Author Topic: For Sale: K1100RS Fairing Kit  (Read 1205 times)
« on: July 05, 2019, 06:17:28 PM »
Motobrickers with 2 valve RS models!  Update your ride to the "modern" K1100 RS fairing.  Your brick can go from this:
* 00U0U_4DvrKQHrF6N_600x450.jpg (72.27 kB . 600x450 - viewed 154 times)
to this:
* DSCN3148.JPG (61.85 kB . 768x560 - viewed 157 times)
I'm selling a complete set of parts with hardware to do this conversion.  Everything is you need is included with the possible exception of some screws, even the hard to find belly pan mount is there.
Parts are in usable condition with some easily repaired rash on the belly pan and the lowers.  One of the lowers has a chunk broken out, but the damage is concealed behind the belly pan.  The color looks to be a dark/charcoal gray, but you will probably want to paint everything to match your bike.
$175 plus shipping.  Pay with PayPal.  Cover my gas and I'll deliver to within 200 miles of Buffalo, NY.
* DSCN3520.JPG (79.24 kB . 768x560 - viewed 164 times)
* DSCN3524.JPG (43.79 kB . 539x576 - viewed 172 times)
* DSCN3525.JPG (56.22 kB . 632x576 - viewed 164 times)
* DSCN3517.JPG (61.06 kB . 768x463 - viewed 177 times)
* DSCN3527.JPG (48.06 kB . 694x576 - viewed 172 times)
'91 K100RS "Moby Brick Too
'89 K100RS SE
Offline riots100
Re: For Sale: K1100RS Fairing Kit
« Reply #1 on: July 05, 2019, 11:14:28 PM »
PM Sent.  (should work on the 4V models as well, right?)
  • Los Angeles, CA
BDJ
Offline Filmcamera
« Reply #2 on: July 06, 2019, 07:13:46 AM »
It does, I have put one on my 16v...
The only thing I had to do was tap a hole in the rhs engine block to install a fairing mount, my engine had the place there but it hadn't been tapped at the factory
  • San Jose, Costa Rica
Poserbricker
« Reply #3 on: July 06, 2019, 09:40:56 AM »
It's a direct swap on the 4v K100RS model.  I've done it to two bikes already.  Just pull off the old lower fairing and bolt on the new.  The only new bracket is the one for the belly pan that is included.  The swap was offered as a dealer option on the 4v K100RS.
I haven't done it to a 2v K100RS, but that fairing uses the same parts as the 4v as far as I know so the retrofit should work there too.
'89 K100RS SE
« Reply #4 on: July 06, 2019, 09:47:09 AM »
Sale pending.
'89 K100RS SE
