Author Topic: Possible Water Pollution?  (Read 6795 times)
Offline Ironwrx
  • I thought I was wrong, but I was mistaken.
« on: April 08, 2019, 07:28:57 PM »
     Hi. The long Vermont winter has finally loosened its grip and the multiple glaciers have finally given way to mud!  This got me thinking of coming back out of hibernation to get on my bike again for an early spring ride.  The temperature got up to 55 (my minimum is 50) and I decided to start up the bike and see how it ran. Well, it started after an extended start time, (with considerable starter use), and it seemed to need a longer choke use than normal. after a short time, I ramped down to 1/2 choke. still running a bit rough, I tried the throttle.  It popped (backfired), and has not started of its own free will since.  I did try starting fluid several times, but couldn't get more than a few coughs out of it.
     During the long cold lonely winter, I may have made a fatal mistake: my wife was low on gas in her car, and at the time we didn't have any cash, so I siphoned the gas from the bike. Normally I don't like to do this, on account of condensation fear.  I did refill the tank, and ended up putting "mechanic in a bottle" fuel treatment in. Unfortunately to no avail. Any ideas out there? or am I going to have to tear out the carbs, swab out the tank, etc.? help!!
  • Westminster West
  • 1985 K100 83 Type 0511
- Jon
Re: Possible Water Pollution?
« Reply #1 on: April 08, 2019, 07:54:38 PM »
you may have some water in the tank, add a can of HEET to a fresh tank and swapping out the plugs for some new ones will probably fix you up.  Don't worry about the carbs, K bikes are strictly on the Kito diet.
« Reply #2 on: April 08, 2019, 08:16:27 PM »
+1 on the condensation.
Get the battery on a charger.  If you haven't done it lately, get a NAPA 3032 fuel filter and install it.
Get a couple cans of drygas, the isopropryl alcohol stuff, a bottle of Techron fuel system cleaner, and a couple gallons of no corn gasoline if you can find it.  Pull as much old gas out of the tank as possible, and use paper towels to soak up the stuff remaining at the low points.  Add the fresh fuel and 1 can of drygas with the Techron.
Try to start the engine.  If it starts, great, if not, that's okay too.  Crank it a bit to circulate the mixture in the tank and blend it with the stuff that you couldn't remove.  If it still won't start, crank for a minute or so, and let it sit overnight on the charger while the fresh fuel cleans things up in the injectors.   Next day it should start.
Offline Ironwrx
« Reply #3 on: April 08, 2019, 10:53:42 PM »
Thanks guys. (Sigh) I’m glad there is apparently hope for my blue babe. I’ll update when I get a chance to try the suggestions.
  • Westminster West
- Jon
Offline blackie1
  • christchurch nz
« Reply #4 on: April 13, 2019, 02:32:01 AM »
methylated spirits mixed into your water contaminated fuel at a ratio of 15ml per liter.
Meths is Hygroscopic. it attracts and absorbs water and will allow it to be combusted through the engine.
had great success with this a few years back.
cheap option and normally have a half bottle of meths laying about in the shed...... or the drinks cabinet
  • 1991 K75RT naked 67,000kms
Offline Ironwrx
« Reply #5 on: April 14, 2019, 08:50:12 PM »
Ok. It’s kind of a moot point (and you will see why momentarily. But what is mentholated spirits?
  • Westminster West
- Jon
« Reply #6 on: April 14, 2019, 09:02:04 PM »
It's a UK term for denatured alcohol. Methylated.
Offline Ironwrx
« Reply #7 on: April 14, 2019, 09:24:13 PM »
Hi. Thanks for the suggestions guys.  I was planning on new plugs, and a new filter, as suggested …BUT… when I took the gas cap assembly off to clean up the tank this is what I found!! Ahhhh Haaaaa!!!! So, Ol’ Blue didn’t have a major problem after all. Just a minor fuel hose disconnection!!  I swabbed out the tank, put in some Techron, re-attached the fuel
Hose, and Voila!! It’s Alive!! And runs great!! I’m not sure how the fuel hose got disconnected, but glad it was an easy fix!!
I am left, however , with a couple of questions: how did the hose get disconnected in the first place? In picture #1I show a broken fuel pump hold-down tab that I discovered in the bottom of the tank. Should I be worried that the pump is now only ”snapped in” with one tab? In picture #2, and #3I found what I thought was an old dead leaf, but was actually some type of “filler” or sealant that had been used somewhere and ended up in the bottom of the tank. This “filler” was just loose in the bottom of the tank, and seems to have no purpose there. Anyone seen any of this before?
  • Westminster West
- Jon
Offline Ironwrx
« Reply #8 on: April 14, 2019, 09:32:38 PM »
Gotcha! So, I’m your opinion, is that better than to use isopropyl?
  • Westminster West
- Jon
« Reply #9 on: April 14, 2019, 09:42:07 PM »
. . . when I took the gas cap assembly off to clean up the tank this is what I found!! Ahhhh Haaaaa!!!!
The fuel line connected to the fuel filter doesn't appear to be in good condition. Consider replacing both lines connected to the filter with high pressure, submersible fuel hose. The fuel pump holder will probably be stable enough with one locking tab if the moto isn't habitually ridden over pothole fields. The tab's being broken indicates that the plastic might be brittle so take care when removing the assembly from the tank.
There appears to be the imprint of welding bead in that material you identify as filler. No telling whether that material was inserted within the tank to stop a seam leak or dropped accidentally, or for some other purpose. It doesn't look like anything I've come across in my moto's tank.
