Author Topic: Greetings and Questions about K75  (Read 22911 times)
Offline VAK75
« on: September 02, 2019, 01:56:16 PM »
Hello all!
New member from Virginia, USA and prospective K75 purchaser/owner with a number of questions.  Hopefully I'm in the right place to ask them?
I'm in the early stages of researching the purchase of a K75.  I'm focussing on the K75 "standard" (is that the right terminology?) for the low seat height.  I also prefer the simple clean look of this version.  I'd like to find a late-model ('94/'95) with low miles and ABS.
My first questions concern the optional ABS.  Can this option still be added to a K75 that was not equipped with ABS from the factory?  If yes, is it an oem solution from BMW, or aftermarket?  If no, what is the general sentiment about the desirability of the ABS feature on a K75?  (I come across many good candidates, but they often lack ABS.)
My second question concerns oem or aftermarket saddlebags and associated mounting brackets/legs/hardware.  Are these readily available new?  If not, how difficult is it to find them on the used market?
I have more questions but will hold off - - don't want to overload you folks and not even sure if I've posted in the correct location.
Thanks!
  • Northern Virginia/Metro DC
  • No motobrick yet - - researching
Re: Greetings and Questions about K75
« Reply #1 on: September 02, 2019, 02:21:39 PM »
Welcome.
What is your motorcycle riding experience?
https://tinyurl.com/RillRider
Offline VAK75
« Reply #2 on: September 02, 2019, 02:35:05 PM »
to add abs to nonabs brick it will likely have to be oe... you will have to source all the components... will costs thousands for sure...
oe is the way to go for side bags and top box... they are available new and used... click on parts guidance and getts familure with the fische... butts you can fit anything on there f you have tools and skills and piggy bank...
you can find a seven fitty with everything you want if you are patient and wait for the right one to go up for sale...
Thank you.  This info is very helpful.
Offline stokester
« Reply #3 on: September 02, 2019, 02:41:01 PM »
Agree with Johnny. I would never attempt to add ABS to a non-ABS bike.  There are too many hoses, pipes, pumps, rotors, wiring and a computer to add that would make it not worth the cost or effort while there are fine bricks on the market if you are patient.
Here is an example I found nearby Craig's List -> https://easternshore.craigslist.org/mcy/d/ocean-city-1987-bmw-k75c/6960335395.html
While it does not have ABS it looks clean, has low mileage with cases and it appears the seller is knowledgeable of spline maintenance.
  • Yorktown Virginia
Offline VAK75
« Reply #4 on: September 02, 2019, 02:52:04 PM »
Welcome.
Thanks for the welcome.
My riding experience is very limited.  I took the MSF Basic course a few months ago.  Shortly after that, I purchased a small starter bike (2016 Honda Rebel 250) on which to practice and build my skills/confidence.  I have only logged about 500 miles on it so far.
But I live in a congested urban environment, so 100% of that is in pretty challenging riding conditions with tons of stop/go and traffic (I have seen references on this website to the detours riders take to avoid my
area.)  It usually takes 60-90 minutes to travel about 20 miles around here.  So my time in the saddle is more than the miles suggest.  But I have very limited time at highway speeds.
I recognize my inexperience, and plan to keep riding the Rebel for quite a while yet.  I may even keep it as a second bike when I eventually upgrade - - it’s actually a lot of fun to ride and well-suited to this area.  But these K75s interest me and due to their age will need a thorough going-over before using.  So I am beginning to sniff around.
« Reply #5 on: September 02, 2019, 02:54:05 PM »
Most bikes I see of the vintage you are interested in have both side cases and ABS.  Top cases are fairly easy to find if you aren't in too much of a hurry.
ABS is an OEM system.  There is too much stuff to put together to make the system work.  Personally, I have it on my bikes because they came with it.  It's nice because it gets an insurance discount of $10-20 per year.   I have actually activated the system only once to see if it was working.  Normally, I am leery of hitting the brakes hard enough to activate it because I don't want to find out it isn't working.  Alert defensive driving is more valuable to me than ABS.
Luggage is readily available on eBay along with the necessary hardware.  Adding it is strictly an easy bolt on task as long as the bike has the rack mounted on the tail cowl.  No big deal if the rack isn't there.  You just need to spend an afternoon removing the cowl and drilling four holes.
