Author Topic: Awakening 1987 K100RS from 10 year slumber.  (Read 3505 times)
Offline SpecialK
Re: Awakening 1987 K100RS from 10 year slumber.
« Reply #150 on: August 14, 2019, 09:20:32 PM »
If the master cylinder is off of the bike and disconnected from the brake line, you can dissolve the crystallized brake fluid by a short soak in hot water.  After the parts separate, dry them off and blow any remaining water off with compressed air.
I soaked the parts in soapy hot water but nothing was coming apart. I ended up putting the housing in a vice and clamping a channel lock plier onto the plunger end and turning. After much marring and trying to twist it finally started to turn and I could hear the spring turning but it took some twisting and tapping the pliers for it to come out. the inside of the cylinder looks clean but hard to tell.  I am soaking for a while the see if it will clean up.
The plunger/spring looks good except the tip where the pliers scraped it up. How does it go back in though? does the other end where the hose screws in come out?
I think I have four options; get the retro fit from China, Buy the rebuild kit for $67, buy a whole new master cylinder assembly from MAX for $152, or try to reuse what I have.
Now that I am looking at the photos, the MC doesn't look to be in good condition so may have to go the Chinese or new OEM route:
Marred up tip. Not good. Little plate on the end of the plunger insert came off.
Is inserting to the left the only way for this to go in? The taper on the plunger bushings is against the grain.
Thanks for you help.
  • Wappingers Falls, New York
  • 1987 K100RS
"The first to present his case seems right, till another comes forward and questions him". Proverbs 18:17
« Reply #151 on: August 14, 2019, 10:58:45 PM »
A moment of clarity has revealed to me that for a brake cylinder to be a master cylinder, it must control a slave cylinder. These motos only have one front brake cylinder and one rear brake cylinder.
Anyway, your rear brake cylinder parts are junk when viewed from where I sit on the porch of The Ridley Brook Butterfly and Hummingbird Preserve Gun Club. I recommend replacing the entire rear brake cylinder assembly and also replacing the brake fluid reservoir with a cylindrical container that can hang on a frame member beneath the right side cover away from the effects of sunlight on its integrity.
  • 1995 K75T 72,000 miles
Offline SpecialK
« Reply #152 on: August 15, 2019, 01:03:51 PM »
Yes but if there is no slave then the Master is truly a Master. Maybe of his own destiny, or maybe he's the Master of the brake hose? Anyway, the Fiche calls it a rear brake master cylinder.
Those suggestions sound wise and in line with what I am planning. Thanks
  • 1987 K100RS
« Reply #153 on: August 15, 2019, 01:12:15 PM »
Nonsense. It's Germglish run amok.
Tags: speedometer