You don't need to use either IsoHeet or yellow Heet in your tank. Put some clean fuel in it after you replace the fuel hoses.
Offline Ironwrx
« Reply #10 on: April 14, 2019, 11:24:33 PM »
I agree with your impression of the look of this “filler”. I guess since there doesn’t seem to.be any leaks, it doesn’t seem to belong there. I’ll just be glad it’s no longer rattling around in there.
  • Westminster West
- Jon
« Reply #11 on: April 15, 2019, 02:29:30 AM »
If you are concerned about the missing pump locking tab, try wedging a short piece of submersible fuel hose trimmed to fit into the missing tab slot. You can do this while you are replacing your other tank hoses.
« Reply #12 on: April 15, 2019, 03:41:56 AM »
Back in the days (before ethanol blend was available) on the rare occasion I had freezing or condensation problems, I would pour half a litre of metho (~alcohol)  in the tank, and it would be problem solved. Nowadays you don't have to, just put ethanol (~alcohol) blend in your tank. It's an even rarer problem now that carbies are so rare. I spose it might still be a problem in colder countries.
« Reply #13 on: April 15, 2019, 07:59:25 AM »
+1
Offline Ironwrx
« Reply #14 on: April 15, 2019, 11:07:30 PM »
Well, Laitch, I think you’re right!! I clamped the fuel line that’s connected from the filter back onto the pump, and  a day later, while showing my son how nice the bike started and ran, it happened again - pop tap the line came off the pump again and hit the inside of the tank. I’ll Be ordering some new hose from Max. Could this possibly be caused by a partially blocked fuel filter too? The Mighty Gryphon Suggested a Napa 3032 fuel filter. Is this OEM spec? Or would another one be better?
  • Westminster West
- Jon
Offline blackie1
  • christchurch nz
« Reply #15 on: April 16, 2019, 12:04:25 AM »
trust in the Gryphon my friend
« Reply #16 on: April 16, 2019, 07:08:44 AM »
If you still have that piece, see if you can find where it fits. Maybe on the right hand side at the low point. If you find a spot where it fits, it might give a clue as to its purpose.
« Reply #17 on: April 16, 2019, 07:46:59 AM »
. . .  while showing my son how nice the bike started and ran, it happened again - pop tap the line came off the pump again and hit the inside of the tank. . . .
The hoses look degraded. A clogged filter can cause back pressure that could possibly push it away from the pipe connection at its inlet hose.
Regarding the filter model:
If you can't believe an experienced member who owns K-motos and has tens of thousands of long distance K-moto riding miles under his butt, or can't believe the suggestions in the Alternative Parts section, why don't you start a poll about the issue then let the majority of responses guide you?
Offline Ironwrx
« Reply #18 on: April 16, 2019, 08:04:41 AM »
I apologize, if it looked like I was questioning anyone especially you, Gryphon. I plan on getting the correct hose that Laitch suggested, as well as that NAPA filter. I am just a mere beginner with these fantastic machines, and have a lot to learn not only about the bike, but also to maximize this great resource we’re using here on this forum. Thanks to all of you for your helpful input.
  • Westminster West
- Jon
« Reply #19 on: April 16, 2019, 08:49:43 AM »
I apologize . . .
Доверяй, но проверяй. :giggles
« Reply #20 on: April 16, 2019, 09:26:27 AM »
Hey,  Ironwrx, no problem.  You gotta be careful with the stuff you see posted on the interweb.  There are a lot of experts out there who have little more than a keyboard.
NAPA filters are pretty good and will work at least as well as the OEM units.  The main thing for a K bike filter is that it has a steel body to handle the pressure and heat in the tank, and that the connections are 5/16"(8mm).
While you are at the NAPA store you can also get the fuel line.  I can never remember the SAE spec number, but I'm pretty sure your neighbor, Mr. Laitch will have it in a few moments.
Speaking of Laitch, I need to take another trip up to the Green Mountains to buy him a cuppa.  Maybe can meet you as well.  It would be nice to do Rte 100 without the snow flurries I hit the last time.
Offline Ironwrx
« Reply #21 on: April 16, 2019, 05:24:52 PM »
Hi. Laitch -  The Gryphon suggested that you might have a suggestion of an alternative hose that I can use from NAPA or elsewhere that would work in the tank to and from the filter compared to the $32+ oem hose?
  • Westminster West
- Jon
« Reply #22 on: April 16, 2019, 06:08:58 PM »
This is the stuff:  5/16"   The spec is SAE 30R10 submersible fuel line hose.
http://www.napabeltshose.com/~/media/napa/documents/napa-submersible-hose.pdf?la=en
Offline Ironwrx
« Reply #23 on: April 16, 2019, 09:41:19 PM »
Thanks for the info, I can’t wait to call them up in the morning!! It’s been a long winter, I’ve got that itch to ride!!
  • Westminster West
- Jon
Offline Ironwrx
« Reply #24 on: August 30, 2019, 08:30:12 AM »
Here I am at long last with an update on my early spring fuel issue. As suggested, I replaced  the fuel hose with the submersible NAPA hose. This was due, but a clogged fuel filter was the biggest culprit in my problem. When I removed the filter, I was barely able to blow through it.  A friend offered me an original Mahle filter he had, so I didn't  end up using the NAPA filter as Laitch suggested.  I still to this day do not know what the "filler, or bondo" substance was that I found in the tank, but upon removal, there haven't been any leaks.   The bike ran beautiful, with no issues. Thank you to all who chipped in.
  • Westminster West
- Jon
