Author Topic: Hydraulic clutch- K100  (Read 720 times)
Offline GaryFrank
« on: August 03, 2019, 03:58:58 PM »
Has anyone fitted a hydraulic clutch to the K100?
I need to replace the right handlebar switch on my K100 and have a VFR800 that I can use as a parts doner.
The VFR has a hydraulic clutch....
  • Cape Town
  • K100 RS
Re: Hydraulic clutch- K100
« Reply #1 on: August 03, 2019, 04:50:47 PM »
i suspect replacing switch with correct k-bike one will be A LOT EASIER AND CHEAPER than trying to kludge on a complete master, slave and reservoir hydraulic clutch system from a completely different bike.
and you mean LEFT switch?  not sure how the right switch is related to the clutch..
Offline GaryFrank
« Reply #2 on: August 03, 2019, 05:11:58 PM »
Hahaha.... no,  right switch is toast, left switch is 💯 but it will look kinda stupid if I only replace the right one .....thatís where the Hydraulic clutch bit comes in. VFR800 has what I need (and is free) but has a hydraulic clutch.
So......K100 scrambler with a Honda switches & hydraulic clutch ch 👍👍👍
  • Cape Town
  • K100 RS
« Reply #3 on: August 03, 2019, 07:15:30 PM »
I've never heard of anyone trying it, probably need some creative fabrication for the slave cylinder.  Not sure if the difference between a multi-plate wet clutch and a single plate dry clutch would enter into the equation.
2012 Ural 2WD sidecar (BMW's bastard step child)
Online Martin
« Reply #4 on: August 03, 2019, 07:20:13 PM »
+1 As per Chaos you would need to work out where to mount the slave cylinder and also calculate the correct throw distance (travel).
