Author Topic: Greetings and Questions about K75  (Read 8051 times)
Re: Greetings and Questions about K75
« Reply #75 on: September 14, 2019, 11:31:57 AM »
gay bmw ridors are not bikers... bmw ridors are motocycle enthusiasts... some with higher noses than others...
some wear no socks... some wear rainbow socks... some wear purple socks...
* yeeeehaaaa.png (187.79 kB . 444x496 - viewed 224 times)
  • Redline 7000
  • Forum Moderator
« Reply #76 on: September 14, 2019, 11:49:42 AM »
A feather boa. Perfect.
  • 1995 K75 79,000 miles
https://tinyurl.com/RillRider
« Reply #77 on: September 14, 2019, 01:17:13 PM »
They look to be pretty close to the same size.
They really aren't. The LS is just closer to the camera, the jump to the K is significant in weight, & power.  Never had a low seat so I can't really comment on them but never had much trouble with the height of the k75.  I have the 3/4" shorter shock and lowered the forked tubes 1/2" in the triple clamps.  Can't quite flat foot it but it's no big deal.  The LS back then was refinement of a many decades old design, the K was ahead of it's time.  The difference was like jumping from a bugeye sprite to a 911.  Never missed or regretted selling the LS, nor have I felt the need for something more modern than my K.  But that's strictly a personal opinion.
2012 Ural 2WD sidecar (BMW's bastard step child)
Offline volador
  • NEEDS MORE CHROME
« Reply #78 on: September 14, 2019, 02:24:30 PM »
They look to be pretty close to the same size....
What a dilemma!
Geez, imagine going shopping with you?
Oy vey!!!
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
« Reply #79 on: September 14, 2019, 03:07:34 PM »
Interesting site that may help or may totally confuse you.https://www.bikesales.com.au/editorial/details/cycle-ergo-bike-size-test-22558/ And at 5'7" with the legs of a penguin if I can sit on a 75 with bent knees so should you.
  • Redline 7000
  • Forum Moderator
« Reply #80 on: September 14, 2019, 03:28:01 PM »
. . . with the legs of a penguin . . .
Let's not bring birds and beasts into the discussion, Martin. It's already unsettling enough for some people.
« Reply #81 on: September 14, 2019, 03:50:04 PM »
Sorry Laitch I'll try to refrain from animal comparisons. However at the time of the operation that was all that was available. As a result I'm a much better swimmer now.
Regards a contrite Martin.
  • Redline 7000
  • Forum Moderator
« Reply #82 on: September 14, 2019, 03:58:29 PM »
:-D
Offline Scott
« Reply #83 on: September 30, 2019, 12:11:32 PM »
 Hi, I've got a 30" inseam and can easily flat foot the low seat (1993) k75, so i think it will fit you okay even with less inseam to work with.  Seat height in itself isn't the end all on comfortably reaching the ground, also to be considered is how fat the seat is at the front.  When it's wide, it will push your legs out more making in effect a longer reach to the ground.
 On ABS, i wouldn't be stuck on that, rather find a nice, low mile, well maintained example and if it has ABS great, but if not you won't miss it probably.  Personally I search out models without ABS for less complexity and the extra plumbing that comes with the system.  Good brakes, and proper application of the brakes is key to survival in my opinion.  Unless you plan on riding a lot in rain, or in icy conditions, probably isn't necessary.  Good luck with your searching.  scott
Edited to add pic, this is a stock low seat, really low, Just like my r100r Mystic, same height i think.
* K75_090.jpg (72.32 kB . 768x432 - viewed 160 times)
  • SoCal
  • bmw R100r, bmw k75, hondapotamus G/W, XT 500 enduro
Offline Past-my-Prime
« Reply #84 on: October 18, 2019, 07:07:24 PM »
I only just now learned that Motobrick is a “virtual gay bmw biker bar.”  My fault for not checking the aggregating sites before signing up.  No judgement - - just not my thing.
Thanks to those who provided helpful info.  Safe riding to all.
It is?  I was unaware of aggravating sites but maybe I need to  check them.
Anyway, at 5;10", and 32" inseam, K75 which in my case is normal seat is easy to get both feet flat on the  ground. It's hardest to move around at a stop. Mine has gotten tired and laid down a couple times, always at a dead stop or nearly so. A few times as I was trying to get onto center stand.
Engine protection bars and tragkorbs help a lot, you don't have to lift it so far.
PS if you do get one, don't forget to lube the splines. I found lack of spline lubrication to be a real pain in the ass.
  • North Shore of Lake Superior
  • BRICK: 1989 K75 RT - Rocinante; NONBRICK: 2007 F650 GS Dakar - not yet named
Offline Rcgreaves
« Reply #85 on: October 21, 2019, 04:04:55 PM »
At 5'7" and 29" inseam my low seat conversion this past summer was next to installing radials the best mod I've done.  And yes Mystic Red is faster.
My first brick was non ABS my current is Gen 1 ABS.  I can push the brakes farther, deeper with the ABS ready to "click click click" when adhesion ends.  I like.
My current project is Gen 2 ABS.  My 94 with 70k I paid a premium, 3k, knowing  I could click up 10k miles without a thought of doing major service except spline lube.  In October a reasonable garage queen on Craigslist is a $1500 idea.
My current K1100 was a $500 Craigslist find. Fill piggy banks, be patient.
  • Livingston, SW WI. USA-"With the good earth all around."
  • Newest Resto: 96 Honda Interceptor VFR750F, Also Restoring: 1995 K1100RS, 1994 K75S ,1985 Goldwing Aspencade
Doing “better than I deserve”
« Reply #86 on: October 23, 2019, 08:39:57 PM »
seibenwhack hemmerroid... getts that thing off there...
* 20191023_193835.jpg (19.98 kB . 388x576 - viewed 98 times)
« Reply #87 on: October 23, 2019, 09:30:47 PM »
OMG!!!  My eyes!!!
'91 K100RS "Moby Brick Too
'89 K100RS SE
« Reply #88 on: October 24, 2019, 08:00:49 PM »
It's a Weber.
Offline volador
  • NEEDS MORE CHROME
« Reply #89 on: October 24, 2019, 08:32:30 PM »
  • NYC NY
