I could not get a static voltage reading with ignition switch on. Figured there was no need to crank the engine to test for a pulsating negative if I had no voltage to start. I only tested one connector, they are very hard to unplug the connector, i picked the injector closest to the battery. It was easiest to get the clip off and that one was still hard to do.
I place my positive probe in the female end of the connector and my negative on a good grounding bolt on the frame that I tested by measuring my battery voltage first to test my ground selection. I tried both wires.
I'm thinking that the engine has to be turning for the ignition ECU to activate both the fuel pump AND the fuel injection relay.(but I could be wrong on that one)
The Green/Red wire is the +12v to the injectors. It comes thru the 'fuel injection relay'(in the electrical box under the fuel tank) and direct from the battery(no fuse). The power to the relay coil comes from the right handle bar kill switch, and before it gets to the kill switch it comes from the ignition switch.... all un-fused direct from the battery.
The relay coil ground is controlled from the ignition ECU, the same controller that activates the spark plugs.
There are at least 4 different plug in harness connections that can be dirty, (ignition switch, rh bar switch, injector bundle, injection relay), the kill switch could be going bad, the relay could be going bad and/or have bad contacts.
Fuse #1 is also fed from the ignition switch/kill switch chain, so it can be a good testing point to check power. If you can measure +12v at fuse 1 with the key on, then you should also be getting the same +12v at the injection relay coil.(it's easier to measure at the fuse).
To check the relay socket:
30 is +12v power in from battery
87 is switched power out to injectors and fuse #6(another good place to test if relay is working)--you will find 2 terminals marked 87.
86 is incoming switched +12v from the ignition/kill switch for the coil
85 is the coil ground output to the ignition control ECU
