They're not too hard to replace, just takes some patience. Plenty of on line help. http://www.odometergears.com/products/BMW/R+&+K+Motorcycles/42
... the gears on the odometer are literally made of cheese and crumble.
Overseas Speedometer in Austin, Tx does a good job
Question: The speedometer on my 1991 K75S still works fine, but this afternoon, the odometer and trip meter stopped. I'll clean the speedo sensor on the final drive when I get home, but since the speedometer works, I'm not hopeful. Any ideas?Quote from: brichbk on May 02, 2019, 12:15:08 AMInstalled a new HFP-437 Fuel Pump I got for $42 on Amazon. It's a direct replacement for the factory one.
To many of us, that probably would seem unsuitable for use as either an odometer or a speedometer.
Any experience of these things having a short hiccup and then function fine for another 40K miles?
'll just keep riding it until it becomes annoying to not have an odometer. They seem overrated.
They are overrated. Use an astrolabe instead. As long as you have a relatively accurate low fuel light and ability at dead reckoning, you're golden.
<CUT>Did some investigating here and found this post. Contacted Overseas Speedometers in Austin, Texas and got a quote to replace the gears and such. <CUT>
But where do you keep the charts??
I'm curious how much they ask to rebuild it. It's not difficult and they are available with instructions as I posted previously.The bike runs fine without updating the odometer, you'll just have to keep an eye on the fuel lamp. On my '93 K75S the trip meter has never worked since I've owned it and when the odometer quit I dismantled the cluster. It was apparent the gears were shot for the odometer but I still could not figure out the failure in the trip meter and without a spare I did not want to take it too far. I've used an inexpensive bicycle computer to keep track of the tank mileage since I've owned it and have replaced the gears.
You put them in the maritime version of City Cases—Nauti Cases.With GPS and its swarm of attending apps, odometers and speedometers are quaint reminders of a simpler time—like Regal Beer cans and prophylactic machines that need change to be operated.
I still need to put three quarters in the ignition before I can ride the bike.
As long as the low fuel light works you should be okay. If is comes on as you say at 100 miles, just figure on filling the tank within an hour and you should be good. I suspect one of the drive gears for the tripmeter has lost a tooth. If you are adventurous you can open the case and get at the odometer and make a repair in an evening.
