Author Topic: I'm back, the Brick is getting better.  (Read 352 times)
Offline JPaganel
« on: April 07, 2019, 08:58:04 PM »
I had a bit of an absence from here for various reasons you guys don't need to know.
Anyone I was PMing with about buying stuff - I apologize. Life got in the way, as it does.
Anyhoo. I have christened my Brick the Frankenbeemer.  And it's alive!
Starts, runs, drives.  Latest things done to it was replacement of the cover bolt seals and a new crankcase seal - they were leaking. Also, an oil change and a wash to get rid of ghosts of leaks past.
I don't have any sidecovers yet, kinda debating buying vs. making.
Also, noticed when doing the oil that the bike has a decided starboard list on the centerstand. I think the stand is wonky. Need to look into that.
  • Minnesnowta
  • 1986 K100RT, 1996 R1100RS
Offline JPaganel
Re: I'm back, the Brick is getting better.
« Reply #1 on: April 07, 2019, 09:00:56 PM »
Also, I got a hold of this bit of awesome.
I think I will have to pull front half of the air duct for it to work. Also, it needs brackets. I haven't been able to find any, might have to make some.
If anyone knows where they might exist, let me know.
  • Minnesnowta
« Reply #2 on: April 07, 2019, 09:17:32 PM »
I'm not positive, because I have not seen that radiator cowl before, but I suspect you need a K75C tank with a couple of pins at the front that the cowl hangs on.
I just bought one of those tanks to get a fuel level float, and will be selling the tank after I get the level sensor out.  If indeed you need it, I can make you a decent deal on it.
  • '94 K75RT Mystic Red, '91K100RS White/Blue
'91 K100RS "Moby Brick Too
« Reply #3 on: April 07, 2019, 09:29:08 PM »
If you replace your center stand,  get the later type that is not made from bent tubing.
« Reply #4 on: April 07, 2019, 09:32:45 PM »
Post a photo of the inside of the cover.
  • 1995 K75T 68,000 miles
Offline JPaganel
« Reply #5 on: April 07, 2019, 09:38:04 PM »
You might be right. I thought it was a bracket bolted to the radiator, but that looks about correct.
If they are otherwise the same size, that sounds like a swell idea. Bike is headed towards being black anyway.
  • Minnesnowta
Offline JPaganel
« Reply #6 on: April 07, 2019, 10:30:48 PM »
Here ya go.
  • Minnesnowta
« Reply #7 on: April 08, 2019, 12:15:35 AM »
Looks like your radiator cowl has sockets for the pins on the front of the C model tank.
When it gets here later this week I'll take some good photos and make sure it's in good usable shape.  The photos I've seen of the interior look clean.  I know it has some scratches and chips in the paint but no dents, and one of the badges is gone.  It's going to need a paint job.  I'm pretty sure it will work on an RT frame.
« Reply #8 on: April 08, 2019, 09:47:13 AM »
I remember seeing that thing on Max's fiche, when I was a K-bike newbie, and getting all excited about it. (My K100 came to me with all its bodywork long gone.) But I've never seen one, IRL or offered for sale. It's cool to see one out in the wild.
« Reply #9 on: April 08, 2019, 11:14:35 AM »
I remember seeing that thing on Max's fiche, when I was a K-bike newbie, and getting all excited about it. . . . But I've never seen one . . . offered for sale.
Mark this day in your diary. Lookee!
« Reply #10 on: April 08, 2019, 01:43:50 PM »
Fancy markup on that thing.
Offline JPaganel
« Reply #11 on: April 11, 2019, 01:34:01 PM »
It really isn't bad, considering it's a body part for a bike long out of production.
  • Minnesnowta
Offline JPaganel
« Reply #12 on: April 11, 2019, 01:35:49 PM »
So, my new oil sight glass came in just in time for me to realize that the original is not only too cloudy for me to see the oil clearly, but also leaking.
This pressure washing the bike thing is amazing.
  • Minnesnowta
« Reply #13 on: April 11, 2019, 05:10:13 PM »
Amazing collection of cafe K parts there, a looper's wet dream.   https://cafe4racer.eu/en/24-bmw-k75-100-1100#
2012 Ural 2WD sidecar (BMW's bastard step child)
« Reply #14 on: April 11, 2019, 05:15:14 PM »
 :laughing-on-ground:
« Reply #15 on: April 14, 2019, 07:27:20 PM »
I have a K75C fuel tank that will work with the radiator shroud.  I have it listed in the For Sale section with photos.
Offline Soggz
  • 2 wheels are better than 4,but 4 wheels are 2 bike
« Reply #16 on: April 16, 2019, 03:38:54 AM »
You should be careful with pressure washers, as they can force water into places that water wouldn’t normally go...just saying...
  • High rise multi-storey car park.
  • 1988 K75C, 1982 Honda CX500EC Eurostreetbrat
Offline JPaganel
« Reply #17 on: April 19, 2019, 12:58:13 AM »
Put in the new glass.
The old one was pretty loose - I just popped it out with a pocket knife, didn't even have to pry much at all.
I'm not sure if the oil pan gasket is leaking or not. Might do another wash to make sure.
  • Minnesnowta
