.com/RillRider
Offline koapono
« Reply #2 on: September 11, 2019, 04:30:03 AM »
do you have "play" in the bearings? wheel still on the scoot? remove brake calipers to eliminate drag and give the wheel a spin, both ways. then Check for any side-to-side movement.
Front wheels just roll merrily along, my 85 still has original bearings on the front. Some last forever, some don't make it around the block.
you'll find age is not a discriminator and should not be the sole source for replacing items.
ride on!
  • 1994 K1100LT
« Reply #3 on: September 11, 2019, 07:52:46 AM »
ride on!
+1  Why make ownership more expensive than it has to be?
« Reply #4 on: September 11, 2019, 08:10:36 AM »
i gotts a front wheel with 2 hundert on it and another with 1.5 hundert on it...  wheel bearings are still 100%...
swing arm bearings and rotor bobbins are a different matter...
i think properly lined up shaft and properly lubed up shaft and properly lubed up spacers everytime the wheel goes back on is key to wheel bearing life...
and bouncing the front tior on the ground  with the front brake locked before tighting the pinch bolts makes a difference too...
Agree Agree x 2 View List
Offline Soggz
« Reply #5 on: September 11, 2019, 03:14:36 PM »
My K has done about 78k,now. I’m the 13th owner. I don’t even know if it got the original wheels!.lol
  • Down in Selwood Forest
