Hi guys
My bike is a BMW K75 RT (750cc) EU spec with ABS (year 1994).
I am replacing the OEM rubber pipes that ran from the metal ABS lines - one of the old rubber OEM lines went to the Master Cylinder, and the other old rubber OEM line went to the Front RH Brake Caliper. Neither of these lines attach directly to the ABS, but instead attach to the metal ABS lines (see below paragraph).
There are 2 OEM metal ABS lines factory-fitted as part of the ABS system, these run in parallel from the ABS Modulator on the side of the bike under the tank and towards the front of the motorcycle (one "send", one "return"). These terminate up under the yoke with a male fitting each. Both of the male fittings on these 2 metal lines are identical.
I need 2 hoses, 1 "send" and 1 "return" line.
(1) "Send" line: from the Master Cylinder to the metal ABS line under the Yoke. One one end, a standard 10mm female connector that fits a banjo 10mm off the M/C .... at the other end the (as yet unknown!) female connector to attach to the metal ABS line male connector as described above. This line to be 35 cm (I will double-check the length to be absolutely sure, before ordering).
(2) "Return" line: from the Front RH Caliper to the metal ABS line under the Yoke. One one end, a standard 10mm female connector that fits a banjo off the Caliper .... at the other end the (as yet unknown) female connector to attach to the metal ABS line male connector. This line to be 55 cm (I will double-check the length to be absolutely sure, before ordering).
The unknown connectors .... they look I/D 10mm to me, but what thread spec I don't know. They look more like something off a car, PLEASE SEE PICS and let me know if you recognise these fittings!
ORDER OF PICS:
1. ABS "Send" (male)
2. ABS "Return" (male)
3. Caliper Banjo (male)
4. Master Cylinder Banjo (male)
5. Old Hose connection (female) to ABS "Return"
6. Old Hose connection (female) to ABS "Send"
It's pics 5 & 6 that show the (unknown to me) connectors.
Many thanks again,
Steve
