Author Topic: Turn signal whack revisited  (Read 27496 times)
Offline beemuker
Re: Turn signal whack revisited
« Reply #50 on: August 30, 2019, 12:47:54 PM »
Check power on the relay Pin 15 (Green/Black)
Check power on the relay Pin 58E (Grey/White)
If power is present and in spec on these wires, then another thing to try is to open the flasher module and reheat the solder joints where the pins join the PCB.  Sometimes the solder joints go cold and don't make a good connection.
got power and Inspec on the green black got power and Inspec on the green black  don’t have a gray white and no marking for a 58E on my flasher module
  • Panama City, FL
Offline beemuker
« Reply #51 on: August 30, 2019, 01:15:31 PM »
The grounds from the switches look good
  • Panama City, FL
Offline beemuker
« Reply #52 on: August 30, 2019, 01:53:40 PM »
Daveson, where is the looms socket, is it one of those under the clear plastic protectors, and how do you get them apart without cutting the plastic? mine are not flexible anymore, and exactly how do you test it?
update: got them apart and tested the grounds, tested fine
  • Panama City, FL
Offline beemuker
« Reply #53 on: August 30, 2019, 02:10:33 PM »
Has rbm's suggestion in Reply #5 of heating likely cold solder joints within the flasher unit been undertaken yet? If not, why not? I don't see that checked off in the list.
no
the joints look good, no movement , no cracks. I don't have a good soldier iron and am afraid of messing up a possibly good and expensive part. I will see if I can borrow/buy a better iron and get to this if nothing else fixes the issue.
Gota possibly bigger problem named Dorian
  • Panama City, FL
Offline daveson
« Reply #54 on: August 30, 2019, 05:40:30 PM »
So the indicators are stealing earth because they have none of their own. The clear plastic cylinder thing on the left is stuck to its loom.  Prise something thin in between,  very carefully,  then wd40 or something, then slide it back.  Disconnect the plug, give it a good clean.
I use electrical circuit board cleaner,  but deoxit seems to be the go. Whenever I ask for it in a shop,  I get looked at funny,  I say don't look at me,  l don't know what I'm talking about either.
Clean it as best you can,  then dry it,  put it back together.  Now test your indicators, horn and light  switches. Then do the right side,  then test your switches again, especially on your right handlebar.
On the frames central bar,  on the left,  you will see a bunch of brown wires bolted to it. Doesn't matter if they look good, scrub them, spray cleaner on them, dry them,  clean them real good. Clean each one separately. Test your switches again.
If lucky,  your indicators will now work properly. Look for any exposed wires and wear spots. Then clean all the other plugs. Look on the left,  for the wear spot mentioned earlier. There should be a rubber grommet to protect wires exiting the relay box.
With your fingernail flat on the horn relay and a short press on the left indicator, you might feel a vibration, then that is where the noise is coming from. The left indicator is trying to steal earth from the horn,  but failing, good.
  • Victoria, Australia
Offline beemuker
« Reply #55 on: September 01, 2019, 03:51:29 PM »
Tried all that, I was not lucky. I'm ready to put the tank back on and see if I can source a not so expensive flasher module. at least I may be able to eliminate that as the problem.
  • Panama City, FL
Offline beemuker
« Reply #56 on: September 01, 2019, 03:54:50 PM »
check all yourn fuses... they all gonna checks good... right...
replace all of them with new unused fuses...
try it... you gotts flashing... then remove fuse 3 and try it... you gotts nothing or flashing... what is it...
when I remove 3 I gots nada
  • Panama City, FL
Offline daveson
« Reply #57 on: September 01, 2019, 04:58:12 PM »
Before you put the tank back on,  a couple of quick,  easy questions.
How do the indicators work with the turn cancel switch unplugged? It's brown white,  with its own plug,  goes into the plastic cylinder on the right hand side.
How do the indicators work with the instrument cluster unplugged?
Do these tests with the hazards unplugged.
About one inch in front of the normal tank position,  on the front,  left hand side, the loom may be rubbing against the vertical black infil panel,  which surrounds the area where the forks pass through. There could be some exposed wires there.
When the indicators worked like hazards,  were both indicator warning lights on the instrument cluster working, or just the side that you pressed?
Offline beemuker
« Reply #58 on: September 01, 2019, 05:23:15 PM »
too late. put the tank back on. tried to start. no start. did I remember to connect fuel pump plug. no. connected it. still no start. don't heat the fuel pump charging. good grief. I did pull the relays to clean the contacts and they might not have gotten in the same places, but the 3 look the same and have the same part #. I guess I'll be pulling the tank off tomorrow and will get to your questions. how /where do I unplug the hazards and inst cluster?