Offline VAK75
« Reply #6 on: September 02, 2019, 02:57:22 PM »
Copy, thanks.
So adding ABS is a no-go.   What is the consensus on the desirability of the ABS feature?  I know ABS is a good thing in theory,  but how is it holding up on 25-year-old bikes?  Reliable, or problematic?
Offline VAK75
« Reply #7 on: September 02, 2019, 03:00:27 PM »
Thank you.  Very helpful.
Offline volador
  • NEEDS MORE CHROME
« Reply #8 on: September 02, 2019, 03:02:24 PM »
Welcome!
I've seen this listing for some time in the NYC area. Clean looking moto, very low miles, looks like "C" type bars not Sport bars
I don't know if its Mystic Red or Marrech Red but I doubt you find another like it
https://newyork.craigslist.org/lgi/mcy/d/hampton-bays-1994-bmw-75/6965416034.html
Another Low Seat model recently listed
https://newyork.craigslist.org/mnh/mcy/d/new-york-1995-bmw-k75/6967337429.html
I saw another NYC K75s for sale from one of the MOE's here. Don't know if it was sold or not
Good luck with your search
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline BrickDad
« Reply #9 on: September 02, 2019, 03:16:40 PM »
Copy, thanks.
As with any brand-new technology, the 1st iteration is often imperfect.
So it was back in the 1980s with the BMW K-bikes, the very first motorcycles with ABS.
Their ABS was good... for the time.  In no  way was it a perfect system.  It was a 1st try at it.
Welcome to the forum - I have a K75 and am in central Arlington, likely right next door to you, figuratively.
My K75 started life as a "low seat" model.  It is now a "regular/aftermarket seat" model, by my choice.  It took me across the country this Summer.  Frankly, unless you are a VERY short person, I would advise a regular model because the Low Seat model has some significant storage and tool limits.
Go ahead and PM me if you want "life with a K75" -type advice, etc.
  • Arlington County, Virginia
  • 1995 K75T + Paralever, 1991 K100RS 4-valver + 1990 Flexit sidecar
« Reply #10 on: September 02, 2019, 03:29:08 PM »
. . . I live in a congested urban environment, so 100% of that is in pretty challenging riding conditions with tons of stop/go and traffic  It usually takes 60-90 minutes to travel about 20 miles around here.  So my time in the saddle is more than the miles suggest.  But I have very limited time at highway speeds.
Your Rebel is more suitable for chronic traffic congestion; furthermore, you'll develop much needed low-speed skill riding that moto in traffic. Low-speed maneuvering is an essential skill easier to learn and perfect on a moto lighter than a Brick. I recommend viewing Jerry Paladino's Ride Like A Pro Series. Once you've picked up that skill, it will make riding a larger moto more pleasurable.
The Brick wants to be run on the open road as frequently as possible. In congestion its fan will bathe the rider with heat periodically although the naked Brick will be cooler than one with a fairing.
An electric moto would seem to be ideal for congested traffic. More are becoming available on the used market.
Offline VAK75
« Reply #11 on: September 02, 2019, 06:09:20 PM »
Thanks for the ABS insight.
Yes, we are near neighbors.  Don’t be surprised to get a pm from me - - I would be curious to test that seat height.  I am only 5’ 7”, with a disproportionately short inseam (28”).  I was assembled from the spare parts bin.  The low seat height of “Standard” trim appeals to me - - I want to be able to flat foot.  As I understand it, the K75 standard had an oem low seat as standard equipment.  (Does anyone happen to know the seat height measurement?)
Incidentally, in your signature you list your 1995 K75 as a “T” model.  I thought the T was only made from ‘86-‘87?
Offline VAK75
« Reply #12 on: September 02, 2019, 06:10:04 PM »
Welcome!
Much appreciated.
« Reply #13 on: September 02, 2019, 06:17:29 PM »
. . . the K75 standard had an oem low seat as standard equipment.  (Does anyone happen to know the seat height measurement?)
. . .I thought the T was only made from ‘86-‘87?
According to Phil Hawksley's site, 29.90 inches is the low seat height.
As far as the T designation goes, don't get tangled in minutiae.
Offline VAK75
« Reply #14 on: September 02, 2019, 06:27:02 PM »
Thanks for the tips.  Like said, I expect to be on the Rebel for a good while.  And if possible will hold onto it after acquiring my “next bike.”  It is a great platform for practicing skills, and for riding around here.
