Author Topic: Spline Lube Lube  (Read 837 times)
Spline Lube Lube
« on: August 16, 2019, 08:52:42 AM »
Rotella SD
The special-duty moly grease, Shell Rotella SD grease, is formulated for vehicle and equipment lubrication. Made with a moly solid lubricant (molybdenum disulfide), itís designed for demanding applications that are subjected to the high shock loads of rapid starts and stops, impacting chassis points, sliding pins, trailer hitches, and axle splines.
any questions...
* Shell_Rotella_SD_Grease.5c3d01d6cfbdc.jpg (13.49 kB . 149x576 - viewed 184 times)
Offline beemuker
Re: Spline Lube Lube
« Reply #1 on: August 16, 2019, 09:14:41 AM »
yes, what is the moly %?
  • Panama City, FL
  • 94 K75s , Dakar yellow ABS
« Reply #2 on: August 16, 2019, 09:33:16 AM »
It isn't on the data sheet so it's proprietary information that Shell doesn't feel is important to disclose. Trust the packaging; it has a strong sense of industrial competence. The empty tube can be re-purposed for cake decorating. That's a plus.
  • 1995 K75 72,000 miles
I wept because I had no radials until I met a man who had no splines.
http://www.motobrick.com/index.php/topic,296.msg53303.html#msg53303
Offline Soggz
« Reply #3 on: August 16, 2019, 10:03:56 AM »
or holding over quarter of an Oz of ground up skunk.
  • Down in Selwood Forest
Offline Soggz
« Reply #4 on: August 16, 2019, 10:40:34 AM »
 :jsdd lol. Where did this come from?
Offline Soggz
« Reply #5 on: August 16, 2019, 10:42:18 AM »
What about just mixing your own grease up with moly powder? That got to be better, hasnít it?
You can make it really thick, then.
« Reply #6 on: August 16, 2019, 11:31:16 AM »
That probably isn't as carcinogenic as inhaling paper fumes but let us know its outcome as your vaping choice.
Offline Soggz
« Reply #7 on: August 16, 2019, 11:39:09 AM »
better in cakes...
« Reply #8 on: August 16, 2019, 01:17:18 PM »
better in cakes...
Kidney pie and skunk cakeóI can almost hear the squeals of delight from over there.
« Reply #9 on: August 16, 2019, 02:40:51 PM »
i know a guy...
* 41dJ8AfArZL._AC_SY400_.jpg (13.79 kB . 183x400 - viewed 160 times)
Offline Soggz
« Reply #10 on: August 16, 2019, 02:44:30 PM »
I donít eat animals organs, either.
« Reply #11 on: August 18, 2019, 11:56:40 AM »
* enduralast.jpg (34.98 kB . 250x250 - viewed 140 times)
enduralast lube 477...
Online Past-my-Prime
« Reply #12 on: August 18, 2019, 12:55:15 PM »
Seek and ye might just find:
  • North Shore of Lake Superior
  • 1989 K75 RT
« Reply #13 on: August 18, 2019, 01:59:58 PM »
Looks to me that there are a number of options for spline lube.
I think the most important thing is to ensure we do it regularly, for me the rear every tire change and the clutch 20K.
These work for me on the Bricks and Airheads and will last a long time if used properly.
  • Yorktown, Virginia
  • '94 K75S Dakar Yellow - '93 K75S Seiden Blau - '91 R100RT Dark Blue- '78 R100S Smoke Red
« Reply #14 on: August 18, 2019, 03:10:58 PM »
Right there is a lucid approach to maintenance. New owners, take note!
« Reply #15 on: August 18, 2019, 03:35:38 PM »
and your 80K brick's splines may look like this...
« Reply #16 on: August 18, 2019, 04:33:46 PM »
* 20190818_150206.jpg (31.36 kB . 576x576 - viewed 133 times)
Offline Soggz
« Reply #17 on: August 18, 2019, 06:08:52 PM »
I just made my own. Iíll take the wheel off in a couple of months to see how itís doing.
« Reply #18 on: August 19, 2019, 05:37:47 AM »
* 41UXyEDcFPL._AC_SY400_.jpg (10.29 kB . 101x400 - viewed 128 times)
Offline Soggz
« Reply #19 on: August 19, 2019, 03:41:11 PM »
Ultimately,make your own!
« Reply #20 on: August 19, 2019, 05:12:42 PM »
The Julia Childs of spline lubrication has rendered a decision. :popcorm
« Reply #21 on: August 20, 2019, 03:25:12 PM »
* 31ToWYpoJ0L._AC_SY400_.jpg (9.24 kB . 133x400 - viewed 101 times)
« Reply #22 on: August 21, 2019, 10:50:32 AM »
* 51U6vooiclL._AC_SY400_.jpg (25.19 kB . 284x400 - viewed 93 times)
Offline Soggz
« Reply #23 on: August 21, 2019, 11:45:11 AM »
Didnt realise they greased the marines in America. Is that why they are slippery characters in war?
« Reply #24 on: August 21, 2019, 11:55:50 AM »
It isn't for battle; it's used on weekend passes.
