Update: I fitted the fuel pump in the tank, connected the battery and fuel injector module, connected tank wiring for gauge/pump, refit the two hoses on the front left side of the tank, put tank back on and filled about 2 gallons of fuel. All lights came on so I wheeled the bike outside, put choke on the first stop and pressed the starter. The bike cranked but didn't turn over and start. Repeated several times with more choke and no choke but still not starting or even sputtering to start.
So I will rest for now until I can try again later. The low (red) fuel light was on but the gauge read about 1/4 so There should be enough fuel.
Any ideas?
Thanks, John