I am considering the K75 for other purposes.  The Rebel is a great bike, but highway cruising is not it’s strong suit.  I would be using the K75 for longer road trips, cruising with camping gear, etc.
How much does a K75 Standard weigh?
« Reply #15 on: September 02, 2019, 06:38:53 PM »
Slightly over 500lbs with all fluids and ready to ride. The Rebel weighs approximately 330lbs. The Rebel has approximately 16 horsepower; the K75 has around 65 horsepower. Experience, good judgment, coordination, upper body strength and humility would be helpful to have before you climb on one.
Offline BrickDad
« Reply #16 on: September 02, 2019, 06:55:43 PM »
You are welcome to sit-test... I have a very nice used Corbin seat and I junked the OEM low seat.
My bike was ordered by the original owner (as relayed to me by the 2d owner) with the "Touring" plexiglass windshield.  It is a late model (1995)K75 with the standard, or "C" handlebars, a huge round headlight, OEM "City" baggage cases and the OEM 22-liter top case, and this windshield.  I therefore call it a "T" because it is decently set up for touring.
Hope this helps.
BTW - in my experience on several bikes, "flat-footing" while at rest, although reassuring, is not really necessary as long as the rider's toes can touch the pavement on both sides.  By contrast, bikes designed to sit the rider low can be quite hard on our tail bones at the bottom of the spine, because the lower the bike, the more weight that body area has to support.  Also, on "low" bikes the seat material is often skimpy, adding to the problem.  Both these factors often manifest on longer rides.
« Reply #17 on: September 02, 2019, 07:02:33 PM »
poast up some photos of this t...
you can call it whats its not... butts i wanna see whats it is and was birthed...
some folks call this a " t "...
* 00101_ae1CTC8sSB0_600x450.jpg (45.74 kB . 600x450 - viewed 448 times)
Offline volador
  • NEEDS MORE CHROME
« Reply #18 on: September 02, 2019, 07:50:48 PM »
That must be " t " for tall windscreen
Here is one more in your own state. This is one sharp looking K75C ABS !
https://ibmwr.org/index.php/ibmwr-marketplace/show-ad/3219/1994-k75c/falls-church/virginia/united-states/brick-k-bikes-1983-2003-bikes-for-sale/
  • NYC NY
Offline VAK75
« Reply #19 on: September 02, 2019, 09:18:21 PM »
Thanks.  Yeah, I have spoken with the owner.  It seems like a really nicely fixed-up K75.  Unfortunately he did a seat conversion to raise it up several inches.
I have a gimpy ankle/foot and flat-footing works best for me.
Offline volador
  • NEEDS MORE CHROME
« Reply #20 on: September 02, 2019, 11:20:09 PM »
Low seat and associated mounting hardware can be found and most of the mounting parts are still available at MAX BMW
This MOE was looking to trade his low seat for regular seat
http://www.motobrick.com/index.php/topic,12729.msg112806.html#new
  • NYC NY
« Reply #21 on: September 02, 2019, 11:29:27 PM »
keep watching the local clist and be patient.  i got both of my K75's through the DC clist.
although the ABS on these bikes is first generation and  very primitive, it works.   if the bike is maintained well the system is very reliable.  make sure it is working on any bike you look at.  easy to tell, there should be no lights flashing in the cluster after rolling the bike a short ways and hitting both brakes.  i intentionally excercise mine regularly.
Offline E30_Crazy
« Reply #22 on: September 02, 2019, 11:56:37 PM »
+1 for the Seller. Great guy. Bought my K1100RS from him. I believe he has a couple ads up. He was downsizing his fleet when I was visiting/purchasing.
  • Newport News, Virginia
  • '85 K100, '93 K1100RS
Offline VAK75
« Reply #23 on: September 03, 2019, 10:03:57 AM »
Thanks for the encouragement.
As far as testing the ABS, when you say “after rolling the bike a short distance”,  is that with the engine on or off, in gear, etc?  Just trying to better understand the test procedure.  Thanks.
PS  It looks like you are another local-to-me K75 owner.
« Reply #24 on: September 03, 2019, 12:17:18 PM »
the abs has a self test procedure on start up.  start bike, start riding, hit both brakes, the two red lights on dash should go out.