When I turn the hazards on , then off , the left stays flashing until I turn the hazards off or depress either r or l turn switch.
  • Panama City, FL
Offline mw074
« Reply #59 on: September 01, 2019, 07:08:34 PM »
 Beemuker, I have a good used flasher relay if you need to replace it.
02    61 31 1 459 224    RELAY FOR FLASHER   0.26    1     $199.59
  • Michigan
Offline daveson
« Reply #60 on: September 01, 2019, 07:21:58 PM »
So you have cleaned all the items on RBM's list except the indicator switches.
I think if you clean the left indicator and horn connections, your left indicator will then work.
Then clean the right, and the cancel switch.
You gotta do it in a bucket or something, so you don't loose springs and stuff that might fly out.
Offline beemuker
« Reply #61 on: September 01, 2019, 09:22:16 PM »
so do you take them apart by loosening the small philips screw inside once you take it off the bar? then clean
  • Panama City, FL
Offline daveson
« Reply #62 on: September 01, 2019, 10:14:46 PM »
I havn't had to do it yet.
You could read up on it first or just go for it and see how it goes.
Offline daveson
« Reply #63 on: September 01, 2019, 11:38:29 PM »
Try this shortcut before dismantling the left switch. With the switch removed you will see where the blue/brown wire has been soldered  at the back. With a test light clip connected well to the battery negative post, touch the probe to the blue/brown soldered spot.  Scratch it well for a good contact, or with the probe flat for a longer contact area. The left indicators might now work, then you know that the left switch has failed to provide earth and you need to dismantle it. The help of the probe might even shake things up a bit for the switch. Try with the probe and pressing the switch. No luck first time,  give it a few goes. Or even better, a jumper wire with a fuse.
Offline beemuker
« Reply #64 on: September 02, 2019, 11:53:46 AM »
ok, will try, any idea why moto will not start. I can hear the pump .
  • Panama City, FL
« Reply #65 on: September 02, 2019, 04:10:06 PM »
The first thing that I do on a non starting bike is check the spark plugs. Are they wet or dry???
Offline beemuker
« Reply #66 on: September 02, 2019, 04:24:44 PM »
will do, but I could smell gas. I must have disconnected or neglected to reconnect  something, I tried to clean all the connectors under the tank.  .
  • Panama City, FL
« Reply #67 on: September 02, 2019, 04:48:18 PM »
If your smelling petrol, it could be a faulty temperature sensor or a dirty connection. Pull the fuel pump fuse # 6 Krafftstoppe and try and start on the residual fuel in the combustion chamber. If it starts it will eventually die as the fuel runs out, but it can be kept running by ramming the fuse home and throttle manipulation before it dies. It won't be running smooth, more like a hairy goat. I've managed to limp home twice by doing this.
The sensor is in a bad position and is subjected to water and road crap. I use heavy silicone grease around the connection in the hope that it will keep out the crap. I have thought about using self melding silicone tape but it would require more effort to get it off if a problem should occur.
Offline beemuker
« Reply #68 on: September 02, 2019, 05:21:40 PM »
thanks I think it’s just something like the Killswitch connect Or something else I just left disconnected I’m gonna take the tank off and look around and see if I see anything obvious I’ll report back thanks again
  • Panama City, FL
Offline daveson
« Reply #69 on: September 02, 2019, 05:51:37 PM »
You got the green neutral light on the instrument cluster?
Which reminds me,  when for example you pressed the left indicator, did you have six lights on  (4 indicators and 2 warning lights on the instrument cluster) or five lights (4 indicators and the left warning light?)
Offline beemuker
« Reply #70 on: September 03, 2019, 09:11:10 AM »
thanks, but if you want 200 for it,  I can buy a used one on fleabay for $70.
  • Panama City, FL
Offline mw074
« Reply #71 on: September 03, 2019, 09:24:14 AM »
 I was just listing the OEM part number. $50. plus shipping for it.
  • Michigan
Offline beemuker
« Reply #72 on: September 03, 2019, 09:54:34 AM »
thanks. if the other solutions don't pan out, i'll probably take you up on it, just to eliminate that possibility.
  • Panama City, FL
Offline beemuker
« Reply #73 on: September 03, 2019, 09:57:33 AM »
6 lights on. and I have the neutral light.
  • Panama City, FL
Offline beemuker
« Reply #74 on: September 03, 2019, 10:33:48 AM »
tried to start and checked the plugs, they looked dry, but when I removed the hose at the fuel rail, gas shot out, so the fuel was pressurized so the pump is working?, and I'm getting spark, ground the plug and cranked while I had the plugs out. ????
I'm going to remove the tank now and see if I've left anything disconnected.
  • Panama City, FL
