Author Topic: Restoration: 1995 K1100RS for under a grand?  (Read 8162 times)
Offline Hilltopper46
Re: Restoration: 1995 K1100RS for under a grand?
« Reply #100 on: March 25, 2020, 09:41:29 AM »
If you want to keep it in Wisconsin, this guy rebuilt mine when I bought by K1100LT http://www.ingramshocks.com/index.html .
He's about 45 minutes southeast of me in Kenosha County..
  • East Troy, WI
  • 1995 K1100LT
Current bike - 1995 K1100LT - It RUNS!. You says Plum, DMV says Purple, BMW says Navana Violet.
Previously: 1982 XJ650 Yamaha, 1987 GoldWing, 1995 GoldWing, 2001 FLSTC, 2003 Goldwing
Offline Bon Jon Bovi
  • All's well that's going ashore
« Reply #101 on: March 25, 2020, 12:04:28 PM »
If it was my shock and it seems to work I would take it to a motorcycle shop that caters to the motocross crowd.  Someone there(probably one of the older guys) will recognize your shock.  They can remove the spring so you can have it stripped and powder coated.
Ask them about a new spring.  Racers are always changing springs and if it's a good shop, they'll have a source for a new one, maybe for less than powder coating the old one.
They may also be able to do a rebuild, but if the damping works, I would be inclined to let sleeping dogs snooze.  Clean it up, paint it, and have the moto shop charge the nitrogen and reinstall the spring.
Wooooow. This must be a truly magical place, do I need a DeLorean or a telephone call box to get there? Maybe that peacock chair from the H.G. Wells story? Here in Old New Mexico they ain't got such establishments. Next you'd have us believe there are places where toilet paper and hand sanitizer can just be bought off the shelf whenever you want to!
 :poo
  • Cloudcroft, New Mex
  • '93 K75s-'97 R1100RT-'81 CB750-'76 GL1000 LTD-'74 GT80
62 years. Don't they go by in a blink...
« Reply #102 on: March 25, 2020, 12:17:15 PM »
 :poo
Nobody rides dirt bikes or races in New Mexico anymore????!!!
Any moto dealer's shop should be able to remove the spring while you wait for a couple bucks.  An abrasive blaster can strip the old paint, and then it's off to a powder coater.  The shop that took it off puts it back on and charges the nitrogen.  None of it is rocket surgery.
Marzocchi was a big name in racing shocks and forks back in the late 70's mid 80's.
  • '94 K75RT Mystic Red, '91K100RS White/Blue, '89 K100RS Special edition White/Blue
'91 K100RS "Moby Brick Too
'89 K100RS SE
Offline Rcgreaves
« Reply #103 on: March 25, 2020, 09:26:00 PM »
During my drive to work the other day Iowa public radio had a Jazz show that highlighted the great singer Bessie Smith and Backwater Blues- search it on YouTube.  Anyway the lyrics could easily be modified to "Corona Virus Blues".  I've been too ill of late to get creative, so I digress.
Thanks all for your latest input.  I've located a spring compression tool and a shop to do some powder painting..As for my clutch challenges I checked into machining and used bits but can’t stomach it.  Maybe on K clutch #4 but not on K 11 #1.
There's a serviceable clutch kit on Ebay for $40 - I’ve attached a blurry image of the housing mating surface I had to request from the seller... Bothers me -when selling clutch bits to not show the most critical stuf without having to request a follow up pic.  Sorta like a used car ad that omits images of the drivers seat.  My local shops didn't have tooling to grasp and machine my clutch housing without a center mounting point  .  Growing impatient.  I don’t want to dick around with this. And I definitely want to reassemble once!!
A few overlooked items ordered from MAX today (free shipping on a $30 order BTW)   compression ring, Spacer ring and a new K75 badge...
Pitting on the mating face is probably passable. Auto machinist thought so too...New clutch housing at Motobins is about $170.  Money tight but with this critical bit I’ll go the Johnny route on this score- new bits is best when it comes to an 84k mile clutch  I’ll repaint and inspect my rear strut spring and see how it goes.
Temps in the high 40s today- you can smell spring in the air.  Looking forward to some Moto induced social distancing -Cheers.
  • Livingston, SW WI. USA-"With the good earth all around."
  • 94' K75S , 85' Goldwing Aspencade,96' Honda Interceptor VFR750F, restoring: 1995 K1100RS,
Doing “better than I deserve”
Offline Rcgreaves
« Reply #104 on: April 10, 2020, 12:54:22 PM »
So my Honda Interceptor project has had my sidetracked a bit as I re-learned the functions of my multimeter. "Stators make AC current"...cool...." 2 of six diodes in the regulator rectifier were fried.  It took some time and patience to sort....current-gen units use MOSFETs to shunt overages...I do love BMWs....
Now back to my last acquisition for the K11 clutch:  I need, and acquired today Part #6 on the fiche attached- outer housing far right, Mine is fairly deeply pitted and nasty from 80k and an oil soak.
 Max gets $300+ for this OEM Sachs outer housing OUCH.  Not a whole lot different than the K75 version for half that. a rude awakening when I saw first saw it...My COVID deprived play money account can hardly afford the used unit on eBay , now discounted to $38.  Gotta do better.
Motobins gets about $180 plus even higher cost shipment from the locked-down fortress Europe.  So, Motobins is out as a USA supplier for now.  A German dismantler outfit quoted $100+ $105 to ship...ouch!!
Anyway, good news:  a Vegas dismantler on Ebay just posted a complete clutch from a rather high mileage 1100LT (same clutch) and with a nearly spanking new -:" I can still see the machining grooves in the mating surface " part # 21212333472  can be read on the posting...."Take my money!!!
Here's the auction:
https://www.ebay.com/itm/93-99-BMW-K1100LT-OEM-CLUTCH-PRESSURE-PLATE-R3-BX1/383409677077?autorefresh=true
the second image is the actual part from the listing.  Note the spots of wear surrounded by concentric rings.  this thing hasn't even been worn flat yet...gotta be very low mileage.  Do experts agree??
Better news yet:  he accepted an offer of $52.75 shipped.  Time to install the main seal and maybe paint the center stand.
Offline natalena
« Reply #105 on: April 10, 2020, 03:59:51 PM »
Nah, I can meet you at the Mall or near the clock tower.
  • MST
  • 1987 K75s #0919, '05 Sportster 1200C
We don't need no stinkin' moly.
« Reply #106 on: April 10, 2020, 07:39:50 PM »
Bad Natalena! Wicked Natalena!! Almost bought one in 1992 but was working for chump change at a regional airline flying Brazilian turboprops in and out of Shitkicker, Texas, a fam of four at home, and a wife with her divorce lawyer on speed dial. Had to pass. I am the proud owner of a John DeLorean original bizness card though.
Offline natalena
« Reply #107 on: April 11, 2020, 12:50:17 AM »
A card appropriate for dividing powder lines. John had a place not far from me in Valley Center, lost it to the attorney's representation fees.
  • MST
Offline Rcgreaves
« Reply #108 on: April 16, 2020, 02:09:20 PM »
If John were to card powder on my just delivered clutch housing mating surface he'd miss some...  Machining grooves still visible on both components- nearly new parts! Delighted.
I have three days of liberty, maybe I can clear a path in my trashed workshop.
I still have no idea why the threads on my pilot puller are different than the other parts in my kit.  Early morning epiphany:  maybe that component comes with theads compatible with a puller?  Gotta check that out. ideas?
Offline Rcgreaves
« Reply #109 on: April 19, 2020, 09:49:33 PM »
So my tank bags show the usual wear and tear.  Showed momma the areas requiring stitches while she was chilling in front of the TV, came back in an hour and presto, stitched zipper.  This foam bonder remains flexible so I sealed the stitches with glue.
S100 detailer is the real deal, combined with a low setting on the pressure washer and it made quick work of detailing.  Got a nice line up before packing up for the night.
Interceptor project  is on the market, but I can't help but take it out and flog it while I can.  What a sound!   I uploaded a raw unedited video to YouTube.com.  If impatient.....no names... :nono2:  Skip to:30 or 2:30 for best bits.
Shop is cleaner than its been in months. I'll start by replacing the main shaft seal and pilot bearing.
Offline herseyb
« Reply #110 on: April 19, 2020, 10:28:11 PM »
beautiful sunset there!
  • Brooklyn
  • '93 K1100RS
Offline volador
  • NEEDS MORE CHROME
« Reply #111 on: April 19, 2020, 11:28:44 PM »
Geez too much green for me. Sounds bad arse
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
